Check out these other great forumsSoundSolutionsAudio.comAudioAddicts.netCarAudio-Forum.comCarAudioResources.comHomeAudioForum.net
Ascendant Audio, only at SSA.
HDC 3.0 Starting @ $239
* * * * * 1 votes
The Difference Between Copper and Copper Clad Aluminum Cable
  • Please log in to reply
40 replies to this topic
#16 jay-cee
jay-cee
    Local Neighborhood Playa
  • SSA Regular
  • 10,643 posts
  • Real Name:Justin
  • Gender:Male
  • Interests:Family, Cars, Music & Food
Posted 29 July 2010 - 01:00 PM
Is this copper or CCA?
Knu 4 Gauge Amp Kit
It tells you in the description of the product if you read it. :peepwall:
  • 0
(2) SB Acoustics SB29RDNC-C000-4
(2)
SSA Icon 15"
US Acoustics Mike
Big 3
#17 Maddenkid2011
Maddenkid2011
    Member
  • Members
  • 477 posts
Posted 29 July 2010 - 01:07 PM
Knu 4 Gauge Amp Kit
I knew it was the OFC but the strands on the ground wires look more like the CCA example picture than the copper example picture
  • 0
Metallic Grey 2005 Grand Prix GT
Sub: Fi BL 15" w/
Components: Accepting All Offers
Amp: Rockford Fosgate T-1000bd
Wiring: KnuKonceptz 4 Gauge
Electrical: Yellow Top Starter
#18 sandt38
sandt38
    Misanthrope
  • SSA Tech Team
  • 3,607 posts
  • Real Name:sandt38...
  • Gender:Male
  • Interests:VaJayJay
Posted 29 July 2010 - 03:43 PM
Knu 4 Gauge Amp Kit
That is copper. The CCA is not really a transparent covering, it is opaque pearl blue, and the CCA ground is pearl white.
this is the 4ga CCA kit:
http://www.knukoncep...m?prodID=KLM-K8
  • 0
It Doesn't matter if the glass is half full or half empty As long as there is whiskey in it.
So how's that hope and change shit workin' out for ya?
I smoke cigars because the smell keeps assholes away.
#19 98GMC
98GMC
    Synergy Audio Sales
  • Moderators
  • 6,878 posts
  • Gender:Male
Posted 29 July 2010 - 03:53 PM
I will stick to Stinger HPM silver tinned OFC. It doesn't corrode as easy as non tinned copper, especially under the hood.
Great post btw Duran! Thanks!
  • 0
#20 cobra93
cobra93
    Regular Member
  • Members
  • 592 posts
  • Gender:Male
  • Interests:Cars, car audio, Computers, Golf.
Posted 29 July 2010 - 07:45 PM
I don't remember where I read about it, but with silver tinned copper wire the signal/voltage will travel the path of least resistance (obviously).
In this case the silver has a lower resistance than the copper and this signal/volts/amps will travel down the out side of the wire more so than the copper itself.
Does this matter? Probably not to my ears, but to some people they can hear the difference. I remember seeing a company that had home theater cable (diy) for more than $1200.00 per foot.
I realize this is way off topic, but.....
This was a quick search Audioquest cable
Edited by cobra93, 29 July 2010 - 07:46 PM.
  • 0
Pinch the lane divers out, no matter the cost !!!!!!
Head Unit....................... P99rs and lovin it.
Jl audio 300.2 .................Fr88's
Sundown sax 125.2.........(4) Peerless SLS's (door mounted) .3 c.f. sealed enclosures.
Sundown saz2000d..... ....Eclipse 88120 TI DVC, 1.55c.f. 32 hertz tuned.
