kryptonitewhite
door hinge(es)? door popping against panels!
yesterday out of the blue my car door started popping while I open it, not as bad when i shut it. in front the body seam is right up against the door seam, so the door is sitting forward... pushed/bent toward the front of the car.
The rear seam is now a big gap.
I checked the hinges, they dont look bent or like they have any play.
top hinge
bottom hinge
sorry this camera blows
I tried lifting the end of the door, there is no play, and visually the black rubber/plastic bushings look OK... bolts tight....
looks like you pushed the door open to hard, one to many times. you usually see that when people have there door open in a parking lot and someone hits the door a little, or someone has there door open and backs up into something with there door.
the frame is probably bent a little where the hinges connect.
Edited by าชกุศล
I compared it to the other side to see if there was a gap between the hinge and where it mounts, but both sides look the same, and when I open both doors all the way, they seem to go the same
