BanginGMC
Amp Catches on FIRE!
so the lesson of the day is don't splice power wires? :peepwall:
You can do whatever you want. I mentioned previously, if the power supply blows and the mosfets short out you will basically have a short between + and - inside the amp. Blow on it, spit, piss, pour water put a blanket over, nothing will work.
Here's some fire damage :P
When did they feed it oxygen?
When they were blowing on it?
Biology 101
We inhale Oxygen and Exhale Carbon Dioxide. :drink40:
You're joking right?
If they blow from that kind of distance it will get more oxygen then Carbon dioxide. ;)
Nobody was smart enough to pop the hood and disconnect power wires? and then put water on it? :peepwall:
He's gotcha there Tirefryr :P
Not actually, considering the guy is right on top of the thing. Maybe if he was fanning it, but either way, it's a moot point.
What amp is that?
What amp is that?
Digital Designs Z1.
Ended up working good :P