4- SA8 box build log
Front Stage Build
#21 98GMC
98GMC
    Synergy Audio Sales
  • Moderators
  • 6,878 posts
  • Gender:Male
Posted 29 July 2010 - 07:51 PM
Wow! Really wouldn't know about all that. I just stick with Stinger as I can get it local and cheap! :drink40:
  • 0
#22 cobra93
cobra93
    Regular Member
  • Members
  • 592 posts
  • Gender:Male
Posted 29 July 2010 - 08:14 PM
I would like to say I read this in a home stereo magazine many years ago, not sure. Whoever was reviewing the different cables worked for this magazine, The funny part was that he struggled to hear any difference, while his wife would walk in from another room and say something like "The highs sound better, did you get new speakers?". I'm sure this irritated the crap out of him.
He also said that different frequencies travel through different parts of the wire (the skin or the core of the wire) and arrive at the speaker at different times. Is this true, I don't know. I would have the means to test it, but it was an interesting read.
In the 90's, I was told that twisted/braided rca's would reject outside noise from being introduced into the signal. Is that true, I don't know, but I never had any more issues with buzzing or other noise in my systems after i switched to them.
Edited by cobra93, 29 July 2010 - 08:15 PM.
  • 0
Front Stage Build
#23 sandt38
sandt38
    Misanthrope
  • SSA Tech Team
  • 3,607 posts
  • Gender:Male
Posted 29 July 2010 - 08:42 PM
Actually unshielded twisted pairs are not really designed to eliminate ground loops or induced noise, such as we see from car audio environments. They are intended to eliminate crosstalk. BUT! In a car we really are not terribly concerned about crosstalk.
Rarely in a car audio environment will we see UTPs used correctly. Ideal usage of UTP usually involves multiple runs of twisted pairs in a single insulator sleeve. In order to reduce, or eliminate crosstalk transmission between the 2 twisted pair in the same sleeve, the twist rates (and in some cases, direction) need to be different. Considering that most manufacturers twisted pair RCAs for in car use are all the same twist rate (it may vary by mfg, but who is going to use multiple mfgs, as they typically don't match?), their ability to eliminate crosstalk is nearly nil. However, outside EMI/RFI and ground loops really are what cause the noise issues we hear in a car. The noisy environment in a car really makes crosstalk a non-issue, as it is generally a very fine distortion compared to typical ambient noise in a vehicle.
A lot of people figure that twisted pair was the ingenious development that was cause for better noise rejection in car audio systems. In reality we saw better noise rejection technology introduced to our equipment including but not limited to increased low line voltages which help reduce noise on the input side by increasing the desired signal to interfering signal ratios. The best RCA to use for RFI/EMI noise rejection in a car is really good old fashioned shielded RCA cables. However, for the best of both worlds you can find shielded twisted pairs (STPs). But actually because today's noise rejection technology in our devices you could just about run your power cable next to an old school speaker wire type RCA cable without much noise issue, as long as the system is well gounded that is.
  • 0
#24 Impious
Impious
    I Know The Pieces Fit
  • SSA Tech Team
  • 6,436 posts
  • Gender:Male
Posted 29 July 2010 - 08:59 PM
Really, just from what you've said, I would guess that the article you read was filled with techno-babble bullshit. It sounds like they were taking some general facts and extrapolating out useless or possibly incorrect theories. Stereophile'ish, for lack of a better word.
Silver has less resistance than copper, no doubt about it. And while I haven't done any mathematics at all, this is a pure guesstimation, I would have a hard time imagining the silver tinning having less resistance than the copper wire of comparatively much greater thickness.
Skin effect is real, and wire does have group delay. However, within the audible spectrum and with speaker wire the length we use in car audio (and in most homes), both of these issues can be completely ignored. The change in speaker wire "performance" as a result of these two items within the 20hz - 20khz bandwidth is well below the threshold of audibility. We are talking about hundredths of a decibel and nanoseconds. Nothing to concern yourself with. Now if we were talking RF frequencies, then it's something to consider. Nobody can hear the difference, but many people like to trick themselves into believing the can so they can justify either 1) spending more on speaker cable than most spend on a new car, or 2) to justify their other closely held but largely unfounded beliefs. It's a little like religion, really.....a loss of rational thinking so that irrational thinking can attempt to be justified. Also, skin effect only affects AC not DC. So no worries with your power/ground cables.
