Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
Chaos 10 inch in Sealed Cabinet
#1
Posted 16 June 2012 - 06:06 AM
Using the T&S figures given on site the box size for a sealed enclosure seems wrong, when I calculated it out if the box is 0.6 cu ft (min. size) the system QTC is 0.55 which is of course very low and for 1.0 cu ft (max. size) the QTC is 0.49.
So what is wrong the T&S figures or min and max box sizes.
#2
Posted 16 June 2012 - 11:16 AM
The suggested enclosure volumes from any manufacturer are exactly that: suggestions. It doesn't mean you can't use the driver in a different alignment if you so choose.
Defeated I concede and move closer.
I may find comfort here. I may find peace within the emptiness.
How pitiful.
- TOOL, Reflection
I contend that we are both atheists. I just believe in one fewer god than you do. When you understand why you dismiss all of the other possible gods, you will understand why I dismiss yours. - Stephen Roberts
#3
Posted 16 June 2012 - 12:53 PM
#4
Posted 16 June 2012 - 02:14 PM
Many manufacturers "recommend" small enclosure volumes simply because they have a higher peak output which makes the average consumer think the product is "better". That doesn't mean the recommended enclosures are optimal for the driver. Hell, I never even look at manufacturer suggested enclosure volumes. They don't know what I look for from a performance aspect, and I don't know what they were aiming for from a performance aspect when they suggested those enclosure volumes. I take the time to design my own enclosure, or lack there-of since I generally run my drivers IB (even when they might not be specifically "suggested" for IB use by the manufacturer). It's the only sensible way to go about it.I take you point but I have never seen a manufacturer suggest a minimum box size this big before giving such a low starting QTC and I mean never, just look at Fi and Re so I say again there is something not right somewhere.
As far as I know, Scott for the most part doesn't really use enclosure modeling, target curves or target Qtc's to recommend enclosure volumes for his drivers. He uses his experience with the driver to suggest the range of enclosure volumes that most consumers would prefer. So the results will all vary slightly when plugged into enclosure modeling software.
You apparently know how to use enclosure modeling software....if you're not happy with the recommended enclosure volumes, model something else that you would prefer more.
I fail to see why you are having such problems or making an issue out of something that really isn't an issue? Again I say it seems like you're trying to make a big deal out of nothing.
How pitiful.
- TOOL, Reflection
#5
Posted 16 June 2012 - 02:52 PM
Just look at others and you will see what I mean.
I am actually thinking of using a Fi or AA for home music use not HT and am having difficulty getting information from either. I would like to know what the high QTS is on the Fi SSD and Q models but cant get an answer and enclosure sizes vary all the time so its difficult to model without exact figures.
#6
Posted 16 June 2012 - 03:48 PM
Team SSAudio
(8) Sound Solutions Audio XCON's
American Bass 1000.1
(4) Diehard Platiums
Pioneer Premier DEH-880PRS
Sexiest Team SSAudio Car!
#7
Posted 17 June 2012 - 09:02 AM
Just find it strange that Fi and AA seem to have the same designer and Fi quote small enclosure sizes and AA large for the 10 inch sizes it makes it seem that the figures are not correct or there is a mistake with the enclosure sizes with AA.
I gave you the answer on AVFourms with regards to H-Qts. The info you seek on the enclosure parameters are on the Fi/AA sites. All the threads you have started on various forums have been answered correctly and accurately by proffessionals who know what they are talking about. The only answer Fi/AA will give you is the answers you've already read and seen, so I'm not sure why its so important to be hearing it from the horses mouth?
Anyway, I trully hope you find the answers your looking for
UK/European Distributors
Ascendant Audio
Fi Car Audio
KnuKonceptz.co.uk
Youtube Channel
#8
Posted 17 June 2012 - 02:14 PM
Sorry just finding hard to make a decision, also trying to see now if I can fit a 12 inch into my space.
I assume that if I go for a 12inch Fi the high QTS versions are also plus 0.08 above the normal QTS figures.
#9
Posted 18 June 2012 - 07:08 AM
Yes thats correct. Also if its any interest to yo I have a semi-used Q15 D2 H-QTS with cooling and Intl. Lead options for sale, its in superb condition!
Edited by BILTD, 18 June 2012 - 07:09 AM.
Ascendant Audio
Fi Car Audio
KnuKonceptz.co.uk
Youtube Channel
#10
Posted 18 June 2012 - 11:12 AM
What is the best size of cabinet for a 12 inch SSD for home music use.
#11
Posted 18 June 2012 - 04:10 PM
Ascendant Audio
Fi Car Audio
KnuKonceptz.co.uk
Youtube Channel
#12
Posted 22 June 2012 - 05:11 AM
I am assuming H-Qts for driver is 0.44 and I have modelled it in Win ISD and its not bad and of course I have 6db boost at 25 hz. My crossover is 70 hz and so I am only 4db down at 25 hz. As I said I only use the sub for music at home and there is not much below 30 hz anyway.
Overall I think it will give me a better performance than the RE SR10 if you agree will place order soon
#13
Posted 22 June 2012 - 10:38 AM
Correct Qts is 0.44. f3 I get is 36Hz in 1.1cf with all walls lined. Not sure how you are getting it @ 25Hz. I use Bass Box pro for modelling.
Ascendant Audio
Fi Car Audio
KnuKonceptz.co.uk
Youtube Channel
#14
Posted 23 June 2012 - 01:49 AM
Using WinISD with 1 watt input I get about 85db at 70 hz my crossover point and 75 db at 25 hz.
My amp is set to give 6db boost at 25 hz so I will actually get 81 db at 25 hz when playing hence only 4 db down.
This is pretty much what I get now with the RE SR10 but I am looking for a cleaner sound.
#15
Posted 24 June 2012 - 04:53 PM
One other sub I have been looking at is AA Havoc 12 inch, how would this be for home use in a sealed cabinet of say 1.0 cu ft with my amplifier
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Sign In
Create Account
Back to top
