12,015 -
Days Won
123
Content Type
Profiles
Forums
Gallery
Everything posted by jcarter1885
considering the performance of your batcap 2000, would you keep it or upgrade to something else(what would you upgrade to)?
Which battery woud you pick?
jcarter1885 replied to CrazyKenKid's topic in Amplifiers / Head Units / Processors / Electrical
I was in the same boat with you on trying to decide on what battery to run, two bat caps put out 50AH, 2000 CCA for $300. Lately I been thinking of getting two XS Power Batteries D2400 & D3100 for my system but today I spoke to a friend in Chicago who owns his own sound shop and stop selling Optima Batteries because price has been going up while quality is going done. Then he thought of Kinetik Batteries but wanted a battery with a less price tag for his customers so he told me about Shuriken Batteries which I been seing in local stereo shops here in Dallas, Fort Worth area. Basically their the same as Kinetik but cheaper, so I checked them out today and they just entered the car audio industry around 2007-2008 and where at CES 2009. Their only sold at a few places now sonicelectronix.com and a couple smaller companies on the internet, but fairly priced. Now Im looking at their BT-80 or BT-100(Starting) & BT-120(System), www.shurikenonline.com http://www.shurikenonline.com/brochure.pdf (2009 Brochure) Check them out, the BT-120 does 2600 CCA & 120 Ah for $270-300. -
The negative battery terminal. EDIT: I guess I should add that if your battery is in the trunk like mine the negative terminal is preferred. Ground it to the frame. So instead of my amps being ground to the metal block with a bolt and washer which attaches the back seat to the cars' frame, I should run a little longer ground wire (almost 1-2 feet more) to where my battery's negative post since my battery is in the trunk also. I thought longer ground wire may have more resistence but i may be wrong.
Stock Big Three Upgrade
jcarter1885 replied to jcarter1885's topic in Amplifiers / Head Units / Processors / Electrical
yeah i know that and appreciate your info, thats what Im upgrading my wires with Kicker 1/0 gauge. that still does not answer the questions i posted -
jcarter1885 posted a topic in Amplifiers / Head Units / Processors / Electrical
I have a 2003 Saturn Ion with a 2.2L Ecotech Engine with a stock 105A alternator, im trying to upgrade my big three but im running into obstacles so im coming here for some creative input. Yesterday I pulled the box out my trunk and finally took the spare out since its pointless in being under there and got to my starting battery (located in trunk where Saturn puts them). I completed the Big 1 so far using Kicker 1/0 Gauge ground wire and my voltage is outstanding so far when I idle I dont stay 14.0v to 14.1v (use to be 13.7v to 13.8v) when I crank my car im at 14.3v to 14.4v (use to be 14.0v to 14.1v in this Texas Summer Heat we been in the 100's last few days) and when music playing while on highway I sit at 13.8v to 14.0v depending on how much my air is blowing (use to be anywhere between 13.5v to 13.7v). I started looking under my hood to start on the ground for my alternator and its to tight of a fit for me to mess with so im going to take it to a shop so they can do it for me, then I noticed that I cant seem to find a ground wire leaving the alternator to engine block or frame of car maybe its on the rear side of alternator where I can see or get to with moving stuff around. So I found a shop who will assist me in grounding my alternator and one dude up there ask me why am I trying to do this since alternators are already mounted on engine blocks, then ask him if they will do it and how much then he points to the main dude who says yeah he will do it and understood why I wanted to do this. Ok... I just look a little harder and couldnt find a ground wire but there is an object that the ground wire that has a 10 wire going to it coming from under the engine block and it disappears not sure where its coming from and a 10 gauge wire to the engine block with a 4 gauge wire leaving the engine block to the frame. Question #1: What wire should I upgrade: just the 4 gauge itself to a kicker 1/0 gauge ground wire or find where the 10 gauge is going to and if its coming from the alternator ugrade that ground also. If I have to just upgrade the 4 gauge wire to 1/0 gauge I can do that myself. Question #2: The 4 gauge has a flange nut on top of the terminal ring with a flange nut under the terminal ring tighten to the frame and no paint is scatched off. I know I should scratch the paint off but wondering if I should keep the flange nut between the terminal ring and frame as Saturn grounded it or should take it away and just have the terminal ring touching the frame itself? -
Question #3: Where the 10 gauge and 4 gauge wire are grounded to the engine frame, they are seperated from the engine block with a flange nut like the question above: can I leave that nut their or should I take it off and have the terminals touching the frame itself? -
L.A. Sound 4 Channel Amplifier
jcarter1885 replied to tripslipfall's topic in Amplifiers / Head Units / Processors / Electrical
Yeah I found that page, I'm thinking it's 40 x 4 RMS, but somewhere else on the page it says 60 x 4, so I'll just have to try it and see, but all I know is it's probably much better than the built in amp in my Vr3 headunit (crap, I know, but it was free). yeah the manual and what the comany wrote for the specs on the amp were 60rms x 4 @ 4 ohms but after someone bench tested it they only got 40rms x 4 @ 4 ohm as the actual output power -
Best Deck For System
jcarter1885 replied to Hell-Razor's topic in Amplifiers / Head Units / Processors / Electrical
I would go with the second one(JVC) because Im thinking of getting one, but it has the highest preamp voltage and its the best quality. just my .02 -
Which amp for 10" Fi Bl?
