All Activity
This stream auto-updates
  1. Today
  2. Platform for consensual free relationships Real-life Females Optimal Сasual Dating
  3. jcarter1885
    Total newbie here
    Definitely should be fun learning all the new brands and ways that car audio has changed over the years. Glad you're back
  4. Last week
  5. Aaron Clinton
    Total newbie here
    Welcome back.
  6. Aaron Clinton
    2021 Volkswagen Passat Rline
    Good to see SSA in the build.
  7. Aaron Clinton
    2017 Audi Q3 stereo upgrade
    Any April updates?
  8. jcarter1885
    I finally got my trunk light back working, had to do anjothenight video of the enclosure. 20240418_204054.mp4
  9. Earlier
  10. jcarter1885
    Nighttime view of enclosure with lights on. 20240410_205215.mp4
  11. jcarter1885
    Daylight view of enclosure with lights on. 20240409_131331.mp4
  12. jcarter1885
    I removed the Stinger X RCAs and replaced them with Rhyno RCAs. Sorry I haven't cleaned up the wiring some but I haven't messed with this system since I installed the JL DSP. 20240409_114311.mp4
  13. cobra65427289
    Total newbie here
    Well maybe not totally. I joined back in 2003 when the site came back up. I took about a 15 year hiatus from car audio. Spent some time in college, spent some time on my career, spent a little time on life. Now I'm in a comfortable spot in life where I have the time for treating my car like a toy again. So I figure why not stop back by one of the best forums I remember. I'm Alex, from northern illinois, the only older piece of equipment I still have is an old blown Avionixx AXT800.2 so don't expect to see any OG gear haha. I'm still a noob, hoping to gain as much knowledge as I can as quickly as I can about newer gear and doing a simple install in my boring '23 Forester. PS excuse all the numbers in the name, I was really young when I made this screen name, admin please lemme know if its possible to change this nonsense
  14. Just depends on music choice really since most songs aren't really under 30 hz. But to be safe an adjustable subsonic filter will be wise especially if you are playing rebassed or boosted songs.
  15. The kicker having a fixed sub sonic filter at 25hz 24db slope , the E1500 has an adjustable SSF with a 12db slope. My enclosure is tuned to 35hz . Just don’t want to have any issues with playing to far below tuning.
  16. You won't hear a difference in power so just flip a coin, either amp will be a solid choice.
  17. I have two kicker comp q 12’s dual 4ohm and looking at two different amps , the kicker cxa 1800.1 and the D’Amore engineering E1500.1 . Love the idea of the E1500 but I feel like the kicker would be better power wise just not sure .
  18. jcarter1885
    Yeah my factory battery was a group 43 but I seen a dude fit a 48, so I went that route. It was snug but it fit like a glove. The only company I found at the time who would make an H/O alternator was Brand X and mine is a 270. Had it installed in Summer of 22 and no issues yet, he had bigger sizes but this size was the most reliable and dependable. I have 2/0 welding cable all throughout the ride. 2 power runs from front battery to rear batteries. Amps grounded to batteries, rear batteries grounded in spare tire well. One positive and negative run from front battery to alternator. And 4 grounds under the hood too. I been meaning that call Brand X and see if grounds from front battery to rear battery or from alternator to rear battery would make any differences.
  19. bigrank916
    What kind of alternator did you go with in that VW? I think your car would have the group 47 battery? Mine is the 48 so I've got a few more electronics I think as well as being a midsize SUV. Where did you use the 2/0 cable at? 2 runs of pos to the rear from the batt or alt? Yeah I fucking wish I could just yank that head unit out. I was planning on using the old Pioneer DEH 80PRS but that plan went up in smoke quick. Its fitting that I left off with probs in that Merc and getting new ones for the Audi. I'm half tempted to drive it by the shop of Steve Meade Designs here in Sac and ask them what they would do lol. I met Steve before but I highly doubt he would remember me. I know exactly where the shop is and it looks like he has a walk in storefront of some kind. Maybe when I get the electrical done I might cruise by
  20. bigrank916
    I'm not sure what you mean by "jump inputs" for amps. Come to think of it, my stock speakers are actually 2 ohm besides the trunk sub and possibly the front center channel as well. I think those might be 8 ohm. Your suggestion had me thinking of instead of just classic wiring one speaker for each channel, I could run 2 of each mid/high in parallel for a 2 ohm load. I would use both doors on each side together. That would leave me with 4 channels and using only one amp. What do you think of that route? Ok well I like the idea of keeping shit the same so since I don't have to buy the isolator, I'll use it. I might end up using AGM under the hood and lithium in the rear. That's too bad about the resting voltage. I cranked mine up a few notches in my old truck but this is obviously much different. I guess I will find all this out when searching the vagcom software. I'm gonna have to get that and a decent laptop. Or a tablet I guess. Will those work too? I just need it for that and possibly a DSP software since I would have the ability to use it then. Plus they could make this install a bit easier. Hopefully
  21. Chapter2
    Yeah, you don’t have to run one, it’s just anouther way to keep the charging system intact and separated from the oem. I did it because I have enough reserve but either will be fine, I just always worry about the Electrical,,
  22. jcarter1885
    I don't have an isolator in my VW and have no problems with voltage or anything to that affect. Granted I have an aftermarket alternator, but stock wiring still intact. When I had the factory alternator and battery in, it did limit my voltage. Just by doing the big 3 and upgrading my front battery to an Odyssey Group 48 AGM I gained .5volts. I went from a voltage at idle with lights on and A/C from 13.8v to 14.3v. Once I did the h/o alternator, I didn't have any other voltage issues. Now at times during the winter I can see voltage as high as 15.3 and 14.5-8v during the summer and I'm in Texas. OP sucks you can't take your factory radio out because the one in my car sucked, using Bluetooth it would just go silent for like two seconds every 30 minutes or so give or take. Everyone said it's just something with the radios they use when using the Bluetooth setting. I had soany issues with the factory radio and NAV-TV unit that it made me rip out my radio and replace it with a Sony head unit, I haven't had any issues since. Yes codes are crazy, I had to take it to a shop to get all that stuff figured out since my car was new and no information was out about it at the time.
