liljestrand
15 bl fully loaded box help
got my sub couple of days ago and need a design. its going into a 99 cadillac escalade so theres plenty of room... can you guys help?? listen mostly to heavy rock and some rap.
Need some dimensions to work with...we can't take a stab in the dark
Thanks!
-Nick
This will work. Around 3.85 ft^3 tuned to 33 Hz. You could double the front baffle making the box 19.25" deep and get rid of the two small braces.
Edited by BKOLFO4
Looks like a solid design. Should work well for a daily setup.
If the above design doesnt meet your requirements, let me know and we can tweak things from there (thanks Brian)
hey just another quick question...how many sheets of mdf will this take 1-2. thanks
it will be close but should be just 1 sheet even with a double baffle for subs.
Depends on the way you cut the pieces you need out too.
MDF comes in 49" x 97" sheets.
so im trying to figure out what all to cut let me see if i got this right, i will go with the double baffle
box dimensions 19x34x18
(2) 18x16.5 for the sides
(1) 34x16.5 for the back
(2) 30.25x16.5 for the baffle
(1) 13.75x16.5 for one of the port sides
(1) 11x16.5 for the other port side
(1) 18x35.5 for the top and bottom
if i messed up somewhere let me know...i dont want to start cutting and mess it up when it doesnt fit
The overall dimensions I posted above are the outer dimensions. . .
If you are going to build as drawn with a double baffle (not sure why I said 19.25" deep above - should be 18.75), you would have:
(2) 18.75x16.5 for the sides
(1) 32.5x16.5 for the back
(2) 28.25x16.5 for the baffle
(1) 18.75x34 for the top and bottom
My bad again. . .
With double front baffle,
"(1) 13.75x16.5 for one of the port sides"
should be
"(1) 14.5x16.5 for one of the port sides"
since the box is now 18.75" deep.
Brian
good thing i got 2 sheets. ha ha ha thanks again...i cut it all this morning but that will be an easy piece
i had made this box and i had to cut 2 inches of the top for it to even fit in my trunk might be a dumb question but what is the cubic feet and the tunning im asking this cause i am now just sending my amp to get fixed cause it took me 2 months to contact the dealer who sold me this amp cause fosgate was wanting 200 to fix it and now all i gotta pay is shipping and i am just wanting to no the tuning so i no where to set my setting on my amp any ideas will help ooo and its a t1001bd thanks
