Check out these other great forumsSoundSolutionsAudio.comAudioAddicts.netCarAudio-Forum.comCarAudioResources.comHomeAudioForum.net
Welcome to SSA Car Audio Forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
The all new XP series Batteries.
Now shipping!
Help with preventing voltage drops?
  • Please log in to reply
10 replies to this topic
#1
Angelboy863
Angelboy863
    Regular Member
  • Members
  • 773 posts
  • Gender:Male
  • Interests:Car Audio, Army, Family, Friends,
  • Vehicle:07 550i
Hello everyone.
There have been numerous times where my voltage drops to 11.7. I usually have a constant 12.8, or 12.9 (never 13 :o)
On idle with music a little bit up (volume knob at around 20 out of 30) and/or other electronics in car I'm around 12.5 but when I'm at idle and my music is up it can get to 11.7-11.8
I have a 96 civic. Stock alt is 70amps. I have a kinetik 800 under hood and big three done with 1/0 kicker wires. Those are currently the only electrical upgrades I have.
I have a temporary system in while I'm saving up for some good stuff. Just a 12" Sony xplod on a 250w monoblock xplod amp. My voltage drops from this? Gain is 1/4 up I'm not een stressin the amp. Could this be a sign that my alternator is getting weak?
What would you guys recommend I do. A HO alternator isn't an option at the moment. .
Is upgrading big 3 to 4/0 going to do anything or would I be wasting my time without upgrading my alt. More batteries? Plan to run an almost 1000wrms system soon. I do plan on getting another battery in the back again, like a kinetik 1800.
07 BMW 550i
#2
Shogen
Shogen
    SSA Old School
  • SSA Supporter L1
  • 5,749 posts
  • Gender:Male
  • Interests:women, computers and car/home audio
  • Vehicle:2003 Toyota Camry
don't upgrade wire... that's pointless...
You need better battery support for later.. But I think maybe a slightly upgraded alternator would help alot for you..
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060- Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: Mechman 270a - Kinetik HC1800(front) NEW***DieHard P-2(rear)
Posted Image
ohjay - We're definitely not calorie counters, 'cause we can't count that high.
onebadmonte: Did you feel it?
denim: Yes, both monitors were shaking bad. I work at a mid-size engineering firm. Funny story, the structural department all stood up and none of us said a word and we all hustled out of the building, the entire electrical, process, mechanical and piping departments were staring at us.
Julian: "Our Structural engineering senses are tingling, quick let the weaker electrical, process, mechanical and piping departments die!"
#3
MemphisMzd
MemphisMzd
    why not?
  • Members
  • 898 posts
  • Gender:Male
  • Interests:Nascar Technical Institute and car audio.
Your alternator is on its way out if you never see above 13v. It takes more voltage than that to maintain and charge an agm which you have.
03' Mazda Tribute
Team SSA
155.5 @ 36hz - sealed
^ music ^
Pioneer DEH-80prs|8x SD SA-12s|4x SD SAZ-2500Dv2|SD SAX-100.2|3x XS XP3000's|DC XP250
#4
stefanhinote
stefanhinote
    what are these ohms you people talk about?
  • SSA Regular
  • 11,871 posts
  • Gender:Male
Alternator and or voltage regulator, not sure if that car has it built in with the alt.
Additional batteries will increase your "power reserve", but if your alternator can't properly charge a single battery then don't expect it to be able to charge multiple.
I would get the alternator / regulator issue fixed, then go from there. A new working stock alternator is better then an old failing one. Posted Image
Otherwise, a few more batteries, bigger amp, and failing alternator = killing your batteries' lifespan, and eventually getting stock on the side of the road one day.
Edited by stefanhinote, 17 April 2012 - 06:50 PM.
2002 volvo v40
Posted Image
#5
///M5
///M5
    SSAudio Level 14
  • SSA Audio Tech Team
  • 58,664 posts
  • Gender:Male
Doubt that.
