Joe Chen
Members
    21
Everything posted by Joe Chen
  1. Perhaps the amp is defective. Maybe that's why your sub blew out.
  2. Joe Chen
    sp4 dust cap warm
    Sounds like you're setting your gains too high or something. It should get warm when playing, but if it's hot to the point where you can't touch it.. something's wrong.
  3. Joe Chen
    SP4 RMS Change
    Did the guys at Fi re-evalutate the SP4 and change the RMS from 2500 to 3000 watts, or did they redesign it to increase RMS?
  4. Joe Chen
    SP4 Box Design
    I made this box not too long ago. Does it look fine to you guys?
  5. Joe Chen
    SP4 Box Design
    How come I've never thought of that... I'll see about it.
  6. Joe Chen
    SP4 Box Design
    I'll try, man.
  7. Joe Chen
    SP4 Box Design
    Well, that's out of my expertise, I'm just a novice box designer..
  8. Joe Chen
    SP4 Box Design
    sweet and if you add 2 inches on the height ??? would that work ?? Then I'd have to compensate for the extra box volume, lol. I think it'll be fine, a little less won't make it terrible.
  9. Joe Chen
    SP4 Box Design
    It should barely squeeze in, I checked.
  10. Joe Chen
    SP4 Box Design
    I need more space to fit the subs on top. If you're willing to sacrifice some port area though... Top/Bottom: 43x30 Side 1: 19.5x28.5 Side 2: 19.5x29225 Back: 19.5x43 Front: 19.5x36.25 Port: 19.5x14.25 Sub Hole: From the midpoint on the right side, 4.75 up, 10 inches to the left, center for first sub, then go 9.5 down and 16 left for center of hole 2. It'll kinda be a tight fit for the subs.
  11. Joe Chen
    SP4 Box Design
    No prob, so I can increase the depth then, right?
  12. Joe Chen
    SP4 Box Design
    I don't know about the middle port, probably not enough space to fit the port in. I can barely squeeze 2 18s in with this box alone!
  13. Joe Chen
    SP4 Box Design
    Got it. You don't mind if I make it longer? The subs will fit diagonally, as I'm designing it, but they wont fit unless I get it a bit wider..
  14. Joe Chen
    SP4 Box Design
    I've got an idea.... why not just place the port on bottom of the backside. That'll let us place the subs nicely on top.
  15. Joe Chen
    SP4 Box Design
    Double baffle? Edit: I honestly don't know if this is bad or just fine. But with the addition of the port, I managed to give your subs 5.5 cubes each, and your port is tuned to like 34 hz. If we add like 3 inches to your height, that'll solve the problem. How's this look?
  16. Joe Chen
    SP4 Box Design
    from TOP to BOTTOM 21 inches and from SIDE to SIDE 43 inches and from FRONT to BACK 30 inches how many CUBIC FEET is that ??? 13 cu ft.
  17. Joe Chen
    SP4 Box Design
    What do you want your dimensions to be? Any specific bracing that you might want?
  18. Joe Chen
    SP4 Box Design
    Yeah, unless you wanted a super quick sketch of a basic box, then I think it's best to go to a pro..
  19. Joe Chen
    SP4 Box Design
    Sketch?
  20. Joe Chen
    SP4 Box Design
    Are you sure? It's a few square inches below the minimum 12 sq in of port/cu ft though.
  21. I used Paypal as well, and Paypal shows the transaction as complete. It says the same thing on the site. I'm gonna be pissed to find out that my subs aren't coming for another few weeks..
