swift
4 channel amp wiring question, opinions
I am thinking of going with 2 sets of components for my front stage and doing away with the rears.(maybe) I have a Alpine PDX 4.150 that does 150 x 4 rms to each channel. Right now I have the fronts on the front channel rca and the rears on the rear channel RCA's.
So I do not mess with imaging too bad do I just run RCA Y spitters just on the front channel from the head unit so I can use all 4 channels of this amp?
I need something to keep up with two 18's and I think my current front stage would but since my rears will blocked by the huge box I might as well double up front and use all 600 of this amp :)
Do you have front and rear rca's coming off the H/U and no sub outputs?
I do have front, rear and sub rca's coming from the head unit. Both front and rears are going to the 4 channel currently, but I thought it would be better if all fronts were coming off the same signal? Maybe I am wrong, thats why I'm asking.
Thanks
Thanks
You can adjust that with your head unit.
Thanks
You must not understand my question at all.
I'll give someone else a shot at it.
Thanks
Thanks
Thanks
I understand you want all the signals to be the same.Do you want to use the second amp channels to run a sub?
Do you have a sub amp?
I have a Sundown 1500v.2 on the sub RCA's. (didnt think that was relevant)
I have a Alpine PDX 4.150 with the front RCA's on two channels to the front components and the rear RCA's on two channels for the rear coaxials.
I want to run two sets of components up front. I did not think it was a good idea to run the rear RCA's for the second set of components.
To use all 4 channels of this amp I have to run 2 sets of RCA's to it. Should I split the front RCA's coming from the head unit so I dont have a "rear" signal going to the second set of front components?
http://www.sonicelec...cture_id=145065
EDIT, after looking at the pic of my amp I think I can switch it to run all on one set of RCA's. If so I should have done alittle more reasearch on my amp before asking. Maybe I made it more complicated than it needed to be.
Edited by swift
It won't matter, no. A lot of people use a 4 channel amp for just their mids and highs in their front doors. I'll be running 2 channels to my mids, and the other 2 channels to my highs on my 100.4. They're just labels, they're sending the same information to the amp. Whatever you have the setting on the amp or your HU is a different question.
This possibly could be the dumbest question I have seen yet and I made the damn thread!!
LOL
So bridge the amp on just the front RCA's or split the RCA's and use all 4 channels independently? I wonder which is most efficient or maybe it will not matter?
It runs 4ohm bridged or unbridged.
is splitting rcas like wiring speakers in parallel? for instance if you had 4volts preamp would it create 2volts per channel? dont mean to thread jack but my question does kinda pertain to your topic.
btw what kinda of components are you running? i was thinking of doing the same thing except with except i would take out one of the tweeters.
If so then I am better bridging the amp and not splitting RCA's. Didnt think of the voltage. hmmm maybe someone can answer that.
I am running Rockford T2652s up front and would probably just add another set.
Edited by swift
Thanks
Thanks
No you dont understand what he is asking and no he doesnt want to use the other 2 channels on his amp for subs. He wants to run two sets of components to his 4 channel alpine amplifiers, he wants to know can he use one set of 2 channel rca's with a y-splitter to turn the end of the rca's going into the amp to a 4 channel set. You can but Ive heard you loose some signal/output by using y-splitters so I would just keep the front and rear rca's plugged up unless your amp had a 2/3/4 channel switch. Front and rear will send the same signal
I think by running splitters you will decrease the ohm load from 4 to 2ohms
You cant run two sets of components at 4 ohms bridged, 2 sets of components per side will result in a 2 ohm load.
Do some research and you will find out splitters do not change the ohm load, only adding/deleting speakers can change ohm loads and wiring configurations. Please be advised with what your saying as other people read this thread for the same answers, we dont want any confusion or misinformation.
Maybe he should be the one asking questions....LOL
Here is my amp specs BTW.
http://www.sonicelectronix.com/item_6895_Alpine-PDX-4.150.html
http://www.sonicelec...-PDX-4.150.html
Naw i doubt it since he is the one who claims to hit a 150db with 2 Icon 12'' and a AQ2200d but couldnt provide evidence when i asked, not that guy. He should do more than ask questions, Im glad he is trying to help but you gotta know when you know something and when you dont.
Read under the controls section here and it tells you no y-splitter is needed and one set of 2 channel rca's will be enough to run all 4 channels. You just have to put the signal setting on the right feature:
http://www.crutchfie...tml#details-tab
Edited by jay-cee
lol so i checked just to make sure and splitting doesn't change the voltage. sorry for any confusion...
TEST: same volume, 1K hz test tone, could've done a 50hz but i dont have high pass on the doors, shouldve done it though cuz the 1K hurt my ears :/, 2 DMM, same .5 volts each. i did this at low volume 15 out of 60.
those rockfords are sweet, i just installed the t1 6.5s in my uncles car last week... and they said it wouldnt fit B)
custom FTW!!
Sorry I guess I didnt understand your question.
    1. Recent Topics
        • 17 comments
        • 178 views
        • 393 comments
        • 32,175 views
        • 2 comments
        • 670 views
        • 5 comments
        • 1,446 views
        • 6 comments
        • 1,015 views
        • 1 comment
        • 961 views
  • Similar Content
    • By musgrove
      I'm nearing the finish line in an installation that includes a new HU with FT/RT, FR/LT RR/RT RR/LT, and a SUB output, plus an unmarked, unidentified in the manual, RCA output on the back of the HU next to the SUB output.