Please read my posts with care. I do not pull punches, but state exactly what is on my mind. My goal is to make you think, make you try harder and to improve yourself AND this forum. This doesn't mean that I don't like you, am being aggressive towards you, or have any other hidden meaning. Instead look at it as me trying to make you better. In no way at all should your butt be hurt by my posts. If so, read it differently. You agreed to taking criticism when you joined, doesn't mean that you have to choose to take it personally. The more effort you put into your threads and posts, the more I will in return. What you get out of it is up to you.
Posted Image
Posted Image
New members topics >> SSA Membership Terms + New Topic Guidelines + New Member Welcome
I was. Super proud I didn't shit my pants. I was sure it was going to happen.
We sit on the same bench. Your "asshole" just makes me curious.
#6
Angelboy863
Angelboy863
    Regular Member
  • Members
  • 773 posts
  • Gender:Male
  • Vehicle:07 550i
Dangg, I guess I'll check out the alternators at autozone. I was around 13.4 - 13.7 when I had two batteries in the car but I sold the second one and since then voltage never was over 13. My gain is 1/4 up. Before it was 3/4 bit that was about a month ago. Since then I sold my second battery and eased up on the gain because voltage was so low.
07 BMW 550i
#7
jay-cee
jay-cee
    Local Neighborhood Playa
  • SSA Regular
  • 8,823 posts
  • Gender:Male
  • Interests:Cars, Food, Women, Shoes and Music
Dont set your gain by how many batteries you have, learn how to protect your equipment and install it right before it causes problems.
Your gain matches the pre-out voltage of your source (i.e. head unit).
Pioneer DEH-P8300UB
(2) CSS ERT26 Tweeters
(2) O2 Audio OM-605ND-PRO Mids
(2) 12" IA Lethal Injections
Cadence ZRS-7000D
BHE Enclosure "Blue Magic"
#8
Angelboy863
Angelboy863
    Regular Member
  • Members
  • 773 posts
  • Gender:Male
  • Vehicle:07 550i
Just emailed excessive amperage to see if they can build me an alternator around 160amps. Hopefully the price won't hurt too much.
07 BMW 550i
#9
Angelboy863
Angelboy863
    Regular Member
  • Members
  • 773 posts
  • Gender:Male
  • Vehicle:07 550i
So my dad and i got a new "high output" alternator from ebay. its supposely 165amps but not sure yet (how to figure out actual amps?) wayy better than my stock alt. we got it for about $150 shipped. we installed it today and voltage is at a steady 13.6-13.7. pretty impressed so far but again we JUST installed it so i hope this lasts. not bad for $150 though. still only kinetik 800 under hood and big 3 so i c ant wait till second battery is in, hopefully it'll boost that voltage a little bit.
07 BMW 550i
#10
Fearz
Fearz
    Member
  • Members
  • 416 posts
  • Real Name:Zach
  • Gender:Male
  • Interests:Tuners, Car audio, building PC's, Women, and Living
  • Vehicle:GM PCM controlled
If its a Honda I think you can do a ELD bypass To charge in the 14v range.
Amp: 2000d
2 Sundown Zv3 18''s
Knu wire
Knu RCA's
Xs Power 3400 secondary
Looking for an alt.
#11
shizzzon
shizzzon
    Car Audio Competitor
  • SSA Regular
  • 7,003 posts
  • Gender:Male
  • Interests:Working\building\OC-ing Computers, Building\diagnosing Car Audio Systems, Repairing Xbox360s, Video Editing, Audio Editing, Theme Parks, Traveling.
if i had that car, i'd be gettin some facts first before buyin stuff and potentially wasting money where you do not have too.
Call a reputable alt company that knows imports. Mechman and DC Power both know these cars well.
Ask them what is the normal charge voltage for this car.
Tell them you are only ever seeing 13.7v all the time.. that's not normal but can be if it's setup that way from factory.
You need to know what's normal and what cancan't be done first.
I'm assuming the alt and new alt must be charging because if they weren't, you wouldn't be able to drive back and forth after just 30-60minutes without major electrical problems.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
#1 Car Audio Forum Since 2001!
