SSA Car Audio Forum: Hoffman's Iron Law - SSA Car Audio Forum
Digg Del.ico.us Slashdot Technorati furl Reddit Facebook Fark Google Magnolia Wink Yahoo Netscape
  • (2 Pages)
  • 1
  • 2
  • You cannot start a new topic
  • You cannot reply to this topic
Hoffman's Iron Law Rate Topic: -----
#1 User is offline   Neil Icon
  • Four factorial, is that youl!?!
  • PipPipPipPip
  • View gallery
  • Group: SSA Audio Tech Team
Posted 23 February 2007 - 05:02 PM
I love Iron Laws. Why? Well, they are so succinctly and aptly named: they are infact, iron. Good luck breaking them!
If you've been a browsing member of the online audio community for a while, you have no doubt heard about Hoffman's Iron Law. What's it all about? Well, it is quite simple. Forgive me if I am misquoting here, but I think JimJ put it best when he said:
"You can have low end extension, high efficiency, or small enclosure size. Pick two."
Please note that while many people use this statement related to enclosures, it applies to the speaker you're using as well ;) So what does that mean? And why is that the case? Well, as you may have heard me say once before, speaker design and engineering is a game of compromises. The best speaker (if there truly is such a thing) is the one that has the lowest impacting compromises.
Let's say you you drive a little Dodge Sprint or another vehicle with a relatively small cabin and little-to-no room for an enclosure. Of course, you're a bass head and you want to hear those lower notes banged out with some authority. To top it off, you're a cheap bugger and want a lot of sound without buying an expensive amplifier. You build your miracle enclosure, install everything, power it up, and surprise! Those low notes just aren't there. You tried to have your cake and eat it too, which just doesn't work in the real world. Naturally, you think there must be something wrong with the sub or amplifier. Now you have switched every product imaginable in and out. The good news is that an amplifier rated much higher than the RMS of your sub has given you that low end beat you're looking for. The bad news is that you just cooked a voice coil.
And this is Hoffman's Iron Law at it's finest. If you want a low end monster, you had better step up the power or build a behemoth enclosure. If you want to keep your amplifier costs to a minimum, you had better build a huge enclosure or accept a very high rolloff with very little low end. If you want a small enclosure, be prepared to buy a big amp or give up that low end you love.
What is the specific relation between these by-products? Simply put, the efficiency of any speaker system is directly proportional to the enclosure volume and the cube of the f3 (the frequency at which SPL is down 3dB). If you halve the efficiency of your speaker system, you may also halve the volume of the enclosure. However, if you decrease the f3 of your speaker system by a factor of two while retaining the same efficiency, you would have to increase the enclosure volume by a factor of 8 (2^3=8). Let's say you have an enclosure with an efficiency of 90dB/w/m that is 2 cubic feet in size. Suppose the f3 of this system is 30hz. However, you've decided you want a heavy bottom end and wish to drop the f3 to 15hz. Without decreasing efficiency, this change would require an enclosure measuring 16 cubic feet in size! That is quite a change, and hardly affordable in a vehicle.
With a lot of preamble, I think that adequately explains how things work on the enclosure side. But as I mentioned earlier, this applies to a normal speaker prior to installation as well. I'll cover this when I get a chance, but to provide a starting point:
where n0 = reference efficiency (% based)
Fs = the resonant frequency of the driver (measured in Hz)
Vas = Volume of air which, when acted upon by a piston of area Sd, has the same compliance as the driver's suspension (measured in m^3)
Qes = electrical "Q" of the driver at Fs (unitless)
n0 = (9.614 * 10^-7 * Fs^3 * Vas)/Qes * 100
This post has been edited by DevilDriver: 24 February 2007 - 05:16 AM
0
#2 User is offline   JimJ Icon
  • Banned
  • PipPipPipPipPipPipPipPipPip
  • View gallery
  • Group: BANNED
  • Gender:Male
Posted 23 February 2007 - 10:20 PM
Excellent info!
My journey down the road of single ended triodes has taught me this all too well...getting reference levels with a lightbulb's worth of watts is no place for puny, stand-mounted "bookshelf" speakers :)
0
#3 User is offline   bdawson72 Icon
  • Advanced Member
  • PipPipPip
  • Group: SSA Regular
Posted 25 February 2007 - 06:37 PM
good read
0
#4 User is offline   Chris Icon
  • Regular Member
  • PipPip
  • Group: Members
Posted 25 February 2007 - 11:32 PM
I have always "known" a little bit about this topic, but am definitely happy you posted this thread. It gives "meat" to the subject of necessary comprimise when deciding which driver, enclosure, and amount of power to use.
0
#5 User is offline   CBFryman Icon
  • SSA Master
  • Interests:Stereo/acoustics (particularly bass/infrabass) (duh), Bass, Physics, Chemistry, Wakebaording, Surfing, Soccer.
Posted 06 March 2007 - 02:46 PM
Good write up. I especially like the 5th paragraph.
You see that with noobs all the time.
I have a big enclosure, two big speakers, and a lot of power...Got low-end?
QUOTE
One good thing about music, when it hits you feel no pain. So hit me with music, hit me with music!
Owner of Post 100,000th Post in the IHop... May 11, 2006
Do NOT Buy From Ikesound.com
0
#6 User is online   denim Icon
  • SSAudio Level 12
  • PipPipPipPipPipPipPipPipPipPip
  • View gallery
  • Group: Admin
  • Gender:Male
  • Interests:German auto's, American Speakers, my family, photography, collector amps, good music, and this place!!
Posted 07 March 2007 - 03:21 PM
This is something everyone on here should read. Heck I need to read it again.
