denalilvr
Mach5Audio MLI-65
hey guys the more i look at this lil thing the more i feel i want it..so i was wondering for component use..how does this speaker sound? also i was thinking of paring them with some tweeters and maybe a 4'' driver to make my own 3 ways sets..would this not be a good idea sound wise?
An excellent quality 6.5 inch bass-midrange that will work well in 2-way systems or MTM alignments. Also useful as a mini sub for small systems or computer setups. Use at home or in the car.
Power Handling: 100 watts RMS
Sensitivity: 89db (2.83 volts)
Impedance: 4 Ohm Nominal
Dimensions
Outside Diameter: 16.8cm (6 5/8")
Mounting Diameter: 15.3cm (6")
Depth: 6.7cm (2 5/8")
T/S parameters:
Fs = 62.2 Hz
Re = 3.4 Ohms[dc]
Qt = 0.61
Qes = 0.68
Qms = 5.69
Mms = 19.1 grams
Rms = 1.31 kg/s
Cms = 0.342 mm/N
Vas = 6.6 liters
Sd= 116.9 cm2
Xmax = 5.5 mm
Diameter = 12.2cm
Edited by denalilvr
In my application they are midbass monsters. These will be great for a 3-way and even a 2-way with a tweet that'll handle a low enough crossover point. I guarantee you if you buy them, it will be one of your best audio purchases.
Notice how it says good for 2-way systems? It won't function really well as a midbass unit.
Typically you want the driver size spacing a little further apart in a 3-way. 7-8" midbass, 3-4" midrange 1-2" tweet.
There are exceptions to the rule, but those are generalizations.
i was looking up tweeter and they are up to from $1200 to $30..lol whats a good set to go with..i dont want anything really harsh..
Madisound has been around a long time... :)
Check Fuzzypings topic in the classified section, great price on SEAS tweets.
these should go on sale again... *hint* *hint*
With price being extremly low for the performace, and the fact Mach5 is essentially breaking even on the driver...
$36 a piece and Shipping included in price (within North America)
For how they perform, I think it's a very good price.
People would want sales even if the item is for free :(
