ABXX49
SSA Regular
    2,256
  • Days Won
    1
Everything posted by ABXX49
  1. ABXX49
    fuse question
    How long is the wire you're fusing and what gauge is it?
  2. ABXX49
    Ryan J's build log
    I got the left side of the front done. I have to go to work now, but will finish the right side and the top panels tonight. Pics to come soon!
  3. ABXX49
    08 Dodge Ram 2500 Mega Diesel (Full Custom)
    Awesome install man! You've got talent!
  4. ABXX49
    Ryan J's build log
    Going to pull some old case fans and get my front panel done until my new fans come in.
  5. ABXX49
    I dont know if this is a big deal..
    You'll be fine. Assuming he didn't prod it hard enough to bend it..lol. Now had he done that while it was playing music, you could have rocked the coil and had some serious issues. **Take your hand on the cone and press down firmly enough to compress the suspension a LITTLE. Listed and see if you hear any rubbing sounds coming from the coil against the pole piece or magnet.
  6. ABXX49
    Chop's build log
    Looking good! You're going to be loud. Just out of curiosity, why did you end up using the PAP WMDS?
  7. ABXX49
    Another wiring info help
    Battery. Within the first 18" of wire, a fuse. Wire back to distro block. Fust IMMEDIATELY after the distro block. Then to the amps. You'll need 2 sets of RCA cables. You've got the right idea.
  8. ABXX49
    Ryan J's build log
    After those are glued down, I'm cutting a hole in the top large enough to put the amps in. Then I'm building another panel to cover that which will be held down with magnets. EDIT: Spelling error.
  9. ABXX49
    Ryan J's build log
    Note to all box builders: Never throw away your scraps! I've made this ENTIRE thing out of scraps I had left over from my entertainment center. The top, as seen above, is four separate pieces that are all cut to the same size. They'll be held down by Titebond and brad nails with a common support beam running all the way across the back on the bottom of the overhang.
  10. ABXX49
    Ryan J's build log
    Okay, got a little more done today. These pieces are NOT glued down. I need to wait for my fans before I glue anymore.
  11. ABXX49
    Ryan J's build log
    It might be tough to find one like mine used. Luckily, m5 had one used. I'll have reviews on EVERYTHING once the whole system is done.
  12. ABXX49
    Ryan J's build log
    I haven't. I need to get the floor done and the amps mounted first. I can't use those speakers without the amplifiers and I can't use the amplifiers with out the new HU it. And I can't have music until I have the amps in if I put the new HU in...lol So it's going to be a big all at once thing once the floor gets done.
  13. ABXX49
    Ryan J's build log
    Thanks Jay, I've been watching yours too! I've got some really neat stuff planned for this one, so make sure you don't turn your head!
  14. ABXX49
    Ryan J's build log
    Well the fans and magnets won't be here for 5-10 days, and I can't do anything until then.
  15. ABXX49
    Zed Goodness for the low
    Ugh. I want a Leviathon so bad..
  16. ABXX49
    Ryan J's build log
    **Just ordered some Neo magnets and 4 fans.
  17. ABXX49
    Ryan J's build log
    Okay, here is the start of my amp rack/false floor. Titebond, clamps, and brad nails. You need NOTHING more.
  18. ABXX49
    Ryan J's build log
    It's rough, like I said. I've already made a few changes in the first few steps
  19. ABXX49
    Ryan J's build log
    Started the false floor tonight. We'll see how far I get. I'll make sure I have pictures up tonight for you whores.
  20. ABXX49
    2001 Chevy Extreme Blazer
    Looks nice!
  21. ABXX49
    Looking for a good front stage
    You're probably not going to want to purchase prefab kick panels either. You'll want to glass them.
  22. How about taking your rears and moving them to the front on a custom baffle. That way you'll have the larger, louder speakers in the front and you can finally ditch the rears.
  23. ABXX49
    Ryan J's build log
    Here is a little Sketch-Up I did tonight. It's really rough, but it's the general idea of what I have planned. I want to hide my equipment as much as possible. I did a little thinking and searching and found a temperature controller for a PC that I'm going to wiring in with a relay. The holes in the front of the rack will house PC fans that will only run when it reaches a certain temperature.
  24. ABXX49
    Turbocharger
    I'd shy away from that one. If you want a quality unit, you'll have to pay for a quality unit. That's something you're not going to want to cheap out on.
  25. ABXX49
    J-Roadtatts Honda Accord Build
    Looking good man! Keep going strong!
