3,729 -
Days Won
26
Posts posted by edouble101
I have been using the Markaudio Alpair-7-Grey Cone 4" Full Range for over a year now. They are hands down very transparent and extremely capable. Over the years I used and tested +20 full range drivers and these sound the best to my ears. Currently, they are mounted in pods on my dash corners. When the music starts playing they simply disappear.
The only driver on your list that is the most comparable is the Tang Band w4-1337sd. Unfortunately, the Tang Band w4-1337sd are HUGE!! Top end "sparkle" is much more present with the Markaudio Alpair-7-Grey Cone 4" Full Range.
Other than the Markaudio Alpair-7-Grey Cone 4" Full Range I wold recommend the FaitalPRO 3FE22. The 3FE22 are probably the most underrated midrange IMO. Very neutral sounding like the Markaudio Alpair-7-Grey Cone 4" Full Range and Tang Band w4-1337sd.
I recommend the Markaudio Alpair-7-Grey Cone 4" Full Range, runner up the FaitalPRO 3FE22.
0 -
Yes sir
0 -
14 hours ago, Tirefryr said:I hate to ask, but are you interested in any type of trades?
No thanks.
I am closing this thread. They are being sold on Ebay.
0 -
Last attempt to sell these on online forums.
$650 shipped for both units.
0 -
15 hours ago, Notorious97200 said:Some news since november ?
How do you like your Evil sub ?
I ended up selling it before I used it
I started this thread too soon.
0 -
Selling on ebay
0 -
I am selling my Evil 15" d2. I've decided to build a drag racing car, all my money will be going into that instead of finishing my audio build.
I had the sub mounted but it it was never powered.
$500 shipped, no trades and I am not lowering the price.
20180127_124334 by edouble.photo, on Flickr
20180127_124445 by edouble.photo, on Flickr
20180127_124451 by edouble.photo, on Flickr
20180127_124352 by edouble.photo, on Flickr
1 -
This amp is going to power my Evil 15
2 -
On 12/1/2017 at 8:45 PM, j-roadtatts said:You know me better than that Eric.
0 -
You are using two different tweeters in the same install?
0 -
T1500-1 is SOLD
0 -
5 hours ago, Aaron Clinton said:She has personality to spare. Neal can speak from experience, as she is always high-energy, always intense, and always caring.
Well then, Dr. Lindsey will be a hit on youtube!
0 -
The best part of the video was all the kisses at the end, too cute. Is that always her mo?
0 -
4 hours ago, ManzKea said:Box specs the same?
Specs indicate that it should be comparable to the Evil.
1 -
Looks like a beast.
I was expecting the next wattage sub up from the Evil to be a neo sub
0 -
55 minutes ago, Thumpper said:I have to say these subs are sweet.... they
will hang against the W7 and WGTI for sound quality....
it's true Audiophile sub....not a sub for SPLers
Thanks for the review.
Are these now your reference subs for sound quality?
0 -
50 minutes ago, Aaron Clinton said:Only during their Black and Blue sale.
I forgot about the Black and Blue sale, thanks.
A 40.1 will have to hold me over until SSA releases Evil amps
2 -
Are you expecting a sale on Incriminator Audio amps?
0 -
I am selling my excellent condition Rockford Fosgate Power amplifiers. The T1500-1bdCP was from Rockford Fosgate, the T600-4 and T600-2 were bought from Crutchfield.
