Dangercdv
Members
    256
Everything posted by Dangercdv
  1. Dangercdv
    Advice for Ported Box
    It is a little on the larger side for the recommended 1.5-2 for ported, but that's awesome. I think I will be happy with this I hear that its best in an SUV to have the subs up, and port back. So this is what I got. look good?
  2. Dangercdv
    SA12 Dual Box
    From the album: Sub Box
  3. Dangercdv
    Total box outside dimensions. H=18 W=36.5 D=22 And the port is 5 x 15.75 and 42 inches deep. This is tuned around 31.5hz and leaves room for the subs. Thank you for the help
  4. Dangercdv
    Okay, I just made a model, the port being over 50 inches long takes away space needed for the subwoofers... this cant work in this size of a box. I will try to expand it later. I am going to try to expand the box a little where I can. Could I possibly lower the port to 5 inches? I know its 78.75 instead of the 80-90. Im looking for good SQ as well as some SPL, I dont want to blow the doors off without sounding good.
  5. Dangercdv
    Okay, so my new box L= 36 in. H= 18 in. D = 20 in. With a 5.25 x 15.75 port, I need over 50 inches of port length. That seems like its too much for a box of this size. If its right though I cant argue
  6. Dangercdv
    Okay, thank you. Il try making a box like that then.
  7. Dangercdv
    okay, that got me the cubic feet... I already knew my cubic feet, i was looking for the 80-90 in2 like you said. How much is 80-90 in2 in cubic feet. 85 in2 = how many cubic feet?
  8. Dangercdv
    I know what it means... I'm trying to find how much mine takes up now. 1.5 cubic feet = ??? In2
  9. Dangercdv
    well you said to use 80-90 in2 of port... i just want to know how many cubic feet that is. because right now my original design has .64 cubic feet, and the newer one i designed today uses 1.48 cubic feet.. I dont know how those numbers compare. I am about to leave the house, I will download it later tho and try to learn
  10. Dangercdv
    I had that once, didn't fully understand it. I'm afraid I won't know everything I'm looking at. Can I just get a conversion of 85 in2 to cubic feet? That will be my last question, with that I can build my box.
  11. Dangercdv
    okay, so im pretty bad at calculating that. I only know how to tell how many cubic feet I have. So can I convert that? How close was I on my last design? (Last post on first page)
  12. Dangercdv
    1500 RMS amplifier. Thank you for your help
  13. Dangercdv
    This is another design of the same box. SAME outside dimensions. Total volume = 5.333 (1 inch MDF) Port Volume = 1.37037 Tune = 31.5 hz I made the port 4 inches in width and raised the length to where I had it tuned around 31.5 - 31.6 hz. Its now 4 x 16 x 37
  14. Dangercdv
    Sub box, 4 inch port
  15. Dangercdv
    Okay, so if both SA12 and Gcon 12s are both bad ass subs, il probably stick with sundown then. So 2 SA12s, in that ported box. I will make another model of it tonight. How big of a port are we talking? I will also change the box dimensions to keep around 3-4 cubes of air because sundown recommends SA-12s get 1.5-2 cubes each.
  16. Dangercdv
    The 2 15 inch gcons sounds good. Won't I need a bigger box tho? As for the subs... I understand I need to pick, bit for this box, would sa12s or gcons sound better?
  17. Dangercdv
    Well yeah, of course I want it to sound good. I just want to be able to crank it up and get some good bass. Not competition or anything like that, but just some nice loud bass when I want it. I just want to know if this box is good to use?
  18. Dangercdv
    Sa-12s, or gcon 12s. Or possibly an xcon 15. Which ever is louder. This would be in the back of an SUV. Would the subs being on top be better? I could raise the height of the box and extend the port to what ever I need.
  19. Dangercdv
    Sub BOXX 2
  20. Dangercdv
    Sub BOXX
    4.69~ cubic feet of air. 0.64~ port area 5.33~ Total box airspace Tune = 31hz
  21. Dangercdv
    Best 10s for me?
    My friend has a small ported 10 on 250rms and its as loud as my two 10s sealed. He's ported at about 40hz tho. I'm going to try to get a box like that around 38hz at most. My best buy has something like it. I tested airflow of my ports and there's hardly anything coming out, and my friends box is pushing out a crazy ammount and still sounds good on moat music. I dont listen to anything to low anyway. 35hz is about as low as it gets
  22. Dangercdv
    Best 10s for me?
    Okay, im going to look for a prefab box thast ported. maybe the same size as my last box but a little wider with a port. ​can somebody recommend me a box? My current sealed boxes are H=13.5, W=14.5, D=11.5(at the top) 6(at the bottom) The ported box I need can be as big as H=13.5, W=16 D=12
  23. Dangercdv
    Best 10s for me?
    The person who built my box is a professional carpernter. He said he will be able to undo the glue, if the box won't be good enough with a slot port then I'm giving up until I get a new car. I will make a sketch of my box later today
  24. Dangercdv
    Best 10s for me?
    My box won't be to hard to take apart. I just need a design to use. I have the two boxes already, but I'm not good at doing slot ports for boxes so small
  25. Dangercdv
    Best 10s for me?
    I am going to use the 2 boxes I already have. Just replace the ports
