dbEric
New HT subwoofer
Taking the subwoofer out from my receiver to a low pass crossover and then to the Soundstream C-1 preamp and onto the Soundstream DA-1 dual monoblock amplifier.
-Soundstream DA-1
Dual monoblock power amplifier
200 watts /channel, 8ohms (continuous power, minimum rms, 20Hz-20kHz, (with less then 0.1% THD)
300 watts/ channel, 4ohms
400 watts bridge, 16ohm
600 watts bridge, 8ohm
Frequency response 20Hz-20kHz +-0.1dB
Bandwidth 2Hz-100kHz
Slew rate greater then 35v/us
Crosstalk greater then -110dB
Signal/Noise, A weighted greater then -110dB
Gain x40, 32dBv
Dynamic Headroom greater then 3dB, 4ohm
Dimensions 5 7/8" x 17" x 14"
Weight 35lbs
-Soundstream C-1 pre-amplifier
Input impedance 30k ohms
Input sensitivity less then 100mv for 0.5Vout
Maximum input signal 10Volts
Frequency Response 20Hz-20kHz +-0.1dB
THD less than 0.05%
Signal/noise, A-weighter greater then -110dB
Crosstalk greater then -100dB
Maximum Gain 15dB
Headphone ouput Impedance 30 ohms
Main Output Impedance 1000 ohms
Minimum Recommended load 5000 ohms
Maximum Output Level 10 volts
Treble +-8dB, 10kHz
Bass +-10dB, 50Hz
High Cut Filter 8kHz, 6dB/octave
Mute -20dB
Dimensions 3 3/5" x 17" x 11 1/2"
Weight 15lbs
Elemental Designs 12Kx.2?2
-12" dual voice coil subwoofer
-150/400 power requirement
-Dual 2 ohm coils
Qts: 0.30
Qes : 0.34
Qms : 3.16
Vas : 181.65L
Sd : 545.42 cm^2
Xmag : 12.5mm
Xsus: 18.9mm
Xmax: 12.5mm
MMd: 178g
Re: 2.39
Fs: 17Hz
Bl: 21
6 cube box tuned to roughly 21-23Hz. Hooked up 4 ohms per sub.
My secret glue
It replaces this
A couple things...
Sweet flat cones.
Sweet enclosure
HOLY OVER BRACED !!!!!!!!!
Can i have some of that " secret glue" on my hot dog please
that's freakin awesome. Awesome box
I love the secret glue ;)
x2
Great construction. The drivers look very nice indeed. I hope that caulk dries clear.
no it won't. I grabbed the wrong tube of caulk. I used some silicone around the subs and that is clear.
I like the low tuning, always a fan of that.
I would like to see a negative response to this project.
Very amazing.
Looks very good.
I just thought that if those woofers were placed in a box that was lacquered to hell and back (like some monitor's are, really glossy) I would come to your home and they'd be leaving with me.
That Soundstream amp looks cool, do you like it?
Very nice setup. That is one sexy box. Might I suggest you get some spreay paint and go over the caulk to make it not stand out so much?
Still a very well built HT substage.
I'll post a negative. The paint isn't 100%. I wish I would have used body filler over the entire surface and sanded to get the best possible surface for painting. I would hace also gone with a bedliner time spray on but this is fine if you don't go right up to it under the light.
I also need to put in a port brace since I can almost feel the ouside wall flexing.
Soundstream Amp is nice. I also have the matching C-1 pre-amp and T-1 tuner. The amp is just starting to clip at the maximum I would want to push these. The amp does get real hot when pounding away.
I've been delaying speaker porn and the output mesurements. SOON...
