Briggiboy33
what size wire do i use?
The amp im buying says it takes 4 guage... but its a 1600rms amp. I also have a amp on my door speakers that takes 8 guage but do i run a 1 guage and a distribution? Or do i go bigger and try to cram bigger than 4 in the sub amp?
You could run a 1/0 cable from battery to a D-block, and then place accordingly. You could run one 1/0 cable from battery, to a 1/0 to 4 gauge reducer, and then run a 8 gauge from battery to your mids/high amp.
the bigger the wire size you can fit the better
What amp is it?
Or, snag you up a small battery for the rear and distribute off of that! :)
Its a soundstream rubicon 1600d on the ssd15. And my first amp i ever bought a pyramid classic on the front doors. Lol. But it works fine aslong as its not turned up too high... but so i should get a 1/0 power and distributer block. Alright thanks guys!
I like the battery idea! :D
Lol no room in an access cab tundra with only one less seat...
Lol and btw there is absolutly no possible way im going to spend 60 on a distro block... but ill get a cheap one on amazon
