johnecon2001
SSA Regular
    5,305
  • Days Won
    6
Everything posted by johnecon2001
  1. johnecon2001
    8" mid-bass drivers to keep up with xcon
    Those are subwoofers... not midbass drivers Midbass is ment to blend with your front stage.. if you can't fit them in the doors, then you should make kick panels. Pick up these, Ascendant Audio 7" Carbons - SSA Car Audio Forum Cheap, good, reconeable seeing as how you blow things up often.
  2. johnecon2001
    SSD 18" sealed?
    They perform PERFECTLY FINE in a sealed box. Ported vs sealed is all user preference.
  3. johnecon2001
    Connection Problems
    Negative from battery to the amp is fine. That may be the lowest resistance option. Try hooking up a cd player or ipod to your amp and see if it exhibits the same behavior.
  4. johnecon2001
    Quick Wiring Question...
    Its the same thing..
  5. johnecon2001
    Fi BTL
    http://dictionary.reference.com/browse/what Seriously, it's W-H-A-T
  6. johnecon2001
    IA woofer spec sheet?
    C'mon.. there are box requirements stickied in this forum.
  7. johnecon2001
    Newly PSI Reconed DD 3500 18 value
    Less than a DD reconed 3500 would fetch. Find someone selling a used one of those and then ask 25% less.
  8. johnecon2001
    Oh YEAH, got my hands on the new Crown Finally!!!!
    Whats the price difference?
  9. johnecon2001
    DP 21" Daily?
    Stetsom V 1K5 H 1 Ohm - SSA STORE SSA SHop - Inciminator Audio 20.1 Amplifier
  10. johnecon2001
    DP 21" Daily?
    You've failed to mention a budget..
  11. johnecon2001
    4" midbass drivers
    Sure it can. It may not be as loud as a 6.5 or 8" woofer, but cone size does NOT dictate frequency ability.
  12. johnecon2001
    price
    tl;dr
  13. johnecon2001
    price
    Let me google that for you
  14. johnecon2001
    Details on AA subs?
    Idk Nick, Lord Aoshi sounds more credible than you.
  15. Do you have a budget for the receiver?
  16. johnecon2001
    Whats A Good Amp for 2 BL
    Good is quite subjective, but 1500w would be plenty for that setup. Did you have a budget at all? Hard to recommend anything else without knowing what you can spend.
  17. johnecon2001
    Project I'm Working On
    lol, you won't think so when you see it. Especially bolted to an 18" basket. Of course, motor size really means nothing over all.
  18. johnecon2001
    Speaker grill for a 12" Fi Q
    My favorite.
  19. johnecon2001
    hole in subwoofer
    Silicone caulk will do the trick. Obviously a recone will completely fix it, but the caulk will work fine.
  20. johnecon2001
    ALPINE IVA-W205 HU
    Seems an ok price, it's a couple of years old. I think I got mine in 2007 for $615.
  21. Pretty sure the Sonata doesn't have a factory amplifier...
  22. johnecon2001
    electrical issues
    Excessive has a forum that you could post in... Excessive Amperage - Realm of Excursion
  23. johnecon2001
    Worth getting another BTL 15" ?
    What are you running your current BTL at ohm wise on that amp? 1 ohm? You'll need to get a recone in order to run the amp at 1 ohm again.
  24. johnecon2001
    Win ISD parameters for BTL 15
    Nope its doing exactly what it's supposed to do. The BTL cannot be modeled in WinISD. You should be using the Fi Recommended enclosures in the Tech section instead.
  25. johnecon2001
    electrical issues
    Yeah BS on that. Excessive Amperage makes Civic alternators galore. So does Iraggi.
