zZZzzzSnooze2nd
Sub Displacement
I have the 12" SSA Xcon D1, What is the Displacement of this sub? I would guess it's 0.18 or 0.19cuft?
Take a look!! It's a work of Art...
Did you check the specs on the site? Im positive its there.
Nice breakdown there too. Cool pics. :fing34:
Did you make those breakdown pics or find them on the website somewhere? If you made them, good job, they look great.
Nope I didn't fined them, I Made it using Google SketchUp 7. I'm going to remake the hole thing, I forgotten a few things.
Edited by Snooze
Displacement: 0.17 cu.ft.
http://www.soundsolutionsaudio.com/store/products/12%22-SSA-XCON-D1%7B47%7DD2.html
XCON 12D2/D1
3" wide, 4 layer, Aluminum coils
Push terminals
Pulp Fiber Cone
5 progressive spiders
Custom FEA optimized motor
Aluminum Shorting Ring
3" Anodized alum. former
Triple Sandwiched Leads
Hand crafted in USA
Wattage: 1750wRMS
12" SSA XCON D2
Re 3.7 Ohms (1.85 per coil wired in series)
Fs 32.4 Hz
Qms 5.24
Qes .39
Qts .37
Mms 222
Vas 35 l
Sd 480 cm^2
BL 20.65
SPL 86.7 1 W/1m
Xmax 31mm
Enclosure Recommendations:
Sealed: .9 - 1.25 cu.ft.
Sealed: 1.35 - 1.5 cu.ft. optimal
Ported: 1.75 - 2.25 cu.ft. @ 26-33hz
Ported: 2.5 - 2.75 cu.ft. @ 26-33hz opt.
Sub Outside Dia.: 12.500”
Cut Inside Dia.: 11.150”
Edited by BanginGMC
12" SSA XCON D2
Fs 32.4 Hz
Qms 5.24
Qes .39
Qts .37
Mms 222
Vas 35 l
Sd 480 cm^2
BL 20.65
SPL 86.7 1 W/1m
Xmax 31mm
ok, BTY the Sub Outside Dia is 12.750” with Rubber seal on.
Edited by Snooze
