thor02
Members
    207
Everything posted by thor02
  1. thor02
    18" btl n2, 15'' btl N2, 12'' btl N2, or 2 12'
    He is obviously using figures of speech so settle down people. What are your max dimensions of usable enclosure space?
  2. thor02
    what size aero port for fi bl 15??
    You will need/want more port area than that, just fyi.
  3. thor02
    My 1996 Cavy build
    Great Score!
  4. thor02
    Wood Splitting
    Phi, i agree with you. And seriously, it takes a minute to put some screws in the baffle. I would way rather do that than worrying about the dry time for the glue.
  5. Mines copper. He is looking for cheap. Want me to send you a sample All of the bullz 1/0 on ebay is cca. I wouldn't doubt that they do make copper. OP, wire is not gonna make or break your system. Just get whatever can handle the current you will be pushing through it.
  6. thor02
    Opinions for SQ setup
    For true sq, the subwoofer is not nearly as important as the front stage. Do you have any fiberglassing skills?
  7. thor02
    SQ is the best possible reproduction of the original music. You want it to sound like you're listening to the band/group live right in front of you on a stage.
  8. thor02
    How is Fi pronounced?
    Refrain from licking the windows on your bus ride home
  9. Pretty sure this bullz audio wire is cheap, which means it's not copper wire. It even says it in the ebay description. The jacket thickness varies a lot and is very thick, which tells me right away that this is cheap wire.
  10. thor02
    I believe it's "fye" like "pi"
  11. thor02
    Overcurrent
    What is your voltage in these instances?
  12. thor02
    would I be downgrading?
    I think the two SA-12's would have more output. Could you post the specs of the box for your Q and your planned box?
  13. thor02
    Guy From CA.com
    Welcome!
  14. thor02
    BTL Trouble
    What electrical did you have to support that AQ?
  15. thor02
    houston newb
    Welcome dude. One of the best places to start learning!
  16. I just installed a Deka under the hood and it works very well (replaced the stock). I am drawing approximately 120 amps from it and voltage drop is less than 1.5 volts at full tilt, with no other electrical upgrades besides the big 3. I can't compare it to other company's products, but i am impressed by the performance for the price!
  17. thor02
    Welcome to the IHoP
    Went to the Osaka restaurant in Minneapolis last night. All i can say is wow, what an experience!
  18. thor02
    what amp?
    Why would you do two different sizes, then make them the same later?
  19. thor02
    Port area for 15" BTL
    Anywhere from 12-16 is good, depending on your desired tuning. Less port area=lower tuning, with 12" per cube being on the low end.
  20. Contacting sundown would be your best bet. I'm sure Jacob could help you out.
  21. Bass knobs don't hurt, they just let you control the level of output of your amp. So in a way they are actually safer to use, and are more convenient than messing with settings on the head unit. If bass knobs are bad, then why do most, if not all leading manufacturers supply a bass knob with each amp?
  22. Audioque makes great amps, maybe the best for your money. Their 2200 is $389 straight from the manufacturer. Other good amp companies: Sundown Incriminator Rockford Fosgate (be aware that their amps have a set subsonic filter) Digital Designs DC Audio About all i can think of right now.
  23. There are much better options out there if you have the money. What is your budget? Or are you stuck on hifonics?
  24. thor02
    Need your vote!
    Voted!
  25. thor02
    Welcome to the IHoP
    Supposed to get down to a balmy -20F with a wind chill of -37F tonight.