  23. Chapter2
    The link 8 will work also, really just depends on your needs, typically you jump inputs for your amps, I’d personally run one 4 channel for all 8 highs and mids with passive crossovers (assuming they are all 4 ohm,) but that’s just me, less equipment the better ,again just how I would, I originally picked up the Wavtech for a Fiat I’m building and tbh price/features and spec was the biggest reason for the purchase,, worked flawless and didn’t have to grab 3 diffrent pieces.. as far as the isolator,, do you have to use one? Nah… but with that car(or any Audi for that matter) keeping the factory charging system and your aftermarket charging system separate is just a safe call,, the car regulates voltage output post factory battery, so the less you mess with its resting voltage the less likely your going to run into issues… rofl, if you thought the Mercedes was a fickle pos wait till you start playing with Audis electrical yeah, I tell anyone that get into Audi or and VW product the first purchase should be a Vag-com or what ever it’s called now, lol it’s saved me thousands of dollars in Repairs and trouble shooting.. and being able to adapt and reprogram with it is just awesome.. you can unlock a ton features in your car with it as well
  24. bigrank916
    Hell yeah man I appreciate the help. What are the reasons that led you to use the WavTech over the Audiocontrol units? I don't have any brand specific needs for this build with the equipment that I need to buy. I just want to make sure I understand why and that it works w/o issues . My first question would be, shouldn't I get the Link 8 so I can use all the factory door speakers? Then also get a Link2 for the sub? I guess the same basic plan I had for using LOCs except not Audiocontrol. The link 6 would leave me short one channel of input right? Oh shit that CAN word gives me nightmares from the old Merc. When you say stereo, you mean the stock amp right? I don't even think changing the head unit is an option. Or just replacing the speakers will throw codes? This is exactly what I need to avoid. I want to do this slowly and make sure everything stays the same. Just want crazy beat lol. This is actually my first newer car. I plan on having it at least 5 years so I'm gonna do this right the first time. Ok so just changing the battery will throw codes? I see this vagcom is a software to buy. They had to change the name cause of copyright. Did they not think that was taken yet?? Sounds like something I could use in other areas for the car as well. Well damn ok this is all great info! I have a battery isolator but would love to hear your input on why I should use it. I don't really listen to music with the car off but its prob for another reason I'm assuming. Hell I'd just buy what you tell me to get if you have already done this in a similar Audi before. Not too much info out there for what I'm trying to do. I usually depend on Yt videos but they all seem to be the same stuff.
  25. bigrank916
    I'm right there with ya! I can't wait to have some real beat again. It's been way too many years.
  26. Chapter2
    If it was me,I’m accually working on an Audi now, Id skip the audiocontrol and use the WavTech Link 6(it’ll give you everything you need)…remove the factory amps and wire in from there, the CAN system on those cars are a nitemare and will pick up that something has been added into the system IF you replace the stereo your car will throw codes ,also look at getting your self a Vagcom as you will have to marry/adapt your battery to the car and you can correct the codes .. or you’ll get early replacement warnings.. also possible consider isolating your rear battery from the front, if you have and specific questions feel free to hit me up I’ll help where I can
  27. Aaron Clinton
    Looking forward to this build!!
  28. jcarter1885
    That's the route I went and love mine, took the weight out of my trunk by removing the group 31 battery, and my voltage doesn't drop as much plus it looks cleaner than having that huge battery back there.
  1. Load more activity
