669 -
Days Won
2
Posts posted by Punkeyboozter
I ran 2 bl 18's in an expedition for over 2 years off 2 sundown 1500d's strapped and then changed to a sundown 3500d. Then I have ran seems like everything since then so I figured why not go back to what I was happy with at firstJust curios, mind sharing what else you have used and how they compare in your opinion? I have a set of loaded 12 BL's and was contemplating in making them into 18's. Or just getting a BTL Neo.
0 -
I would start buy graphing different box sizes and tunings for each subwoofer to determine which enclosure parameters gives each sub their "optimal" response, then i would compare those drivers to each other in their graphed "optimal" enclosure. i put optimal in quotes because that is based on preference. The recommended enclosure specs are generic, you want to find those specifications that will net the results/response YOU want. Of course cabin gain plays a huge role so it might be necessary to build several boxes in order achieve the exact sound you want, but that depends on how particular you are.I would start buy graphing different box sizes and tunings for each subwoofer to determine which enclosure parameters gives each sub their "optimal" response, then i would compare those drivers to each other in their graphed "optimal" enclosure. i put optimal in quotes because that is based on preference. The recommended enclosure specs are generic, you want to find those specifications that will net the results/response YOU want. Of course cabin gain plays a huge role so it might be necessary to build several boxes in order achieve the exact sound you want, but that depends on how particular you are.Dont bother he already made up his mind. Something about a 6x9 with the tweets covered in masking tape.
0 -
serving spoon
0 -
Bob I am a smart-ass in case you didn't already realize.
Kang is not no-one he is a SSA member. That gives him brownie points.
0 -
Sub and port are both back already. I thought that was kinda obvious in the picture. You'd be surprised at the music that goes to 30 and lower too, LOL. Lot of rap these days seems to enjoy dipping down into the 20s.Yeah was meaning to say sub back port up in fact If I was you id sacrifice one of those rear seats as that opens a whole new world for you. I do understand that this is simply not a option for most people. With one seat down Ill do a a 18 4th order BP and with two seats down...well you get the point. (dreamz)
A box tuned to 32 will easily play a 30HZ or lower. If you set your infrasonic filter a wee bit below tuning before breakup becomes a problem you will be happy with it 99% of the time. I am not saying you should not do it. however in a car I will not tune lower then 30HZ personally. In fact these days I almost always go 32-35 for music.
Any how all the replies you see here will be options based on personal opinions. All you need to do is to pick one if you can not decide for yourself.
0 -
You could likely get 200 bucks for the W3. Try sub back port back. As for your options I say buy a Fi q and get a bigger deep-cycle. batt for the back. Do the Big 3 while you are at it and you should be good to go.
O and try to build the box your self
(design and build its not too hard)
...also your tuning is somewhat low. Try for around 32-35HZ for music honestly you will gain output and wont miss much at the bottom end.
0 -
Can we fix it?
0 -
Thanks.sweet
I want to be retired hitting a 162.9 hahahaLooks retired to me.you may need to its know that old folk cant hear that well.
0 -
The soft parts are the same for the most part, spiders are different now on the most recent versions. The motor/cooling technology is significantly different then the previous Q. It is simply a continuation in more advanced design that happens over a period of time .How can that be..? I thought the Q was the best and now its even better.
0 -
single woofer
0 -
Have you decided on what subs you will be using next?My guess is he will try some NEo;s
Maybe a 4th BP hey Big J?
1 -
no projector after all that work? I am disappointed.
0 -
I like that 4th order, id rotate to have the port firing down, raised up on some feet. thanks for the input!
yeah but its bets not to see the driver through the port in a 4th order BP
0 -
Strange didnt get post updates on this thread.
Any way send a reminder mail again.
Thanks
0 -
I say with 900 RMS you should be fine on a stock alt.
Do the big 3. Get a deepcycle BAtt upgront and dont play loud with your lights on.
get a voltmeter and take it from there.
0 -
Not sure if it has been mentioned since but Somewhere on Page 1 I read you ground to the sheet metal.
Try grounding to the frame instead. The easiest is ussually where your seatbelt is connected.
0 -
ok maybe ill send a mail again.
Thanks
0 -
Hope the Opp went well?>
Any one else that can process my order?
Thanks
0 -
Well thats unfortunate.
Would any one mind PM'ing me the office number? This order has been pending for a few months.
Thanks
0 -
i have replied to all emails up through the 4th of June.
Hi Shawn,
Looks like you missed my mail.
Last mail I send was on the Thursday, 31 May 2012, 21:56 (GMT +08:00)
Subject :
New Order (Shirts) Singapore
Thanks
0 -
Sounds like a plan to me.
0 -
Any update please?
Maybe you guys should considder using a resale partner? Parts express comes to mind.
Please reply my mail.
Thanks
0 -
Please check my mail and respond. Its the one that has been dragging for longer then I care to mention.
Thanks
0
LMB audio citroen C2 demo car 16 aa 10s, b2 audio front end (pic heavy
in Build Logs
wondering were the mids will go
