Kimberlee Padgett
Members
    53
Everything posted by Kimberlee Padgett
  1. Kimberlee Padgett
    Amazon - *PROMO INSIDE*
    Make the entire back of the enclosure acrylic plex glass is actually a name brand for cast acrylic predrill before u peel the protective paper off if possible . Apply foam tape to outer edge of box peel one side the tape it double sided tape so,both sides r sticky .after the tape applied to the box peel just the edge of the paper off the acrylic side that will be facing the inside of the box then peel the other side of the foam tape use the tape to secure the acrylic to the back of the box to predrill the box for the screws at this point the acrylic is already predrilled I'd start a screw at each Conor first then tighten the rest like u would a wheel on a car .so at this point the box is built with the entire back being acrylic peel the paper off the acrylic last it scratched very easy. Your trim panel that covers the screw holes makes the window like 2" border all the way around use the foam tape to attach the trim panel to the box . Hope this helps. Post pics when u complete please like to check it out
  2. Kimberlee Padgett
    Thanks appreciate it .I seal it with 3m foam tape and long screws predrill and hand tighten like a tire 1 screw here and there slowly tightening back and forth so not to fracture the acrylic minimum thickness ive used is 1/2" strong as hell when it etched or sand blasted larger logos looks spectacular when lit l also line the bottom of enclosure with plex mirror and paint the inside flat black .Yeah dude make one adds that wow factor when u show it off .All those builds were a sealed i dont really like how it looks with vented enclosuresWhat kind of screws? The regular ones you'd use to screw your boxes together Yea 2" wood screws lay tape around the edges where you are going to drill. The tape makes it less likley to fracture. Pre drill the acrylic with a bit levery 3-5" that the screw passes througs easily, you dont want to have to force the screws through the acrylic let the bit do the work steady speed light pressure , Countersink holes if u want trim panel sets flush if countersink holes if you have axcess to some gas welding equipment hydrogen and oxygen they make a real fine tip adjust to fine small flame u can go over the holes and rough edges the industry term is called flaming makes rough edges smooth and crystal clear also for structural use it seals the acrylic around the drilled holes its definitely not needed in this application unless u were edge lighting .sort of got off subject sorry . Get foam tape kinda like weather striping the pic of the sub box being assembled shows the 3m tape pre drill the wood and hand tighten or set the clutch on screw gun. Ive done lots of cool thinks with acrylic like this
  3. Kimberlee Padgett
    Not i sir if i don't know or not sure im not stupid enough to assume i do and go with or like u said refuse to accept im wrong no matter what This forum is the best for any info car audio besides the vendors being on here as well i dont get why people post asking for help because something went wrong with there system and debunk any info offered put aside your pride and learn something
  4. Kimberlee Padgett
    Absolutely agree totally i'll be the first to admit i had an idea where to set subsonic but to be sure i certainly did the research and still asked just to be sure
  5. Kimberlee Padgett
  6. Kimberlee Padgett
  7. Kimberlee Padgett
    Yep designed and built my me . Im lucky that i have a C N C at work my boss lets me use to build with here are some other pics
  8. Kimberlee Padgett
    Will be there this year again with soundqubed hdc315 see whad we can hit
  9. Kimberlee Padgett
    Term-lab Spring break nationals 2012 not pulling numbers out my ass if i was it would be something much higher considering we seen higher numbers with less equipment that day single cab f150 cut out bed
  10. Kimberlee Padgett
    Yeah them to RE SX12s hit 153 on music .Was asking about the Soundqubed amps was pondering getting the to match .Your setting sound like where i'd tune 80-125hz i think someone also mentioned sub sonic settings could cause it to sound funny Fi wanted to know what i had it set at, but no way in hell could that cause the coil shift.I certainty agree HDC4 is top dog you would think it would be bullet proof.Are you having the recone done or doing it yourself ? Where are you getting the recone kit? please let me know how that turns out if it does. Interested in recone the Fi Q with something else a lot of people recommend Psi recone for Fi subs also love to see pics of your install I hope the custom recone works out for ya keep us posted
  11. Kimberlee Padgett
    Yea I think I remember reading that post title something like hds415 to close to wall or something that the correct post ? Buy yea same exact high notes sounded absolutely awful down low couldn't really hear the noise when I removed the fi I could push on the cone in certain areas and it would feel like it was rubbing and other places it was smooth Suspension Did the Hds4 ever sound right or right out the box was making noise? What is your thoughts on the amps? I like to keep everything matching. What subs u plan on running now? I have 2 DC level 3 15 in my dodge ram I've heard DC played before but when I got them in hand wasn't to impressed that are rated at 900 rms and I s**t u not it seems like if I put 901watts it starts to rattle still hits but DQ drops drastically haven't had much time with soundqubed but the time I've had they r impressive I put the right up there with 06 Re Audio sx series these were some nasty subs took twice rated rms for 2 years hit 153.3 with a pair of 12s
