nadcicle
Members
    918
  • Days Won
    4
Everything posted by nadcicle
  1. nadcicle
    6 sp4 18s, 6th order, lots of glass and plexi
    yes its still gonna be a 6th but here in a few weeks when i nut up and spend the $240 on the aeros im gonna need lol Good deal! I know I put off my entire build because I needed the adjustability of Bill Lolo's pyschoports. Now I still have the enclosure, but I sold the subs. Now you really got my interest! lol Keep up the good work.
  2. I think the enclosure you're searching for is a well built parallel 6th ;P
  3. nadcicle
    Wait, so no more 6th? I was actually quite interested in seeing that pan out. Every time I turn around everyone is building what they call a 4th order lately, there are so few 6th orders that are successful it's eye opening when I see one it peaks my interests.
  4. nadcicle
    What sub is this?
    12" Fi BTL triple stack
  5. nadcicle
    My First And Only Tapout In 23 Years Of Being A Basshead
    This really puts things in to perspective on big builds! On one hand you got 2 heavy hitters Metts and Mick and both have done a mid to high 60 on the mic. Both had room to go here. I heard that Metts hit the park and pound up for the first time and got the second loudest score ever of a 139.1? I believe it was and Mick of course with his 142.1 or whatever it is he got. Both had room to go here as well. These guys are definitely on my bucket lists of people to get demos from.
  6. nadcicle
    SSA Team Sub???
    Friggin newbs, clearly you can't spot a sound quality vehicle when you see one. Sheesh!
  7. nadcicle
    SSA Team Sub???
    These are 1 offs though. Not in production unless someone has changed their minds.
  8. nadcicle
    What is clean Power?
    I've often looked at the THD and thought it meant nothing. There should be an "Audible distortion percentage" rating as well. 3000x1 @ 1ohm = Rated 75% before audible distortion 1500x1 @ 2ohm = Rated 83% before audible distortion 1000x1 @ 4ohm = Rated 92% before audible distortion But what is distortion at any ratings. Is it just noise from overvolted outputs? Could it be a squared off wave? We always argue here that power is power, but what does it mean to you that it makes your power clean vs distorted. For someone that doesn't care about a meter it might mean more to have the cleanest possible sound, but they likely won't need the most power. Would it benefit them to get a much larger amp that distorts much less at a higher ohm load vs a much higher quality amp that distorts about the same at a much lower ohm load?
  9. I second what Jay-cee said. Know reputable company with known good amps since power is power. At that point you can go with price/looks or even look further in to their customer service and see who is the happier customer for making the purchase.
  10. nadcicle
    sq of the judge
    FWIW, I would hardly consider the Judge to be an "SQ" sub at all. The sub was designed to exceed at a peak frequency. If you have the time you could in theory plug the T/S perimeters and see how much better/worse the sub could possibly do vs any well known SQ sub that was designed with frequency bandwidth in mind. Of course, it would take time as you would have to not try and be so subjective and would have to model a sealed, slot ported 4th, and etc. I have a couple wardens that i would hardly consider SQ, but they play the entire frequency bandwidth I need them to from extending lows 25hz up to punching bass around 60hz.
  11. nadcicle
    Team IAK IronMan Explorer
    Tell Smiley to get me 2 Ti baskets as well . Glad you got your subs man.
  12. nadcicle
    DONT BUY FROM ONLINECARSTEREO.COM
    They tried to bait-switch on me for an out of stock item. Then when I called they assured me I'd receive my money back withink 24-48 hours which didn't happen. Called back again and told them I was doing a chargeback and I immediately got my money back with them on the phone.
  13. nadcicle
    power issue
    Check your fuse from front to back as well as your grounds. Be best to check the voltage at the amp with a multimeter if you could spare 5 minutes.
  14. nadcicle
    4-18s DSS ethos on 12k
    What is the measured orientation of your organization? Sealed dash, driver door open outlaw, driver door open dash? Depending upon orientation I see your goal being extremely possible. I was simply pointing out your 2 largest set backs that you will have to build around extra well to overcome. Records were made to be broken and I want to see you do it!
