Check out these other great forumsSoundSolutionsAudio.comAudioAddicts.netCarAudio-Forum.comCarAudioResources.comHomeAudioForum.net
Welcome to SSA Car Audio Forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
Just Arrived | The all new SSA GCON
Second Skin Audio, Now in the SSA Store!
Why "daily" systems should not count on impedance rise
  • Please log in to reply
54 replies to this topic
#1
sundownz
sundownz
    SSA Elite Level 2
  • Vendors
  • 7,927 posts
  • Gender:Male
I know it is said a 100 times a day... "with impedance rise you are going to be over 1 ohm anyway" when talking about a half ohm load or lower on a daily system.
Sure... if you constantly played individual sine waves one at a time. But, is that what music is?
http://www.audiograp...odamplifier.htm
Posted Image
"The upper graph illustrates the conventional way of measuring the loudspeaker impedance.
The lower graph illustrates the dynamical approach.
We took a commercial ’off-the shelf’ loudspeaker and did a standard impedance plot for it. We swept the frequency from 20 Hz to 20 kHz, measured the input voltage and current, and calculated the impedance.
However, instead of using a sine wave input signal, we used a square wave. The reason for this is that square waves consist of a large amount of sine waves, as does music. The square wave is of course not an equivalent of music, but for this test it was an easy way of showing that a complex signal (not just a simple sine wave signal) may make the load, from the amplifier point of view, very low.
If you study the graph resulting from the test, you will probably agree that not only is it necessary to check the amplifier’s behavior for resistive, capacitive and inductive loads – the amplifier should also be checked for loads with lower impedance than the nominal impedance of the loudspeaker.
This proves to be very important, since a loudspeaker with a nominal impedance of 4 ohms will sometimes have an actual impedance of 1 ohm or less. The PowerCube helps you perform testing of an amplifier, taking all these load attributes into consideration. "
Keep that in mind when you want to run your amplifier at a super low impedance "daily"
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Associate, Stereo Integrity
#2
sundownz
sundownz
    SSA Elite Level 2
  • Vendors
  • 7,927 posts
  • Gender:Male
QUESTION FROM "atsaubrey":
Since Sundowz brings up the issue, I would love to hear his take on low impedence loads period and how it effects things. Like, effciency, longevity, SQ, heat and electrical systems. I see it everyday on this forum, people asking can this or that amp run at .67 or .5 ohms although it is only rated at say 1ohm. Since the manufactuer stated the thread maybe people will listen. So Jake will you answer those questions? Jake at what impedence do you run your own personal gear at on a daily basis?
MY ANSWER:
If you look at a data sheet you can see that as a transistor gets hot it has a lower current rating... running an amp at a lower impedance increases the current passing through the transistors, heating them up, and progressively lowering their ability to handle the current until something fails.
Dropping an amp to 1/2 ohm doubles the output current (up until the amp just can't put out more at least) and makes everything less efficient so the power supply in turn draws more current, often times inducing more voltage drop which calls for MORE current to maintain the same output level - again, turning into a cycle if it continues until something fails.
Many amps are robust enough to handle this pretty well - but the more you push the amp and the more clipping that goes on you get closer to realizing the impedance chart I posted above for a square wave which can drop down VERY low. That sort of thing can destroy even a very robust amplifier design when you are already running at 1/2 or less of the rated impedance load.
It all started with SPL competition... where you play ONE sine wave at a known impedance so you can get away with a really low nominal load. That is all well and good, but music is not a single sine wave - you do not know what the impedance curve can do and it CAN drop below the nominal load, unlike "common knowledge" on the forums may tell you.
- Jacob Fuller
#3
98GMC
98GMC
    Sundown Sales Rep
  • SSA Regular
  • 6,792 posts
  • Gender:Male
Very informative, Thank You!
Edited by OldSkool_08, 10 August 2009 - 11:24 AM.
#4
c_b_
c_b_
    Junior Member
  • Members
  • 116 posts
  • Gender:Male
i have alot of learning ahead of me . . .
does all of that explain why we should not run amps any lower than the manufacturer's lowest resistance?
perhaps people are running amps at lower ohms thinking that "impedance rise" will keep them at a safe resistance without any other worries? and this thread explains why that is not a wise decision.
thank you.
Edited by c_b_, 10 August 2009 - 12:03 PM.
#5
sundownz
sundownz
    SSA Elite Level 2
  • Vendors
  • 7,927 posts
  • Gender:Male
Right. The "theory" of impedance rise assumes music is just like playing one sine wave after another and it is not.
- Jacob Fuller
#6
KU40
KU40
    Midnight Thunder
  • SSA Round Table Member
  • PipPipPipPipPipPip
  • 6,324 posts
  • Gender:Male
Thank god you posted that. I'm so tired of hearing about impedance rise BS and wanting to run amps below rated.
