AdamInPerth
10 -
Posts posted by AdamInPerth
C-DSP 6x8 is ordered.
I read the manual front to back before purchase. Seems fine.
1-4 tackled.
5 & 6 to go. Amps and Subs.
Sorry Notorious, missed your reply until after I posted this! I've lurked here for a long while, I take note of his replies
0 -
It's definitely a Caddy and not a Tundra.
1.4 Turbo Petrol has been turfed in favour of a Golf R 2.0 Turbo with DSG, LSD and a great deal of handling and cosmetic mods that required wiring and coding - factory LED headlights, electric Recaro seats, folding electric mirrors etc. I can put things together well - the factory Golf loom is spliced on to the Caddy loom before programming the computer.
Okay cool, thanks for the input so far.
- It sounds like I'll be buying the 8 ohm Evil 6.5s and tweeters which takes care of items #2 and #3.
- I've taken the point on having the subs located as far back as possible.
- I am fairly new to this, in a sense. Wiring up entire-home AV systems and making them all interlink and work optimally is within my abilities, so is wiring and programming custom ignition systems on motorbikes. If a mini-DSP is more complicated than that then I'm open to simpler suggestions.
0 -
2 hours ago, Tirefryr said:Do a test first. With the subs in the middle of the van you are likely to experience severe cancellation issues. You usually want tge drivers as far firward or rearward as possible.
Cheers for the interest!
Severe cancellation issues are something I'd very much like to avoid. I don't have any gear to use for testing but if putting the subs all the way at the back is the rule then I can build boxes above the wheel arches I guess. I'll go measure and see what depth that might allow.
Just before I go giving up on my hopes and dreams - do under seat subs always experience cancellation issues? These would be mounted low, angled upwards into the backs of the front seats.
0 -
Hi Everyone.
Newbie here with insufficient knowledge to make informed decisions.
I have a 2019 Volkswagen Caddy SWB van. Plenty of sound deadening and carpet to go in along with many mechanical and cosmetic modifications. Daily driver, sound quality bias, wide variety of music.
I’d like to keep the factory RCD330 head unit, put Evil 6.5”s and Evil tweeters in the factory locations, and have one or two 12” subs directly behind the front seats in what would be the rear passenger footwells. No plans for rear fill.
The Evils will fit – tweeters out front on top of the dash, 6.5s in the front lower corner of the doors. Might be able to position the tweeters in a pod on top of the dash, rather than keeping it under the VW dash grille.
A steel parcel shelf over the rear footwells is going to limit me to one 12” in a sealed box per side.
One sub is great. Two subs for not-much-more is also great if it passes the cost/benefit test - but it will need smaller footprint amps so I can hide them elsewhere now that the spare footwell is no longer spare to mount the amps.
So here’s where I ask you to help me make a shopping list.
- Line Out Converter – XPLOC or XFLOC
- Evil 6.5s – 4ohm or 8ohm
- Evil Tweeters - 4ohm or 8ohm
- miniDSP(s) – 2x4?
- 12” Icon(s) / Demon(s)
- Amps
All help appreciated. Thanks!
0 -
Luck. I was using Google for some stereo research and happened by the forum.
0 -
Hi Aaron,
Really struggling to give you guys money!
I've PMd you three times to confirm the order and also emailed Josh, all without answer. I even called the shop to leave a voicemail but the machine says it's full.
What's the issue please? Are we able to do business? I'm persisting because of your product reputation - but only just!
Thanks for your attention.
Adam
Australia
0 -
Message sent - thanks a million!
0 -
18 minutes ago, Aaron Clinton said:I replied to your email just the other day. Check your spam box, as many of mine seem to end up their lately.
Cheers for the comment Aaron. Negative on an email in the spam box though. I've been receiving them AOK from Josh up until the 4th and then nothing since. Happy to go with PM here if that's possible and easier for you guys?
0 -
Hi Folks,
Not having a lot of luck having my emails replied to. I'd like to buy some SSA subs, amps and speakers at these advertised prices. I'm in Australia and it seems easiest that I arrange the freight myself. If someone could get back to me with a best way to proceed that would be great. Thanks
0
Building a silly van.
in General Audio
I think I've decided on a single 12" ICON D2. If I'm right I can power that with a Class D amp at 1 ohm. Minimises space and power requirements, keeps the freight bill from the US to Australia down too.
So I'll pull the trigger on the 8ohm Evil 6.5s and tweeters, plus the ICON, then source some amps I guess. Maybe locally, maybe second hand. A Class D something-or-other that'll do 1500W+ at 1ohm and a quality 4ch A/B for the fronts.