T1500-1bdCP - $400 shipped
T600-4 - $350 shipped
T600-2 - $350 shipped
T1500-1bdCP http://www.rockfordfosgate.com/products/details/t1500-1bdcp/
Number of Channels: 1 Rated Power: 1000W x 1 @ 4-Ohms RMS
1500W x 1 @ 2-Ohms RMS
1500W x 1 @ 1-Ohm RMSTotal Power: 1500 Watts Dynamic Power: 1320 Watts Bridgeable: No Efficiency (average): 86.2% @ 4-Ohm
74.6% @ 2-Ohm
63.0% @ 1-OhmCrossover Controls: Low-Pass (LP): 35-250Hz 24dB/octave Butterworth Tone Controls: Bass: 0dB to +18dB @ 45Hz
Infrasonic Filter: -3dB @ 28Hz 12dB/OctaveSignal Input: Low level: 1 RCA pair Signal Output: Low level: 1 RCA pair Power Input Connector: Block Power Wire Gauge: 4 AWG Speaker Output Connector: Screw terminal barrier strip Speaker Wire Gauge: 8 AWG to 18 AWG Heat Sink Type: Cast aluminum Cooling: Convection Remote Controls: Optional Remote Punch EQ (overrides built-in Punch EQ) Visual Indicators: Power
Thermal
ProtectCircuit Topology Class: Class bd Frequency Response: 20Hz to 250kHz +/- 0.5dB Shipping Weight: 14.35 Lbs. (6.50 Kg.) Dimensions (HxWxL): 2.14 x 8.14 x 14.91 (in)
5.42 x 20.68 x 37.86 (cm)T600-2 http://www.rockfordfosgate.com/products/details/t600-2/
Number of Channels: 2 Rated Power: 200W x 2 @ 4-Ohms RMS
300W x 2 @ 2-Ohms RMS
600W x 1 @ 4-Ohms bridged RMS
1-Ohm x 2 Stable
2-Ohm x 1 bridged StableTotal Power: 600 Watts Dynamic Power: 229 Watts x 2 @ 4-Ohms 0 degrees Res
369 Watts x 2 @ 2-Ohms 0 degrees ResBridgeable: Yes Efficiency (average): 71% @ 4-Ohm
68% @ 2-OhmCrossover Controls: High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Low-Pass (LP): 50-500Hz 24dB/octave ButterworthTone Controls: Treble: 0dB to +12dB @ 12kHz
Bass: 0dB to +18dB @ 45HzSignal Input: Low level: 1 RCA pair Signal Output: Low level: 1 RCA pair Power Input Connector: Block Power Wire Gauge: 4 AWG Speaker Output Connector: Screw terminal barrier strip Speaker Wire Gauge: 8 AWG to 18 AWG Heat Sink Type: Cast aluminum Cooling: Convection Remote Controls: Optional Remote Punch EQ (overrides built-in Punch EQ) Visual Indicators: Power
Thermal
ProtectCircuit Topology Class: Class A/B Frequency Response: 20Hz to 20kHz +/- 1dB Shipping Weight: 12.15 Lbs. (5.51 Kg.) Dimensions (HxWxL): 2.14 x 8.14 x 13.66 (in)
5.42 x 20.68 x 34.69 (cm)T600-4 http://www.rockfordfosgate.com/products/details/t600-4/
Number of Channels: 4 Rated Power: 100W x 4 @ 4-Ohms RMS
150W x 4 @ 2-Ohms RMS
300W x 2 @ 4-Ohms bridged RMS
2-Ohms x 2 bridged StableTotal Power: 600 Watts Dynamic Power: Front Channels
139 Watts x 2 @ 4-Ohms 0 degrees Res
236 Watts x 2 @ 2-Ohms 0 degrees Res
Rear Channels
140 Watts x 2 @ 4-Ohms 0 degrees Res
236 Watts x 2 @ 2-Ohms 0 degrees ResBridgeable: Yes Efficiency (average): 70% @ 4-Ohm
64% @ 2-OhmCrossover Controls: Front High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Front Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Rear High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Rear Low-Pass (LP): 50-500Hz 24dB/octave ButterworthTone Controls: Front Channels - Punch EQ
Rear Channels - Punch EQ
Bass: 0dB to +18dB @ 45HzSignal Input: Front Low level: 1 RCA pair
Rear Low level: 1 RCA pairSignal Output: Low Level: 1 RCA pair Power Input Connector: Block Power Wire Gauge: 4 AWG Speaker Output Connector: Screw terminal barrier strip Speaker Wire Gauge: 8 AWG to 18 AWG Heat Sink Type: Cast aluminum Cooling: Convection Remote Controls: Optional Remote Punch EQ (overrides built-in Punch EQ) Visual Indicators: Power
Thermal
ProtectCircuit Topology Class: Class A/B Frequency Response: 20Hz to 20kHz +/- 1dB Shipping Weight: 12.00 Lbs. (5.44 Kg.) Dimensions (HxWxL): 2.14 x 8.14 x 14.91 (in)
5.42 x 20.68 x 37.86 (cm)[
0 -
The evil sub is a bargain to start with. At these black Friday prices they are a steal!
2 -
15 hours ago, Mark LaFountain said:Looks great, glad you're happy with the sub so far. Can't wait for you to actually hear it though.
I can’t wait either. I should have my car back from the body shop Nov. 10th and I’ll have this installed shortly after.
0 -
3 hours ago, Travis said:Aww man. That's a bummer. But an awesome attempt nonetheless.
Every build is a learning experience!
0 -
2 hours ago, Aaron Clinton said:Sweet looking enclosure. I apologize for any delay, as we had a stretch there where we were understaffed and I was doing my best to keep up with everything I could. Looking forward to more info on your impressions.
No problems with me! I am pleased with SSA customer service, thank you for assisting.
0
Wideband/Full range speaker suggestions - A Pillars
in General Audio
I have them on-axis without tweeters, there is no need to have a tweeter with these drivers if mounted on-axis or close to it, on top of the dash/a-pillar.
