yukonblack
18 -
Posts posted by yukonblack
That is why I was asking this question. Lots of guys around me are advising against larger amps and going smaller for better efficiency. TFE look like a winner
0 -
280 and 340 mike singer units
0 -
Electrical will not be an issue. Dual alts and 14 batteries. I am trying to stay 12 volts for now. Investment to go 16 would be crazy with buying the amps.
Just wondering if efficiency will be better with smaller amps vs just 2 amps.
0 -
I thought about doing 3 tara amps 8ks as well.
0 -
I am in the middle of redoing mike singer's dora the explora(05 ford explorer). Subs have not been finalized yet. Tantric md 15, Sundown Sa-15, and American Bass XFL 15 are the front runners at this time. Original build was 12 XFL 15d4s on 3 ab 750.1s. He got 15k clamped and 160.9 at 47 out of it. I am trying to go with more 4th friendly subs and more efficient amp set up.
0 -
What would be the most efficient way to reach 15k rms?
Options are 2 Crossfire 8ks, 2 Ampere Audio 7.5s, or 2 Ampere Audio 8.0s
VS
6 Scv 3ks, 6 Skar 2500s, or 6 American Bass 175.1 VFLs
I will be powering 12 15s so I am looking to get around 13 to 15k rms. Cost wise 2 amps would be cheaper.
0 -
Build is already complete. Mike Singer designed and built it for xfls. Sealed section is only 1.25 cubes sealed per 15. The xfls worked well just trying to find a more 4th order friendly sub to help with efficiency. Build did a 160.9 on 15k clamped. Just trying to see if a more friendly sub will be better. I want to try and get my power down to around 12k.
0 -
Bandpass. Originally had xfl 15s. Looking at going to a more 4th friendly sub. I was almost set on sa's but decided to look for something different. Almost everyone with a 4th goes sa. They are proven, but I think the ssd deserves a shot.
0 -
Does anyone have the specs for a SSD 15 with the high QTS upgrade? I am looking to use some in a 4th order build and I am trying to model the subs.
0 -
Do you think its worth it to try that or just stay with 4 15s? I think the wow factor would be to keep the batteries and the amps were they are and still get enough space to run the 18's. I am not going for numbers just demos, but I would like to put up a decent number when I do meter. Legal I am at 150.7 at 43 hertz. I would love to get that up to 153 or so that is why I want the 18s. I don't think the 15s will be about to get there.
0 -
Thanks Mr. Jarrell for the response. Sencheezy (my local dss team member) informed me that it would be about 3 to 4 months on the wait for ethos. I would love to go with tridents, but budget does not allow at this moment. I think the ethos will be a major upgrade for a lightweight like myself to step up to a much better sub. I am currently running 6 american bass xfls.
Current box measures 48w x 30d x 22h. Absolute max is 53w x 45d x 22h to keep it below the window line. Max depth will be adjusted for space between port and rear hatch as needed.
Current box port is 12.5 inch octoport with 6 inches of space from port to tailgate. Port is 19 inches in length tuned to about 31 hertz.
Right now I have batteries and amps mounted in front of the box that takes up about 8 inches.
0 -
I have a 99 yukon denali (aka tahoe) that I want to upgrage to 4 dss ethos 18s. I currently have 6 xfl 12s on 7k in a 12.2 cube net box. I have about 7 inches of space between the port and the back door. Do you think I can get 4 18s in this space or should I stick with going 4 15s? Currently I have my batteries and 2 amps behind the back seats as well.
0 -
Sencheezy sent me here to have some fun!
0 -
I have been a lurker for around 2 years and figured it was time to join in on the fun.
0
15K rms 6 amps vs 2 amps
in Amplifiers / Head Units / Processors / Electrical
If I wire 3 of the hd8ks to 2 ohms each charging at 12.5 how reliable will they be? In the past it had 3 ab 750.1s it got 15k clamped, so I am looking for that same power this time around.