  15. nadcicle
    Good luck with your goal! That has definitely got me interested.
  16. nadcicle
    three 15's or two 18's
    The Ethos gave a strong powerful low with a boomy throated bass while the sp4 gave a tight responsive and also powerful low, but punchy bass. The Sp4 would edge in a slightly pronounced top end while the Ethos powers through lows and definitely satisfies any thirst for bass. I wouldn't hesitate to recommend either for any time of build, but ultimately the choice lies in what you feel your overall build should sound like.
  17. nadcicle
    What orientation are you going with? What kind of tuning are you doing? I've had my fair chance at using both the ethos and Sp4. Either are good subs to go with. The Sp4's prefer a larger box, while the ethos like a smaller box with a much larger port.
  18. nadcicle
    CT Sounds
    Pass on it. Ran their 4k models and had nothing but issues with them and had to exercise their CS more than once. Pick you 5 different companies with models you might find within your needs. Look in to how well their CS is along with the quality of the product and base it off of that. Then compare with how much you are willing to spend and make your final purchase.
  19. nadcicle
    Super high output SQ oriented front stage
    My, how modest. We both know the good midbass drivers with any kind of xmax will usually model out with more than .75 cuft lol He isn't looking at midbasses with lots of xmax but something with output in the pro audio domain. That is a reasonable enclosre for an 8 and some 10's for the frequency range that will be necessary. Obviously bigger volume is not easier therefore outlining a minimum makes sense. Definitely NET btw, discussing Gross volume is idiotic and off topic always. Well, I must have missed where it said this "I'm trying to come up with an idea for front stage that can keep up with four eighteens and sound clean and crystal clear doing so. Imaging as accurate as possible." That is everything, but pro audio. You're becoming too lenient now days lol. I'd still say just build the door the best you possibly can because any "mid" you toss in there will be beating the crap out of the door playing anything below 200hz when trying to keep up with 4 18's.
  20. nadcicle
  21. nadcicle
    Dead 91 CRX si
    Better thank her this time of year bustin a knuckle is like death with the cold!
  22. nadcicle
    Dead 91 CRX si
    While the car likely has a few maintainence issues I'd focus on the most important things you've mentioned first like getting it to at least turn over. Others have mentioned tossing in a known good battery as it is the easiest way to tell if the issue is much larger. If you toss in a new battery I would check to see if this model didn't have a fusable link or the wire going directly from the battery to the starter isn't severed, check all fuses and triple check them again. It is not uncommon for these engines to get blow-back from failing pcv valves or even have a piston ring failure. Fixing other issues might not solve your largest issue which could be a dreaded locked up engine. Smells do help sometimes to determine failures of things. However, a clutch can smell like brakepads, and can even be a clutch master cylinder. I'd definitely work with what you have first before throwing money at it.
  23. nadcicle
    Whatever midbass/midrange you decide upon in your doors be prepared to really build your doors more solid. My 10's are beating the ever lastly piss out of my doors. I won't say that going to a 12 or 15 won't net you a louder response, but it will be much easier to build to a 10 and a single 10 can and will image great with a horn loaded drivers. Just look for a mid that stays relatively flat down to the 100hz range. You will not be playing anything SQ if you are to be playing 4 18's anywhere near their "potential" playing level though.lol
  24. You ever get around to playing with the 80prs? I got a chance to try out a minidsp vs my 80prs and the minidsp just is better. I wouldn't go crazy explaining why, but it just is.
  25. Perhaps I'm misunderstanding, but individual set point cutoff frequencies at your fingertips instead of using passive crossovers is EXACTLY what defines it being active. Sure, a sucks ass 5 band graphic eq can make the experience horrible or less than stellar is the wording I'd use, but I believe the dd has 13 which is OK along with a few Q points per band which gives it a sort of parametric "esque-ness" to it along with time alignment. I'm not saying any noob can make it sound good, but they do have enough there to make it possible. I'd much prefer to have a 32 band graphic+ or a 9 band parametric+ or even both, but I believe this is more than priced accordingly. If nitpicking how well of processing it has then eq's are much cheaper than a full dsp for running the active side of things.