This is actually a long standing debate. Some people swear by UTP (unshielded twisted pair), including the likes of Richard Clark.......others swear by shielded cable. This and amplifier sonics are probably the two most hotly debated topics.
  • 0
I find that I can see a light at the end down beneath my self-indulgent pitiful hole.
Defeated I concede and move closer.
I may find comfort here. I may find peace within the emptiness.
How pitiful.
- TOOL, Reflection
I contend that we are both atheists. I just believe in one fewer god than you do. When you understand why you dismiss all of the other possible gods, you will understand why I dismiss yours. - Stephen Roberts
#25 Impious
Impious
  • SSA Tech Team
  • 6,436 posts
  • Gender:Male
Posted 29 July 2010 - 09:07 PM
You've been able to do that without issue for a couple decades. I know I've been doing it for over a decade without a single issue.
Power cable induced noise is an old wives tale in car audio :)
  • 0
How pitiful.
- TOOL, Reflection
#26 Julian
Julian
    Sexiest Team SSAudio Car
  • Super Moderators
  • 15,391 posts
  • Gender:Male
  • Interests:You know
  • Vehicle:05 TB
    4 ZCON 15's
    6th order
    2 Taramps HD8ks
Posted 29 July 2010 - 09:13 PM
the new KK CCA is very good, same jacket as their higher grade wire, the 1/0 CCA can take up to 250 amps, as pure copper its from like 300-350+, i wouldn't sweat it at all. 2 runs of CCA 4 bucks > Singe run of kicker hyperflex 5 bucks.
  • 0
2x SSA Zcon 12's
Taramp's HD8000
Odyssey PC1800FT
#27 sandt38
sandt38
    Misanthrope
  • SSA Tech Team
  • 3,607 posts
  • Gender:Male
Posted 29 July 2010 - 09:14 PM
In today's systems, yes. But in the days of .5 and .25volt preouts we did see noise issues. I have been bundling my cables for years, but I still cringe in rememberance of the old days... back when Denon tape decks and CD changers were in my car... Yeah, Denon car audio.
  • 0
#28 Randal Johnson
Randal Johnson
    New Build in the Works
  • SSA Regular
  • 4,583 posts
  • Real Name:Randal Johnson
  • Gender:Male
  • Vehicle:1997 Chevy Silverado
    1949 Ford Tudor Sedan
Posted 29 July 2010 - 09:22 PM
Very interesting read guys !!! :drink40:
So is welding cable ok to use ?? How bout coax cable for RCAs ??
  • 0
1997 Chevy Silverado - 1949 Ford Tudor Sedan
Team Linear Power - Hyper Lights
#29 sandt38
sandt38
    Misanthrope
  • SSA Tech Team
  • 3,607 posts
  • Gender:Male
Posted 29 July 2010 - 09:31 PM
Yes and yes. Welding cable is a fantastic conductor, and exceptionally flexible. Coaxial cable is basically just a shielded conductor. IMO it is superior to all UTPs out there. Also, if you go ahead and step up to a Canare system, including their cable and connector technology, you wind up with what many consider as superior to the vast majority of low level transfer out there. Being that you are a clipper, I would assume you are using Canare or similar crimping device, so getting a good set of ends will get you set up right.
  • 0
#30 Randal Johnson
Randal Johnson
  • SSA Regular
  • 4,583 posts
  • Gender:Male
Posted 29 July 2010 - 09:39 PM
Good. I have somewhere around 100ft of welding cable in my ride.
Being a cable guy, Yes I had to try my own touches to my system. I Used Mini RG 59 cable (Cable TV headend cable) with custom preped RCA compression connectors.
Thanks.
  • 0
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
#1 Car Audio Forum Since 2001!
