jj1479
Members
    341
Everything posted by jj1479
  1. jj1479
    daaaaamn
    Does it have alot of spider sag to it? If you look straight across the spider you can tell.That will change the reading of the coils No.. A coil has X feet of wire on it for a desired dcr. The only time you get added resistance is when you get a tinsel popping or a solder joint that is half melted from clipping the thing to death. Then why does the ohms change when you put pressure on the cone or set something light on it? Wouldn't that change what the amp see's as to a ohm load or doesn't it work like that?
  2. jj1479
    daaaaamn
  3. jj1479
    2ohm load amp
    Around the same output as my crossfire vr4000d. Now theirs nothing wrong with my vr but i would like to try a sundown amp.
  4. jj1479
    question about build
    When i did mine i screwed 2x2s to the top of the sides (before putting the sides in) then slid the top on and glue/screwed up through the 2x2s into the top. Never had a problem that way excuse the noobish question but what is a 2x2? i will be running 3500, so using that tool will not be a good idea? 2"x2" wood like a 2x4 you can buy them at lowes/homedepot/84 lumber they come in several different lenghts just like regular 2x4s
  5. jj1479
  6. If you read my other posts I'm not gluing it. They are being sent back to Tc sounds.
  7. Well guys maybe one of you can help me out. I have/had in my SUV a Tc sound axis 12 and was playing it on my orion 275rhcca amp at 1ohm and it was slammin UNTIL it started to rattle So after i removed it from the box i noticed that the whole spider assembly came unglued from the basket/spider landing . Now this is my question I'm sure that its covered under warranty but what are my chances of reglueing it my self? It's not about if i can do it but rather will it be worth it in the long run so to speak. I don't think it will be a problem aligning the coil as it seems to rest snugly in one spot where the LITTLE bit of glue originally was. I have a pair of them and I'm only using one at the moment so time of getting another one back from PE isn't a problem but I hate the hassle of sending shit back for warranty when something like this shouldn't of happened in the first place Also what type of glue? Simple 2part epxoy/jbweld? Anyways thanks in advanced,Joe
  8. Yep there should be ALOT of glue in there. One would think
  9. The ssf is set at 30hz same as the box is tunned to thats also the first thing that i checked. I thought at first that i had it set lower. After talking with Thilo he assured me that they were some of the subs from a bad run that all had the same problem.
  10. They don't have dust caps its one solid cone.
  11. Bought them around 5 months ago. I bought the 12s and then the 15" top Assembly's so i can switch form the 12s to the 15s by just switching the tops. I had the 15s in my escape and took everything out to redo the box but never got around to it cause of the all of the snow so i just threw one of the 12s in for some tunes. Now this is the kicker, after i took the first one out and contacted kyle/thilo i put the 2nd 12 in and it didn't last 5 minutes and the same thing happened. Talked to thilo on the phone and he said that there was several from a run that had that problem and they thought that they had found them all. No problem tho they are being sent out and they are going to fix/replace them and refund all my $ for shipping. Shit happens i guess
  12. Ya I emailed Kyle from Tc sounds and he said just send it back an they will fix it if not they just ship me out another + reimburse my shipping. So thats not that bad.
  13. jj1479
    Is this a FI sponsored rock climber??
    Yep I've got an XJ on 35's with no lift Going to do a full width swap...arb lockers, probably 4.88's or 5.13's, exo cage...4 link rear on fox 2.0's, long arms on the front.. We like to play in the dirt How do you have 35' on a XJ without a lift?
  14. jj1479
    chevy s10 design
    this is what mine looked like in my 2003 from way back
  15. jj1479
    40.1 still around
    Was looking for something to replace my crossfire vr4000d. But i noticed the 40.1 isn't on their web site? Are they still making it or are they replacing it with something?
  16. jj1479
    40.1 still around
    I saw that earlier after i posted. Just was wondering if anyone knew why they took it off of their web site.
  17. jj1479
    Sub Comparison pics
    Thanks i just took the 15's out of my escape and I'm in the proses of putting them in my s10. Its alittle tricky building a box big enough for them with the space that i have and try to fit the box/battery's/amp.
  18. jj1479
    Sub Comparison pics
    what brand and model are those subs? I know there TC Sound drivers, look like the TC-Axis model. Ya they are the axis quad 1ohm
  19. jj1479
    Nope.
    Does the top assembly attach into the side of the motor or down into the top of the motor? Side view pic?
  20. jj1479
    Service after the sale?
    Did you email Nick? When I bought my BL 15s Nick answered all of my emails. Never had a problem.
  21. I called Alpine Tech dept and they said that you have to buy the KTX-H100 IMPRINT™ Sound Manager Kit ($30) and the PXA-H100 IMPRINT audio processor($120). Once hooked up you have to take several measurements throughout out your car and once uploaded into the radio it will unlock the MultEQ setting. Seems like alot of hassle and money ontop of what the deck already cost just for the bass/treble button.
  22. My CDA-9887 is the same I've tried and i can't find the bass/treble controls either. I see in my book that it says "Depending on the connected devices, some functions and display indications do not work" I have Sirius/Ipod/CD changer and my PAC Audio steering wheel control adapter hooked up but i unplugged everything including my rca's for my sub amp and still no basss/treble controls. Even turned off the sub woofer control and nothing.
  23. jj1479
    Featured Customer video - zZZzzzSnooze2nd
    Anyone know the name/artist of the song?
  24. Anyone else here about DD making a new Z with a 6" coil on something bigger than a 18" Or is it just a fake video they are putting out? That neo magnet is HUGE