0
#7 User is offline   tejcurrent Icon
  • Advanced Member
  • PipPipPip
Posted 08 March 2007 - 09:07 PM
Great info. Nicely written too.
0
#8 User is offline   sqguyib Icon
  • Member
  • PipPip
  • Group: Members
Posted 10 August 2007 - 05:42 PM
Very nice write up!
If you happen to have a trunk you can cheat with IB (free-air) subs and get that 30Hz, but it has its drawbacks as well so it is not for everyone. You can use less wattage and then use more drivers to increase output. Since you can't lay the power to IB subs like with a box, you don't need super high power subs either. Problem is finding drivers that will work properly as that is a large extent of your tuning ability, though a great eq would help. Also IB tends to work better for SQ with its ability to produce low Hz tones more easily and its limited power capacity. If done properly you can make a stout IB setup with a moderate level of amp and sub wattage that can produce powerful 30Hz for music listening --and have no box in your car at all.
You would need to (very roughly) use twice the subs and half the wattage of an average box setup. Most subs that manufacturers say can do IB will say at half the rated wattage. Maximum applied amp power will be at the point the subs are playing near xmax, not any rating. Research this before you do it. I just put in 4 12" and they work well but I don't have it all sorted out yet.
0
#9 User is offline   Naledge503 Icon
  • Newbie
  • Pip
  • Group: Members
Posted 17 August 2007 - 05:29 PM
Very good info. This helps answer questions that I have now and have had in the past.
1995 Acura Integra RS
H/U: JVC kd-avx1
Speakers: CDT cl60a/tw25 comp set.
Subs: 2 12" AQ SDC2.5's
Enclosure: 3.6CuFt net tuned to 35Hz built by BJ Fisher
Amps: AQ2200D and kx100.2
Electrical: Iraggi 200A alt. Big 3 with 1/0 Knu KLM
0
#10 User is offline   almond Icon
  • Member
  • PipPip
  • Group: Members
Posted 28 August 2007 - 01:43 PM
how does this relate to t-lines and rear loading horns??
empeg riocar=H/U
mmats sq4035=4 channel amp
mmats d300hc= sub amp
treo ssx motor with 4 inch coil/tc sounds 12" basket=jumble mess of a sub lol (thanks Chad!!)
aundiocontrol 2xs= front stage crossover
mach5 mli-6.5's= front mids
looking for good tweets now :)
0
#11 User is offline   Neil Icon
  • PipPipPipPip
  • View gallery
Posted 28 August 2007 - 02:35 PM
Same rules apply, in general. They just apply in different ways. With a horn, for example, you generally limit low frequency extension if you keep the length of the throat short, and limit efficiency if you keep the mouth area small. You simply must build a large enclosure if you want to keep either of those two, which is why true horn enclosures are usually very big.
0
#12 User is offline   woodguy Icon
  • Newbie
  • Pip
  • Group: Members
Posted 09 September 2007 - 12:12 AM
Good Info. A must read.
0
#13 User is online   denim Icon
  • SSAudio Level 12
  • View gallery
  • Group: Admin
  • Gender:Male
Posted 14 September 2007 - 05:22 PM
Thats for sure, if more people understood this, there would be less topics coming back saying that their speakers don't sound right or don't "hit" like they expected them to.
0
#14 User is offline   yjblitz Icon
  • Newbie
  • Pip
  • Group: Members
Posted 14 September 2007 - 07:24 PM
wow very informative answers a few questions............nice piece
0
#15 User is online   denim Icon
  • SSAudio Level 12
  • View gallery
  • Group: Admin
  • Gender:Male
Posted 25 September 2007 - 09:24 AM
I hope you don't mind, I shared the topic on CYV also. :)
0
  • (2 Pages)
  • 1
  • 2
Page 1 of 1
Trackbacks
Trackback URL Trackback Date Total Hits
No trackbacks were found
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
Affiliate Links
Car Audio Classifieds
Car Audio Classifieds! Here you will find a great car audio forum dedicated to the automotive enthusiast. Buy, Sell and Trade your car audio gear!
Second Skin Sound Deadening
Aftermarket insulation products for reducing noise, heat and vibrations in automobiles. Sound deadener at its finest!
Car Audio Forum
Car Audio Forum! Here you will find a great community dedicated to car audio and the automotive world. DIY heaven here at CA-F, so come, join up, learn and discuss your passion!
Home Audio Forum
HomeAudioForum.net is the online place for Home Audio, Home Video, and DIY Home Audio Enthusiasts to learn from each other sharing their knowledge and experiences.
Phoenix Web Design
Phoenix Web Design & Freelance service offering website design, Custom web design, web development, ecommerce web design and search engine optimization.
Car Audio Store
Car Audio's Best Prices, Brands &Products! Sundown Audio, Sound Solutions Audio, Incriminator Audio, Mach5Audio, Cadence, US Amps, Zed Audio & more!
Phoenix Painter
Platinum Image Painting is the Phoenix painting contractor for commercial and residential, Interior and exterior painting.
Arizona Bail Bonds
Arizona Bail Bonds. 800-556-4373. Fast bail agents for Phoenix. Arrested? Free Information.
Poker Rakeback
When you play online poker, you will inevitably get raked in most of your hands. If you have a good rakeback deal working for you, you will get a portion of that money back.
Team SSAudio, Bass Racer(s) Welcome
This is our website dedicated just to the devoted and hard working members of our team. TeamSSAudio consists of sound quality competition, very high output, show car(s) and bass race vehicles.
Skin by Skinbox
Quality & cheap IPB skins, premade vBulletin styles, cheap Web templates and more! - Skinbox
LaFountain Web Design Professional Web Development
