keetykush
I smoked a woofer...its dead
I had a li15 awhile ago but I think I clipped it or something but it started smoking and just shat on me.
Would I just need a recone for it work again?
You don't clip a subwoofer, you clip an amplifier.
Regardless, if you let out the magic smoke then yes you will need a recone. You can take a DMM to measure the coils to verify it's toast.
However, I would HIGHLY suggest you figure out why you smoked it PRIOR TO re-installing that driver after it's fixed or another subwoofer. Because if you don't fix the problem, it's simply going to happen again.
What amplifier do you have an what are your system settings (gain, bass boost, any settings in the HU that affect the subwoofer)?
Yes sir you will just need a recone. Just give Tricia a call at 256-417-6658 and she can take your order. Thanks alot!
