liljestrand
SSA Regular
    1,139
  • Days Won
    11
Everything posted by liljestrand
  1. liljestrand
    B2 tahoe
    Well since I've decided to move on from this build it was time to find a new project. So I give you the B2 tahoe.... But really thats all I have so far. The plan is to either move the xc's from the toaster into this and drop down to 4 15's no wall since thats the cone area limit for the class i plan to run. So: 4 15 b2 xc's 4 b2 m1s various b2 hn8's or hn6's and hntt tweeters. b2 quattro amps for highs. will be doing 4 alts but dunno on the amperage yet either 320's or 370's, and no clue on batts yet. and all sky high wire. got a few months before any shows so itll be a little bit before I update this. But I'm excited for the upcoming season.
  2. liljestrand
    B2 tahoe
    Sorry I havent been around. I have 0 45's in my box atm. I am actually in the process of building a new box and getting new amps. I built that box based on what someone had told me to without running the numbers on the box...basically it came out to like 10 cf with 20 sq in of port per cube tuned to almost 50. Needless to say it was no where near optimal. The new box should be more in line with what the subs need. 14 cf with 14.5 sq in port per cube tuned to 38. and honestly Im not that hard to find on facebook as there are not many liljestrands.
  3. liljestrand
    B2 tahoe
    From what i was told
  4. liljestrand
    B2 tahoe
    yeah we needed that lift bad. 480lbs in subs alone plus around 200 in wood. it was fun enough having to lift it up onto the lift to slide it around.
  5. liljestrand
    B2 tahoe
  6. liljestrand
    B2 tahoe
    its open on the backside so i can easily run wires out
  7. liljestrand
    B2 tahoe
    but before cutting anywhere around back there be extremely careful as the gas tank is awefully close to that spot...I had a friend drill through his trying to do this same thing
  8. liljestrand
    B2 tahoe
    the back seat. if i would have looked better underneath i could have picked a better spot. I think i went through a body mount there.
  9. liljestrand
    B2 tahoe
  10. liljestrand
    B2 tahoe
    Made a center console for the rear buckets to house the batteries. Also has a cupholder and a usb/lighter plug in. B2 hn6 pa mids and id horns.
  11. liljestrand
    B2 tahoe
  12. liljestrand
    B2 tahoe
    Iirc the zcon doesn't have a pole vent. So you should be perfectly fine.
  13. liljestrand
    B2 tahoe
    The sub was above the port wall. I could barely fit a finger underneath the motor. Thus the vent hole was covered up pretty good. To allow for better cooling I moved those subs back so there is a good 5 inches or so behind the motor
  14. liljestrand
    B2 tahoe
    Like Jay cee said I'll help out here as much aS I can
  15. liljestrand
    B2 tahoe
    What do you want to know.
  16. liljestrand
    B2 tahoe
    working on the cooling fans making a platform for the amps and a platform to raise the amps up to allow the fans below to breath so with the original baffle we ran into 2 problems, 1 I accidently cut the speaker cut outs a half inch too big and 2 the motors for the front subs was right above the port. So to alleviate that we centered the back 2 subs and moved the front 2 subs back. also we need an engine hoist to get this thing out and thats without subs. thats about all i have for updates. will hopefully be able to get more into this in the coming weeks.
  17. liljestrand
    how hernia's are made... AA smd V2
    A 110lb sub will give you a hernia? That's cute.
  18. liljestrand
    B2 tahoe
    I think it's just above window line Iirc. But it's under 25" which is what I need for suv for iasca
  19. liljestrand
    B2 tahoe
    Fairly cheap and easy. Cost about 15 bucks
  20. liljestrand
    B2 tahoe
  21. liljestrand
    B2 tahoe
  22. liljestrand
    B2 tahoe
    The rest of the goodies showed up
  23. liljestrand
    B2 tahoe
    Some goodies showed up. 3/0 electron beam and some 3/0 lugs. Xspower psc60 intellisupply charger and 4 mechman 370s ordered from ssa.
  24. liljestrand
    B2 tahoe
    Ah They are o on the site. Thank you
  25. liljestrand
    B2 tahoe
    x2c they are a limited run so they may not be on the site.
