307 -
Content Type
Profiles
Forums
Gallery
Everything posted by Spencerk
Ford MLA module??
Spencerk replied to Spencerk's topic in Amplifiers / Head Units / Processors / Electrical
OK now I feel f-en stupid thx you for the info guys and I will be picking up one of these two for voltage....plan on runnin a AQ2200D, I want to be able to be bumpin at a stop light in the summer with ac, fan on high, the wipers going and still hold 14.xx (like stock charging system) Can't you just get your alt set to 15.5v? That way depending on what all your running, even if it's drops a bit, everything's still being charged. I would like to have to option to set the voltage bc running a 12 volt bat at 15+ volt for extended amounts of time can cause damage to the batt. -
Omg its got a HEPA filter in port for air purification!!!!! I need one!
Ford MLA module??
OK now I feel f-en stupid thx you for the info guys and I will be picking up one of these two for voltage....plan on runnin a AQ2200D, I want to be able to be bumpin at a stop light in the summer with ac, fan on high, the wipers going and still hold 14.xx (like stock charging system) -
New Crescendo amps FTMFW!!!!!!!
Spencerk replied to edouble101's topic in Amplifiers / Head Units / Processors / Electrical
X2!!! -
ok so far I only got the cable guy that's gone into the 150s....anybody else?? I gota believe more ppl on here have done it too?
Ok well lets get right down to the grit of this issue... Tirefryr is right and wrong to some extent mostly right, wire is not just wire, when you are talking about a power supply of 5vdc @ 20ma max the right conductor is CRUCIAL. It may be the difference between having to go back to the R&D stage of a product or using what you have. That's the wrong, he is right about wire in the application of car audio. In the world of car audio we use current in such excessive amounts and use such short runs (relative to the total resistance of the conductor) that when your taking brand A compared to brand B the differences are all the way out to the 3rd and 4th decimal place resistance per foot....and unless they are using an O-scope to measure that you will never know, a typical fluke meter has a 1%+/-!!!!! Now for the stand count....... The idea behind the strand count is surface area, nothing more. Electrons flow from positive to negative over the surface of a conductor not though it. so the more strands you have in a conductor the more area you can generate in the same MCL or gauge of wire.
Well that scope is going to be your best friend for output, gain, and signal quality.....you are going to need some way to power them with the exact same source of power (that will be regulated at a specific voltage) Also how much power is the variable resistor good for and how low will it go??
HAAAA have you ever tried to get super user permissions on that thing???? it sucks..... terrible phone, shit for hardware and force closes the OS..... tried to overclock to 1.4 ghz, unstable, HOT temps, poor batt life, FAIL! Get the X way easy to hack (even though its the same OS) that way you can get all the cool features for free like wifi teather, plus NO MORE PAYING FOR INTERNET AT HOME!!!!!! EDIT: dint see this....@ Dutchie. they have the same processor speeds stock. and the X takes a far better picture, this is not opinion its fact. 8 meg pic will look worse on cell phone screen BC phone has to compress image to fit onto screen. Plus X can record 720 high def so he can record some sweet vids of his truck and put them on SSA!!!!! Took 30 seconds to root my captivate, had no problems OC'd at 1.2. Upgraded to 2.2 and took about 5 minutes with a different rom. The Galaxy phones will record 30 fps 720 as well. did you use easy root, with rom manager, and set CPU to OC what Rom are you Running right now......Running ballistic beast myself as of now
Basically anything and everything. You can install apps that were paid for(not by you) and they work. You can customize looks and boot. Best thing is tethering built into the ROM of the device. I currently own a Google Nexus One and cannot seem to find a reason to get a new phone. I don't have Verizon so I couldn't be bothered to fully look at the 2 comparisons you mentioned but you should definitely go for the smartphone with the highest frequency processor for smoother response. My brother has an Incredible and loves it though. I couldn't tell you for sure which is better but the Incredible is more hackable.. yep yep... I mainly only hack phones to get WIFI tether and over clock the processor just a touch (1.8ghz currently) as not to affect batt life and make the phone run smoother with no lag. you will also be able to customize EVERYTHING about the phone not just back grounds and themes..
MTX JH1200 Malfunctioning
Spencerk replied to laxer142142@yahoo.com's topic in Amplifiers / Head Units / Processors / Electrical
X2 on this ..... I think those amps have a solid state relay for the control circuit. SO you shouldn't me hearing any "clicks" when it comes on. -
likewise
I am looking at getting a decent setup for a bedroom. I don't want wires everywhere and space is an issue, so i was looking at a sound bar or the Bose 3-2-1 setup. Does anyone know if either of these are any good? I don't know much about home audio, any input is greatly appreciated.
i totally agree i was going to suggest to you to use a adapter plate and run a set of components.
need to know a little more about what you want.....you going to run a 4ch on them?? how much power are you going to put to them???? do you want SQ or midbass??? what do you want these to do that your current ones do not??
i also got a new toy...
From the album: the rocket
is that a glock 36?? the slim one??
What belt are you running with your HO alt?
Spencerk replied to mrbojang's topic in Amplifiers / Head Units / Processors / Electrical
gatorback, 1in shorter than stock
