USAMPFREAK
Kove Prototypes
Well due to everyone blowing me up here is a sneak preview and pricing just for SSA members. I will be selling these untill they are gone,
Everyone of these will have a 1 free recone warranty, but you must pay shipping to and from for the warranty.
12D2 or D4's 219.99
15D2 or D4's 249.99
18D2 or D4's 289.99
These are shipped prices to the continuous 48 states only. D2 or D4's
Edited by USAMPFREAK
Revc= 4.000 ohms
Levc= 1.33 mH
Fo= 24.684 Hz
Sd= 480 cm squared
Md= 114.000 g
BL= 19.709 TM
Qms= 1.979
Qes= 0.522
Qts= 0.413
No= 0.116%
SPLo= 13579.0
Vas= 41.598 Ltr
Cms= 127.147micro M/N
Mms= 326.975 g
Mmd 320.928 g
this is great, i ran kove in my old db drag truck, still got a pair of 15" U subs.
They just look like they are built better than some subs that can handle 1500 rms so I thought they should be able to handle around that much. But I guess looks do not matter that much, because based on the looks of the sub I would think it would be rated for 1000 RMS and actually be able to take 1500+ RMS. Based on the huge triple stacked motor that should allow for plenty of clearance for throw and it seems like the cooling is adequate to handle more power but that is based on looks. The motor could be weaker than it looks and the coil and suspension could be not as heavy duty as I would think they would be.
mind you the RE SE is a triple stack as well. I could be completely off base but the mag looks more similar to the SX then SE
Revc= 4.000 ohms
Levc= 1.33 mH
Fo= 24.684 Hz
Sd= 480 cm squared
Md= 114.000 g
BL= 19.709 TM
Qms= 1.979
Qes= 0.522
Qts= 0.413
No= 0.116%
SPLo= 13579.0
Vas= 41.598 Ltr
Mms= 326.975 g
Mmd 320.928 g
Which one are these specs for?
It's not about the size of the motor, it's about the size of the coil.
Where are they made?
I was told by David, formerly of RE audio, that the Vegas factory shut down in june. It is made in china like all the rest of RE audio and US amps products, right?
the vegas buildhouse did close. They are now located in cali. If they build woofers there i dont know, prior to the move the MT, and SX were built in the US with the re, sr and se in china
