grumby13
Members-
382 -
Content Type
Profiles
Forums
Gallery
Everything posted by grumby13
electrical upgrade question
grumby13 replied to Will Harper's topic in Amplifiers / Head Units / Processors / Electrical
will replace it when i get the money but right now have to work with that i have -
but if im regulated by the pcm then i would not gain any additional voltage increase -
sorry for asking my question off yours but i might to a big three but was wondering if my original stock battery that is in the trunk be good enough after i do the big three. i have a 130amp alt with 95amps to play with after taking away the power need to run everything else or should i replace it i have an agm auto zone duralast platinum 34r up front but it bulgdes since i do not have a heatshield material to stop it from doing so. my setup is 2 pa mofo's 124x wired to 1 ohm and its being ran by a crescendo bc2000d. so will a big three be enough or should i do big 3 and a second agm in the back if a second agm in the back what should i add -
choosing an amp
grumby13 replied to grumby13's topic in Amplifiers / Head Units / Processors / Electrical
but im keeping the crescendo my old subs are going to someone elses car and i need to find one that can suit it well -
01 Grand Vitara charging question
grumby13 replied to Lee Carter's topic in Amplifiers / Head Units / Processors / Electrical
seems to me like the engine idle is to low for the alternator to keep everything running but 14.3 at first start up is normal since cold start up the voltage is high but at idle it should be 13.8. i would probable get a dmm and test the battery if the battery is at 13.8 when your readings are low then that means your voltage meter is off or the current that has to go through the pcm and all the other goodness to show what the voltage is at idle and a 2k rev. i would say get a friend to com over and have a dmm put the points up to the post when the engine is warm and your readings are low see if the battery voltage stays at 13.8 and then crank the system to its maximum playing volume before clipping and see what the drop is if the voltage drops alot from the dmm then that would mean you need a (more powerful) alternator then the stock output one but with 600 watts the dimming should not be noticed til you hit about 800 to 1k rms. but some vehicles lights are sensitive to and voltage drop that is greater then .3 but dimming can be noticed very well with a .5 drop but what else can help is upgrading the amp wire and amp ground might not be sufficent enough for the draw it requires. -
You going to the bear show gray
battery swollen
How Many layers should be needed to cover the battery for the heat shield material for the battery -
so i just replaced my battery two days ago and the battery is already swelling up the next day and today not much has changed. my first guess was heat and still might be, one other info is that the battery is loose not tied down since the bar or battery holding thing that goes across it was to tall to hold the battery in place. so the battery is loose and able to move should i get a new one and tie it down. this battery is the second one and if i replace it it will be the third one from them battery: duralast platinum 34r car toyota camry alt: 130amp from a 2003 highlander(original stock 80 amps)
battery swollen
I forgot to stop by Wal-Mart so I will do it tomorrow morning after work -
battery swollen
battery swollen
Will check Wal-Mart after work since that is the onlything open when I get off. But would a heat shield help as well -
battery swollen
I used a dmm and charge is 13.8 idle after a few minutes oh the engine getting a little warm and 14,2 at cold start but goes to about 13.4 to 13.5 at idle for an hour or so -
dB Drag US Audio, Glen Burnie,Md. October 13, 2013
grumby13 replied to ludeman's topic in Competitions & Other Organized SPL/SQ Events
we shall see what you can build in that time -
alternator rewind
The atm underthe hood keeps bulging and idk why but I have a hunch of either heat or voltage drop -
would anyone know how much more on average you can increase the output of a stock alternator just by doing a rewind. i added a second battery which is not much. the second battery is my old battery that is a stock from upfront in the engine bay. i have the 130amp alternator from a 2003 highlander, just need to get to 200A output but i know each alternator is different and will not be able to get much more out of it. thanks to all that can help me
alternator rewind
@DanP right now that is my only option since i do not want to put the old battery back since i have no idea how much longer it has. the battery is about 5 to 7 years old -
alternator rewind
i just added another battery and my vdrop is still high when i crank it up. i just installed the battery yesturday and so far the vdrop at normal volume and when i compete is about half to 75% of the vdrop. im assumption now is my alternator i have a bc200d wired to 1 ohm but have not calculated box rise yet since im missing some tools to do so. and with the stock alternator from a 03 highlander im left with 95 amps to play with but the amp at full tilt is 144amps draw. -
alright but the box will make it sound alot different.
alternator rewind
the one upfront is a agm a duralast platinum 34r and the one in the back or second one is an acid battery which is the old one i had upfront -
alternator rewind
dayum i just want to boost the output as much as i can but still be able to have it for a couple years i was asking about the diffference between the two -
i can't wait to see the box. i finally added a second battery -
can't wait to see this in bear
alternator rewind
im kinda on a really tight budget saving money on a house as well so have to balance spending and saving edit: is there a difference between rewind and rebuild -
oh i will make sure i can make this one and lude that little thing we were going to do we will have to change it for another time i added my old battery to the loop but not getting that loud til i can get my alt rewound to get a little more amperage -
There is a guy who plays 17hz very well