  12. Kimberlee Padgett
    Fi did eventually did fix the Q but $400 for the sub initially $60 to ship back $100for recone then shipping back , that's a hefty bill.not to mention time factory It slammed and sounded good but was out preformed by a cadance S2 i still have the Fi the coil shifted again 4 months later. Anybody interested in a fi q12 just need recone kit LOL only kidding
  13. Kimberlee Padgett
    Where any of the enclosures actually built for the subs you had or are the specs just what someone told you? The enclosure speccs we supplied by Fi then laid out on castmate and calculated so they were right on spec pics above
  14. Kimberlee Padgett
    The Hds312 is in 2.25ft 35 hz prior post wanted to know what the fi q12 was in, 2.0 @38hz powered by a old school phoenix gold xenon 600.1( man I miss that amp) The top pic is the Hds210 in 1.25@38hz it rocks on just about the same power as the fi q the pretty much did the same as ManzKea started rattling had it looked at coil shift after of only 3-4 weeks of ownership
  15. Kimberlee Padgett
    Awesome we saw your order come through too! We will get it converted and hopefully shipped out today!Def share the install once you get it all buttoned up, would love to see it. Absolutely ,I have the HDS312 install almost finished in my 08 crossfire pic and complete review on your site and amazon as well .Your subs are specacular and the price (OMG) almost to good to be true. Previous sub Fi Q12 $350 plus (2012) slamed Soundqubed HDS312 $160 slams so much harder / better SQ also. I think more people not just hard core bass heads need to know you can get high end equipment at these prices (unbelievable !!) More orders from me real soonWish I had this experience Sorry to hear you didnt, may I ask what happened ? If you dont mind,. Soundqubed has been great to me as well as those I reasearch before buying Soundqubed products. Everything i've ordered was above expectations even the entry HDS210 .I did however have bad experiences with Fi And DC (not company bashing here) witch we know are far more expensive and in my case did the bear minimum to help when I paid $400 plus per sub, and then for to them tell me ship back a 45lbs sub on my dime and they would get around to in 4-8 weeks by the way to over a month to recieve sub ,played for about a month before issues started on an under powered (500 rms) Q12, now I can say the HDS210 is coming up on 1 month play time and seems to get louder and deeper every day as it breaks in this sub cost $95 shipped rated 600rms how can I not be overjoyed as my previous post (again not company bashing here) paid 4x the price For Q and had far far different experience
  16. Kimberlee Padgett
    Awesome we saw your order come through too! We will get it converted and hopefully shipped out today! Def share the install once you get it all buttoned up, would love to see it. Absolutely ,I have the HDS312 install almost finished in my 08 crossfire pic and complete review on your site and amazon as well .Your subs are specacular and the price (OMG) almost to good to be true. Previous sub Fi Q12 $350 plus (2012) slamed Soundqubed HDS312 $160 slams so much harder / better SQ also. I think more people not just hard core bass heads need to know you can get high end equipment at these prices (unbelievable !!) More orders from me real soon
  17. Kimberlee Padgett
    Cool appreciate the help it went through.Long story short I swayed my brother in law from DC Audio after he seen and heard my Hds312... I'm confident you will have a new quber for life after the hopefully 152+ dB these HDC3 should produce !!!!
  18. Kimberlee Padgett
    Sorry to be a pain this is amazons error messages " The promotional code you entered cannot be applied to your purchase."
  19. Kimberlee Padgett
    appreciate the quick response can you advise me on enclosure specs if u dont mind i searched your site didnt seem to find them. Thanks again
  20. Kimberlee Padgett
    Hey guys(soundqubed) looking to place an order for 2 hdc315 d2 can i use to use amazon 10% at soundqubed.com amazon says can not apply code?please advise thanks
  21. Kimberlee Padgett
    FI Q12
    Well said, I'll take of it myself save funds not having to ship that beast to them
  22. Kimberlee Padgett
    FI Q12
    What's up all I have a Fi Q12 that needs to be recone. I read you can use a different brand recone kit as long as specs are right? Or Is it better to use a Fi recone kit made for the Q12 from Fi or does another companies recone kit work just as well? I've never reconed a sub before and as long as the same specs are used to recone the sub everything remainds the same (rms power handling enclosure sizes ect.)? Appreciate any feedback thanks
  23. Kimberlee Padgett
    FI Q12
    Appreciate the quick repy I was thinking using the FI kit would be best. I've seen / read many recone step by step look pretty straight forward anybody done one on a Fi Q? Or better to ship to them ?
  24. Kimberlee Padgett
    Thanks for the awesome review! If you get a chance others would appreciate it posted on our site or amazon. Also, your promo pack is on its way! thanks for the promo pack appreciate it ordered a soundqubed hat just had to have 1 , put them decals to good use as well as the new home for the hds210.The hds312 will be installed first thing tomorrow .
  25. Kimberlee Padgett
    Absolutely will post review on both sites. Thanks in advance for the promo pack, what do you recommend for break in power and time running a hifonics x1500.1 rms @1ohm for the Hds312 and same for the Hds210 running phoenix gold xenon 600.1 Appreciate The Info A+ on an outstanding product