      I have a 5 channel amp that has Channels 1(white), 2(red), 3(white) and 4(red) marked clearly on the amp, plus a SUB RT(white) and SUB LFT(red) input, all input by RCA.
      The same amp has 4 sets of output terminals, 1 each for + & -. It also has 2 terminals for the sub (+ & -), which connects to the sub on R &L posts.
      So, first question:
      How do I run a cable from the HU, which is 1 RCA connection, to the AMP, which has both LT and RT RCA input connections?
      Second question:
      I also have the White, Grey, Green, Violet (+&-'s) hooked up from the HU to the wiring harness that goes to the speakers. The reason for this was that I have six speakers placements: 2 6.5" in the front doors, 2 6.5" in the rear doors. In the dash, I removed the tweeters that were in a plate and replaced them with Infinity Kappa20's midrange speakers that have bandpass crossovers that handle 550hz-7Mhz hooked up.
      Just to confuse things more, The manual for the amp shows The channel 1 speaker attached to the channel 2 output terminals(+&-) and the channel 2 speaker (+&-) attached to the channel 1 terminals. Channels 3 and 4 are where I expect them, 3 & 4. And then again for the SUB it has + and - terminals to go to + & - posts on the SUB.
      I've routed every plug in every location and checked each speaker, one by one by changing the fader/balance in different combinations to determine what's going on.
      What I sense I'm doing wrong is that I'm wiring RCA cables with both RT/LT wires into the AMP to the HU when both only want a single signal cable each going into each jack. One single wire each that somehow is carrying both the Positive and Negative in it, versus a double speaker wire that goes into a positive/negative RCA male connector.
      So that leaves the sub with one single output HU going to the AMP which has a R(white) and L(red) female connector. And then the 5th channel +&- going to the +&- on the SUB input.
      The reason I have the HU output speaker wires (white,grey,green,violet) going to the speakers is because of the Dash Unit speakers. They're tapped into those 4 in the wiring harness where I can't get to them, but run from the HU from 4 wires to 6 different speakers). Again, the dash speakers are 2" Infinity midranges with bandpass crossovers connected to each which came with them. I just noticed they are 2.5 ohm, and everything else is 4 ohm, which is worrisome.
      Is there a wiring genius out there that can understand what's going on and tell what I have wrong? There's also a whine coming from the front right dash speaker and possibly the right(passenger side) door speakers. I have the power cable far from the speaker wires on either sides of the vehicle. But I'm sure it has with the larger wiring issue at hand.
      Any and all help is greatly appreciated. This is a crazy puzzle. Here's a diagram I made to make it more visual:
    • By Alex Kadlec
      I really want one and am willing to pay anything reasonable, just give me a price!
    • By scud
      Hi everyone  please any help
      How do you wire 2 dual voice coil subs that are 2 ohms and i have a 2 channel amp ( http://www.amazon.com/Lanzar-VIBE2102N-2-Channel-MOSFET-Amplifier/dp/B00BN7XQG4 )  i want to know how to wire them up to the amp at the 2 x 2400 Watts @ 2 Ohms RMS  i have come across this page http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2DVC_2-ohm_2ch.jpg%C2'> but does that mean that each sub is wired for 4 ohms. Any help maybe i am missing something or its something so simple but this is my first build and the subs are 2 12" Fi BT series and this is the only amp i have for now. If this amp is not adequate after help with the wiring i would love to know any good deals on amps that could power these subs any help would be greatly appreciated.
    • By altoncustomtech
      Well, a midst everything else that's going on around here, subwoofer enclosure, engine replacement, four wheeler repairs (minor), and WORK, the components in my wife's van have all but completely given up the ghost.  I do have to say they hung in there for WAY longer than she, I or anyone else would have ever dreamed but everything wears out eventually.  They've gotten to the point where they will cut out at high volumes for a short period of time then come back on and it's any combination of the drivers that do it.  Just the one tweeter, or maybe both tweeters, or maybe both mids and the tweeters keep going, or sometimes it's a tweeter and a mid on one side or the other.  The point is that they're about shot, lol.  So, for any one of you who are married, were married, or at least in a long term committed relationship you know what I'm talking about when she walks up to you with that sweet look on her face and in a very sweet voice asks about how long it would take to do something for her, wanting the answer first.  Then she plays with her hair, and does all the cutest things possible while explaining that she would like to have that thing put at the top of the priority list.  All of us who've been there can see it coming a mile away and most of us know exactly what that answer is, lol.  That's where I found myself today.  First she started talking about all the trouble with the Hifonics components, then she started asking about the new ones, and now I've agreed to figure out how to get them put in as soon as possible with the least amount of down time (cuz she's gotta have her music when driving) possible.  Yay.....  LOL
      So here I am, online looking for installation ideas and techniques, trying to figure out the best way to install these without taking forever.  Not an easy task with any set of components or speakers, but with this set, this woman, and this vehicle it's even more challenging.
      Here's a quick pick of the set when I had it out earlier taking some measurements and trying to get a good grasp on how the hell to go through with the install.
  • Recent YouTube Posts
