thor02
Members
    207
Everything posted by thor02
  1. thor02
    sundown nightshade hmmmmm
    I wasn't being hostile, at all. The baskets are completely different, and IA does not make Sundown woofers.
  2. thor02
    Why does it matter if they look alike? How they look and how they perform are two non-related things.
  3. thor02
    Need info for setting Amp Adjustments
    I assume your box is sealed since it's 1 ft3? If that's the case then leave the subsonic filter at 0. For the low pass, put it at approximately 80 hz (it's really personal preference so just play with it a little bit to get it how you like it. 80 hz is just a general starting point).
  4. Yeah sorry i wasn't really thinking about how much power you wanted. Strapping a couple of AQ 2200's would be a good option.
  5. If you have the money, the Rockford 2500 constant power sounds good for your application. It has roughly the same output from 1 to 4 ohms.
  6. OP, at this point in time i would be careful about Stetsom. Lately, I have read numerous threads about people not getting their stuff for months, even when they paid $200 for express shipping. Not bashing them by any means, nor do i have anything against them, I'm just putting other people's experiences out there.
  7. thor02
    Help?
    Use photobucket.
  8. thor02
    pics from Kicker Bash 2011
    That lambo reminds me of dumb and dumber!
  9. If there's no way to do a traditional port, i'm thinking a clamshell design could work. Just throwing that out there.
  10. thor02
    First set up sub suggestions
    I like the idea of two SA-12's on the SAX-1200d or an SA-15 on a SAZ-1000d.
  11. thor02
    And I thought AQ would be good
    What's your box tuned to? The subsonic filter should be approximately 2-3 hz below your box tuning.
  12. thor02
    Can someone from DC Power Contact ME!!!!
    Wow those came out great!
  13. thor02
    Hmmm, i'm waiting for more excuses!
  14. thor02
    Yes i am a noob
    Welcome! You will learn a ton of good info on here!
  15. thor02
    Trunk Car-Optimal Setup
    If it's not sealed from the trunk, it's not worth it. I have tried it and from what i experienced, i had a peakier response and i lost loudness. Yes you do lose most of the trunk rattle, but it wasn't worth it in my mind. I am curious to how it would perform if i did seal it off though...
  16. thor02
    Port Area
  17. thor02
    45's in port of sub box
    As long as you're happy with it, it's not worth your time unless you are hearing a significant amount of port noise.
  18. thor02
    Peel and Seal?
    Did you not see what happened to SteveMead? That so-called "rubberized compound" was melting in his doors, so it's OBVIOUSLY not butyl, so it has to be asphalt.
  19. The diagram shown will give you a 2 ohm nominal load for a 4 ohm dvc sub, so that's correct. You really shouldn't worry about keeping the gain down, as even decent subs should be able to take more than what they are rated for (as long as the signal given to them is clean). Plus having the headroom is nice!
  20. More cone area usually rules over power. BUT, depends upon the power and cone area difference.
  21. thor02
    Kevin S
    I just spent 10 minutes reading through this thing, and i just wish you the best of luck on getting your money back. Personally, i would never deal with even slightly shady people, and situations like this reinforce my point of view.
  22. thor02
    Welcome to the IHoP
    Damn man.........never a fun drive. J Right. I was so thankful that i got home safely.
  23. thor02
    Welcome to the IHoP
    Blizzard conditions! 40-45 mph winds with 55 mph gusts, white-out conditions basically. Had to drive 10 mph with my head out of the window and look straight down just to see the yellow line in the bad spots! Twas ugly.
  24. thor02
    Welcome to the IHoP
    Just drove in by far the worst conditions i have ever driven in.
  25. thor02
    SICKEST SET-UP EVER!!!!!!!!! NASTY
    Dude, chill. The man thought we would find this funny so he posted it, and it's pretty damn funny.
