Greg McCool
It looks so nice
Glad to see you switched amps now for the sub :P
The only way I would take out my X is when I find a woofer that has a bolt in cone and that is better than a X... So as of right now the X is where it's at for me!
I'm curious how you have that 3000D mounted to the box. I get nervous with my 1500D mounted to my dual RL-i8's enclosure. I can't imagine the vibration that 3000D must experience. Especially with the box bolted to your chassis.
I used rubber grommets between the 1500D and the mount points, just for a little bit of absorption. Are you using anything like that? I wouldn't mind finding something even more effective.
I have never had a problem mounting any amp to a sub box up to 160+ db. I hope I don't start having a problem....
Edited by Greg McCool
See you at SBN Greg I wont be competeing but Ill be there supporting every one
Sweet!
yep Ill be riding down with Tommy K and Hank
NICE!! more Sundown goodness!!
NSB 90 x2
1/0 ground for each NSB
1/0 lead to alt
make custom battery box x2
2 NSB 90 and some 1/0....
empty battery box
battery box..... but I only need 4in of it
The tray bolted in
finished with 1/0 ground, 1/0 power lead to ault and 1/0 run of ground to back NSB 90
OEM 1/0?
Back NSB 90
You would think it was made to come together...
I still have to tie in the back battery... I will do it tomorrow..
