341 -
Content Type
Profiles
Forums
Gallery
Everything posted by jj1479
MechMan Alternators Any problems?
jj1479 replied to jj1479's topic in Amplifiers / Head Units / Processors / Electrical
Yes I think I'll go with a Mechman. I have emailed them and Eric has returned all of my emails and the build time is alot faster then the others that i have emailed/looked at. As for Dc power they have yet to email me back and Excessive amperage can only make me a 250 amp unit thats alot more money then what the mechman 270a unit costs. Also I see that Mechman has a limited time deal if you spend over $300 you get free shipping and a free t-shirt Me likey free stuff -
He will Fi has excellent customer service.
Email nick nick@fiaudio.com
Hi there, I am sorry but i dont know where you heard this from, we dont do that We only ask some basics questions about you and if you know what you dealing with because there is a lot of high school students on this the forums and they think they know how to build a big system For the 45k2d of course we going to ask you some questions, THE QUESTIONS IS TO HELP YOU SO YOU DONT HAVE ANY PROBLEMS If you have the money and wanna buy the equipment we will sell to you, we try to help before selling the equipment so we dont get a bad reputation from bad installations Did you know the 45k2d is a 240volts amplifier ?? no a lot of people know who to install a 240volts amplifier and not even know how to use the power Im not pointing anything, i dont know you maybe you are a guru on car audio but im just want to be clear about us picking who uses our equipment There is no such thing Wouldn't happen to have any pictures of that beast would you????
Pop out the Little round plastic tabs outer/inner and it should lift up.
Damn that sucks. Have to pull everything out through the back seat due to the trunk?
I assume that you are using a (L) port? Since you port lenght is 15" and the box stats says 12"? unless you front is 3" thick?
Looking nice. Grill guard looks like it will do the job
Electrical Ignition fault in my car
jj1479 replied to shizzzon's topic in Automotive and Performance
Might be a long shoot but do you think that the plug for one of the computers for the car came lose from all of the bass shaking everything for long periods? Or the main fuse for the car in the fuse box under the hood might of worked lose. -
Need my amp fixed Memphis 16-MCD 25000
jj1479 replied to raolito1980's topic in Amplifiers / Head Units / Processors / Electrical
Try Steve @ ampmedics he will fix it. -
Anyone fix amps??
jj1479 replied to TheInfamousImpala's topic in Amplifiers / Head Units / Processors / Electrical
I think they only fix linear power amps don't they? -
Anyone fix amps??
Ampmedics Steve fixes alot of different brands and db-r sends him amps that they are to busy to fix. Does realy good work. Fixed 2 of my older Orion amps and my crossfire amp. Fast turnaround time -
Well decided to take my stuff out of my 09 Ford Escape and see how it sounds in my s10 for a couple of weeks. I Know the battery needs moved and its unsafe on top of the box but this was just a throw in setup to see how it sounds. It will be secured down tomorrow. The truck is only used to pull my kubota bx25 from job to job so it doesn't get used every day but have to have some kinda tunes. The only thing that i don't like is the subs are quad 1ohm coils but they read 1.2ohms and the final ohm load is 2.9-2.6ohms depending on the mm i used. So with out another battery and a bigger alternator they arn't getting all the amp has to offer but it does get LOUD System includes Pioneer DEH-7200HD deck Tc Sounds Axis subs Crossfire VR4000D amp Big 3 Knukoncepts 1/0 wire Kinetik KHC 2400 battery Box comes in around 6.4cf net tuned to 32hz I have a video we took today of it. The whole box moves and the battery bounces around. Will up load it later.
Ya I like the way they look but I liked the look of my tc 3000's better. They had the black baskets and the vents for the coils had wire mesh in them. The box was actually done for over a month now just didn't have time to put it in. I kinda feel down my hardwood steps on April 12th due too my wife using pledge on them and i twisted my hip and pulled the tendons real bad so i couldn't walk for awhile. But i couldn't wait any longer it had to go in.
At first when I had them in my escape I had them in the box that was built for the Fi Bls that I had an they honestly didn't sound good at all. But now that they are in a bigger box with alot more port they sound 100% better. BUT now I have a problem, their was a brace between the subs in the box that attached the front to the port and it just broke loose a couple of minutes ago so now i have to rip the seats back out and take the subs out to fix.
Little video we took today.
Don't have to worry about rock chips on the hood
Was wondering if you guys are going to make a amp in the future thats full power (so to speak) at 2ohm instead of 1ohm? Instead of just linking 2 together
My problem is i have 2 subs with quad 1 ohm coils. So is it more exspensive to make one run at 2 ohm. I think the problem is having quad 1 ohm coils. There's no reason to have a quad coil sub unless you plan on running 8 amps to it. Well they don't make the sub that i wanted with any other coil options so thats what i had to go with. Have you tested efficiency at different loads before? I've tested Class D's that are more efficient at lower impedance than higher, until below rated, then it just goes to hell. It's all subject to the components used.
Is your line out converter set? As in did you adjust the level settings on it? On my stinger unit it has a ground wire that has to be hooked up for it to work.
As said several times before they don't give release dates. When they are availble they will be on their web site.
Who knows maybe he will keep that stuff longer then twisted keeps his stuff. Maybe twisted will help him.
Does it have alot of spider sag to it? If you look straight across the spider you can tell.That will change the reading of the coils No.. A coil has X feet of wire on it for a desired dcr. The only time you get added resistance is when you get a tinsel popping or a solder joint that is half melted from clipping the thing to death. Then why does the ohms change when you put pressure on the cone or set something light on it? Wouldn't that change what the amp See's as to a ohm load or doesn't it work like that? You are moving wire in a magnetic gap creating a field. So if the suspension is loose in his speaker and it does have minor sag that might be why he gets the 2.4 ohm reading?
