dblovah51
20 -
Posts posted by dblovah51
my boy about to run 14v set up n couldnt find info for the 1100.4
0 -
he is trying to also do well on the meter for the trunk class category so tuning that low may make metering decent a bit more difficult to achieve, although i know tuning that sucka like you guys said at 30hz will be a pretty nice groundpounder.
0 -
Thanks, no problem will do
0 -
About to do a build for a 15" evil to ran by a AQ3500 I'm thinking about 4cubes and 65sq of port at 34-35hz. What's you guys take on that open to better suggestions.
0 -
i figured they would dropped in because the baskets are the same as, but was unsure of what happens in the gap. but thanks for the response.
0 -
no one?
0 -
hi i wanted to know if there is a downside to using an N2 recone on a ufo btl, because i have a friend with 2 recones and have no use for them and i needed recone. would they work?
0 -
They told me to contact demetric bond in NC to repair our 14k that's about 3 days old smh but so skeptical about where to send it because I've seen bad experience in repairs to a 11k those amps are PIA.
0 -
That's exactly what am sayin knowin that ppl run that as low as .25..but the coils are good the subs are BRAND NEW mayhem and each coils are readin the same,, a guy who repairs them said it could b a chip that's stuck so he ordered one to try that.
0 -
sure have no problem tryin it, but what's ur opinion if it stil does it at 4ohm which ill wire it to?
0 -
No we haven't even considering it bein that it won't b playing it at that ohm load
0 -
Was hopin someone like jefferson for stetsom would chime in...
0 -
Even when we connect a dual 2 mayhem to it it still protects as u begin to gain on the amp.
0 -
I think the amp was bein played on a low voltage battery bank and had no volt meter to identify the batteries was drained by a dead one, that caused the first failure.
0 -
6 kinetix 2400. 2 xs d3100.. ohio gen 180amp. It play for almost a year with out problems but after the fets went out and was repaired then came the protect issue..the voltage doesn't even drop below 13.8 before protection.
0 -
A friend of mine sent his 11k to get the mosfets replaced, it was repaired and sent back to him. And immediately he installed it and is now seein protection after we start to gain on the bass a little. It flashes once, which in the manual states low ohm and short circuit. Brand new mayhems @1ohm
0 -
hey troy i wanted to know if by any chance u have designed a dual kit for the 2004 4.2l trailblazer? my boy told me u did but am not sure if he had the right info brought to me!
0 -
I'm in the process of trying to decide between these 2 amps :
MTX TE1501D Elite $339
USAMPS MD-2D $319
The car will be a daily driver.
The subwoofer will be :
RE AUDIO 15" SEX
-or-
RE AUDIO 15" SX
I've heard the MD-2D isnt very clean, but I do love USAMPS from my expierence in the past they are GREAT amps, but for my pricerange these are the 2 amps im looking at. I have no expierence with MTX, so I ask you what is a better amp?
What are the Pros and Cons of both.
Also would a MD-2N be overkill for a 15" RE SXX? Would an MD-1DN do the job?
i say the mtx< those amps do put out more than rated, i have eve seen one of those amps put out 2k +
0 -
hey DB-R , we are playing with these too, it seems that alot of folks say they vary, also the end condition thingy weighs in on the math( wether you are shareing a enlosure wall with the port) the eqaution i copied down to find LV sems to be agreed on quite a bit, so i use the pencil paper and calculator method......
you are on the right track, well the same one i was on, perhaps the actual equation would be better for you also.
Where is this equation? Can you post me a link or post the equation? Thanks if you can! Forgive my ignorance, I do amps, not sub boxes, but I have in the past, but all sealed, so i am still "new" to vented boxes....
U CAN DO YOUR PORT AT 17.25 +5.25+19'' DEEP that should get u where u wanna be!
0
HDS300
in SoundQubed
These subs sounds amazing had them on a sq1200 for a few days and was amazed with the low end response. 7.6cb 120sq port
