jcarter1885
SSA Regular
    12,016
  • Days Won
    123
Everything posted by jcarter1885
  1. jcarter1885
    2021 Volkswagen Passat Rline
    Thanks man I appreciate it, this is by far my best enclosure and I freaking loved the all white one but it stood out way to much. This blends so much better and is just all around beautiful. I will be getting rid of that Odyssey AGM Group 31 battery and will be saving either 69 or 61 lbs. by switching to Lithium. The Odyssey weighs 77.8 lbs., each Lithium battery weighs 8 lbs. My box builder told me to start with one XS power Titan 8 as it is more powerful than both of my batteries (underhood and trunk). If I need more I'll upgrade to two in the future. My rear driver's side suspension will love me in the run with the weight reduction.
  2. jcarter1885
    Speaker connects outside the enclosure.
  3. jcarter1885
    It's hard to get good pictures with the trunk light because it's so damn bright, but in person it's perfect. The entire interior of the enclosure is covered in blue light. I'm glad I didnt pay for the LEDs I usually get installed in the enclosure because I never use them anyway. 20221104_115949.mp4
  4. jcarter1885
    Seat Leon 2007 build log
    looks dope and I love the progress so far. I can't wait to see this wall
  5. jcarter1885
    I will take some night shots one day soon, as much as I loved the white enclosure with the blue lights it stood out way too much at times. I didn't want it covered in bed liner again so I went back with the traditional carpet look and it came out fantastic.
  6. jcarter1885
    This enclosure turned out bad ass, I even had my builder make a matching beauty board to keep the enclosure in place.
  7. jcarter1885
    Some daytime pictures of the new voltmeter placement
  8. jcarter1885
    This light is so bright it's hard to get decent pictures with them on but it came out dope
  9. jcarter1885
    Had to clean up the wiring some since it's exposed but can barely be seen, separated power/ground from RCA signal wire. Y'all know I'm OCD about wire management especially if I can see it.
  10. jcarter1885
    Used this ammo to hold these volt meters in place while the double-sided tape adheres to the panels.
  11. jcarter1885
    Hole cut for cat-5 cord for Sundown bass knob/volt meter.
  12. jcarter1885
    Permanently mounted the cars' main voltage meter with double sided tape, looks damn good if you ask me.
  13. jcarter1885
    I needed to clear my mind so I worked on the car, got two things accomplished. I figured out how to remove this side panel to get access to my gear box area in my center console. I moved the USB cord coming from my radio from the passenger side where the shop installed it, to the driver side for ease of use. I also made a permanent spot for my car's main volt meter which monitors my up front voltage. I'm working on a spot for my Sundown amp bass knob/volt meter next. The volt meter will cover the factory USB port since it is no longer needed, hence why I drilled a hole in the housing to feed the wire. I'll use double sided tape to hold it down tomorrow once I clean the area with alcohol.
  14. jcarter1885
    I sure did look for some Xcon or Zcon 12s when I was buying subs, they were at the top of my list but no luck. Still mad I've never tried an Xcon till this day.
  15. jcarter1885
    This is how it looks now after the work I did earlier, I'm happy with the outcome.
  16. jcarter1885
    These next photos were before I put some work into the car because of my OCD, hated the excess wire I had goin into my DSP. So I untaped it and cut the three excess wires for a cleaner install. I also made the Sundown Salt-4k remote wire smaller since it the connectors on these Audio Control doesn't accept big gauge speaker wire well, especially with thick wire jackets.
  17. jcarter1885
    If I were competing then I would have but for daily I'll be ok with the D1s. But I appreciate ya though
  18. jcarter1885
    Thank you, I agree with you. Fi always makes beautiful subs
  19. jcarter1885
    Who would of thought that I would have twins, especially at 55lbs a piece. My trunk, suspension, sunroof and car in general are going to hate me.
  20. jcarter1885
    Ampere Audio Vibraflex , anyone do their roof ?
    I have a love hate relationship with installing sound dampening but it's so worth it at the end.
  21. jcarter1885
    new member
    can't wait for the build log man
  22. jcarter1885
    Time for a new substage, Dual 12s but which one's: Sundown Xv3s -or- Fi HCs