'98 Explorer
Alpine CDA-9827, JL XR 6.5 components, Boston 6x8 something-or-others, Kenwood X40, Sundown SAE1200v.2, Stereo Integrity Mag 15v.2
<div align='center'><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo--><b><!--coloro:red--><span style="color:red"><!--/coloro-->New members topics<!--colorc--></span><!--/colorc--> <!--coloro:gray--><span style="color:gray"><!--/coloro-->>><!--colorc--></span><!--/colorc--> <a href="http://www.soundsolu...howtopic=22849" target="_blank">SSA Membership Terms</a> <!--coloro:gray--><span style="color:gray"><!--/coloro-->+<!--colorc--></span><!--/colorc--> <a href="http://www.soundsolu...howtopic=13994" target="_blank">New Topic Guidelines</a> <!--coloro:gray--><span style="color:gray"><!--/coloro-->+<!--colorc--></span><!--/colorc--> <a href="http://www.soundsolu...showtopic=5002" target="_blank">New Member Welcome</a></b><!--sizec--></span><!--/sizec--></div>
#7
CrazyKenKid
CrazyKenKid
    SSA Respected
  • SSA Regular
  • 3,046 posts
  • Interests:Car audio
wow! a lot of info there to absorb lol!! thanks for posting that it cleared things up! i guess i learned something new today! score two points for the good guys (sundown)
#8
shizzzon
shizzzon
    Car Audio Competitor
  • SSA Regular
  • 6,993 posts
  • Gender:Male
  • Interests:Working\building\OC-ing Computers, Building\diagnosing Car Audio Systems, Repairing Xbox360s, Video Editing, Audio Editing, Theme Parks, Traveling.
and on top of all that, DO NOT get drawn into the hype about "getting your amp modded to handle lower ohm loads".
All that is doing is basically removing the protection circuit from prohibiting the amp from shutting down so u can run it DIRECTLY into destruction.
Ask DB-R about people who mod amps just to turn right around and send em to him to fix because of their stupidity.
I saved someone else over the weekend from doing such a wiring configuration.
For some unknown reason, he has 2 Dual 2 ohm subs wired to 2 ohm on a sundown 3000D.
The subs he is using needs a lot more power than that load can offer but i was tuning his car and found out he has a 2.96x rise at his peak note.
Wiring his subs down to 0.38DCR would allow him to just surpass a 1 ohm load on the amp.
I told him you can do it but you gonna need more battery...
Very next thing he said.... "you think it be alright if i were it like that for daily?"
I answered NO before he even finished the sentence.
I already know that rise DROPS lot lower in places that usually don't sound as loud to the ear.
You can be pullin only 800w out of a 3000w at your loudest frequency or small range there but once u start listenin to areas that dont sound that loud, don't be surprised that the amp starts puttin out over 2000w in that area and it's not that loud at all. That's where crossovers come in handy.
#9
bigmike
bigmike
    Newbie
  • Members
  • 74 posts
This should be posted on every forum!!!!
I/m guilty of this, But now I know better.
Thanks Sundown!!!
Posted Image
#10
loud by design
loud by design
    Member
  • Members
  • 272 posts
  • Gender:Male
  • Interests:God,Car Audio, Motorcycles, My kids(3)
Good post very helpful.
  • 1997 Acura CL 3.0, alpine 7985 head unit,1 Sundown/T3 12" , American Bass 175.1, American Bass SQ500,
    ,The Big 3 , 2 Shuriken 2250,1 red top, 2 runs of 0/1, 8ga speaker wire . M.E.C.A. ONLY 145.4db at the headrest, in the trunk looking for 150db.( where are you ?) 2010 S.C. S5 Champ and Record holder.
#11
jbizzle
jbizzle
    Newbie
  • Members
  • 76 posts
  • Gender:Male
bump for a good thread
Edited by jbizzle, 18 November 2009 - 10:33 PM.
2002 Chevy Trailblazer LTZ
- Alpine 9887
- 8" Powerbass 4XL Mids - CDT TW-25S Tweeters (Active)
- Sundown Audio SAX-100.4D
- 4 Digital Designs 9512Gs
- 2 Sundown Audio SAZ-3500Ds
Team Sundown Audio
Team Mechman
Team Shok Industries
Official jbizzle Feedback Thread
#12
corrie3232
corrie3232
    Junior Member
  • Members
  • 135 posts
repost it for all the knuckle heads out there
#13
Don Ganso
Don Ganso
    Mmmmmmm... Bbbaaaaaassssssss...
  • Members
  • 610 posts
  • Gender:Male
  • Interests:Percussion and Piano
This might have just saved me a lot of stress. Excellent info!
May his bass shine upon you, and be gracious to you. May Jacob Fuller look upon you with favor, and give you peace. Amen.
SSA refs: Miller
#14
Moparbass28
Moparbass28
    Newbie
  • Members
  • 26 posts
  • Gender:Male
Image no longer works. Would like to see the graph.
Top Dog Car Audio
Team Top Dog
Proud member of MidwestSpl
#15
sundownz
sundownz
    SSA Elite Level 2
  • Vendors
  • 7,927 posts
  • Gender:Male
Unfortunately the graph seems to be gone.
- Jacob Fuller
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
#1 Car Audio Forum Since 2001!