jcarter1885 replied to 4X4AUTIGER's topic in Amplifiers / Head Units / Processors / Electrical
audioque 1200d -
i would of told him his system was real cute, keep up the good work on killing your subs for showing off
Amp For A Fi Bt 12"
jcarter1885 replied to sherwei's topic in Amplifiers / Head Units / Processors / Electrical
^^^^X2 or BL: Audioque 1200D or Kicker ZX1500.1 BTl: Audioque 2200D or Audioque 3500D (watch the gains) or Kicker ZX2500.1 -
starting battery upgrade and want opinions
no upgrded alternator yet but im in the process of looking for one for a 2003 saturn ion, the stock alternator is 105 amps. the starting battery is stock and i will be getting a xs power d2400 for my secondary battery for the 3000 watt rms system first and then change my starting battery. i wanted to know which one would be better just for starting purposes even though i know red tops are designed just for starting a vehicle best. i have researched and heard pros for a yellow and pros for a red, why would i want a yellowtop as a starting battery if i have a xs power battery in the back? -
i talked to mechman and he said making a alternator thats high output the same size as the stock one will eventually fail on me, im sorry but i take his word for it. why would he tell me not to get one or he wont even make me one if it wont help, im pretty sure he wouldnt turn my money down. i am going to get a xs power d2400(primary-stock) and d3100(secondary) and by a charger so i can charge them every few days or so; enabling me to help my charging system. I asked mechman would this be ok and he said yeah, we talked for almost 30 minutes trust me i went every route and found the advantages and disadvantages of having a high output alternator. If I felt like I really need one beside what he said to me I would pay $500 for a ho alternator but i feel safe after my conversation yesterday. -
i talked to mechman yesterday and they say that they dont make a high outout alternator for my car because its to tight of a fit for the regular alternator so making a bigger or custom one really isnt possible. so im just gonna run with a xs power d2400 and d3100 -
would like to get an answer to this so i can have further understanding -
i say go for it man, looking at all that space just made me jealous. what i would do to have all that room?
thats how i roll
I will be currently running around 3000 rms in a saturn ion with stock alternator (105 amps) until i find a high output alternator for my car. Right now i am planning on running 2 xstatic batcap 2000's(one as the primary batter and one as the secondary battery), i already know people are going to talk down on the 2000's so let me have it. what would be some good xs power battery choices. the primary battery opening is between 11-12"s and the secondary spot is under 11"s, my battery compartment is in my trunk and is exaclty the same as the one on this page just for a visual (http://www.saturnspot.com/f19/been-updating-system-again-29848.html). appreciate the help and opinions
bump -
Just the stock one and its not going below 12 even when im playing at idle. what upgrades do you plan on doing to your truck or are you gonna keep it as is, how did you like the performance of the batcap 2000
did you have a volt reader with you today when you were making videos, if so how was your voltage. that flex was incredible, looks like that xstatic is doing its job
QUestion #1-so correct me if im wrong and i know you guys will. my saturn ion has a 105 amp alternator and my system will be drawing somewhere close to 300Amps, so that totals up to around 405Amps. These are the three options of thinking of but correct me if im wrong (which is the best?): Option #1- Get two 200A alternators and a good starting battery. Option #2- Get the 200A alternator along with my 105A alternator thas in my car and a battery with 95(AH) or more to go with it. Option #3- Get a 200A alternator and two XS Power D2700(103 AH). Im just trying to make sure my electrical is sufficient and i understand the correct way to have enough electrical power to run my system without shotrtcuttin. Question #2- now here is where i get confused xs power says that D2400 will power a system with up to 4000watts if used as a secondary battery. So if i had a stock battery and a xspower d2400 i should be able to power my system with no upgrades to my stock battery or stock alternator. In acutuallity do you go by the watts of your system or do you add up the amp draw and try to even it with some beefy electrical? Is xsPower using this as a gimmick to purchase batteries? apprecaite the help and info -
1 ohm, 2ohm, 4ohm, WTF!
jcarter1885 replied to Kyleebbert's topic in Amplifiers / Head Units / Processors / Electrical
it doesnt matter what BL you get just make sure if you get a dual 1 ohm sub then you can wire it to 0.5 ohms or 2 ohms ; if you get a dual 2 ohm sub then you can wire it 1 ohm or 4 ohms. Once you figure out what sub your gonna get then you figure out how you want to wire it and what amp you need. For example if you get a dual 2 ohm subwoofer, you should wire it down to 1 ohm and then find you a 1 ohm stable amp that does rated rms as your subwoofer or a little more. -
hopefully in 15 days (give or take a little) i will be recieving my tracking number, june is almost ove with and i cant wait because lately i have noy been able to sleep with all this anticipation building up.
well i will have to wait till tomorrow once u test everything out to see if its the beast that the ceo or xstatic told me it was also
