Check out these other great forumsSoundSolutionsAudio.comAudioAddicts.netCarAudio-Forum.comCarAudioResources.comHomeAudioForum.net
Welcome to SSA Car Audio Forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
nuff said.
Modified Show | Custom Cars, Car Audio and Models
Upgrade Questions
  • Please log in to reply
96 replies to this topic
#1
Budah93
Budah93
    Member
  • Members
  • 283 posts
  • Gender:Male
  • Interests:Hit me on twitter: @budah93
  • Vehicle:1999 Dodge Durango
I have a 98 blazer with aftermarket electrical system. I currently have 2 SA-15s running off of a hifonics hifi1500d. I'm wondering if i would notice any difference in sound if I added another sa-15 and ran a hifonics hifi 1000d on it? I want my system to be louder but not stupid loud haha any input on upgrading amps or anything like that will be accepted!
#2
Aaron Clinton
Aaron Clinton
    SSAudio Level 16
  • 40,252 posts
  • Real Name:Aaron Clinton
  • Gender:Male
  • Interests:Performance auto's, American Speakers, my family, photography, collector amps, good music, and this place!!
  • Vehicle:Mazda P5 & RX-8
Just to understand correctly, you want to add a 3rd sub woofer with a different amplifier to the existing install?
#3
stefanhinote
stefanhinote
    what are these ohms you people talk about?
  • SSA Regular
  • 11,871 posts
  • Gender:Male
If so, bad idea.
Depending on the coil configuration on the drivers, you would be better off wiring all three together on the existing amplifier.
Before purchasing another driver, how do you feel about your current enclosure? Did you build it, or a shop? Do you know the specs as far as volume and tuning? Reason I ask is the enclosure plays a HUGE part in the end result.
2002 volvo v40
Posted Image
#4
pro-rabbit
pro-rabbit
    Regular Member
  • Vendors
  • 538 posts
  • Real Name:Dustin Cambron
  • Gender:Male
  • Interests:Owner of DC Creations
  • Vehicle:Our demo truck is a customized 1995 Jimmy.
What kind of enclosure do you have those SA15s in?
If you want more output I would get a little better amplifier and work on the enclosure to ensure you have what is working best for your application.
Posted Image
Designs, DIY Enclosures, and full custom Enclosures
#5
Notorious from FWI
Notorious from FWI
    Still a Basshead !
  • SSA Supporter L2
  • 2,731 posts
  • Gender:Male
Get 2 more SA's and another amp like your current one !
3 is not a good number Posted Image
Toyota Auris 4 doors D4D 2.0 l.
Pioneer deh9300 sd / 1 set of Focal 165KP / 12" Fi BTL N2 in a 2.5 ft3 box @ 34Hz / Sundown sax 50.4 & saz 1500 D
Secondskin Damplifier & pro / Stinger wiring and accessories / 1 Kinetic HC 1200 (2nd battery) / 0 ga grounds & power !
As Hoffman's iron law goes, Efficient enclosure, low frequency extension, or small space, pick two.
Posted Image
Martinique is a wonderful French Caribbean island, just click :http://www.martinique.org/
#6
pro-rabbit
pro-rabbit
    Regular Member
  • Vendors
  • 538 posts
  • Gender:Male
He does not have the room for 4 with out folding down the seat....well three won't even fit lol.
Posted Image
#7
Budah93
Budah93
    Member
  • Members
  • 283 posts
  • Gender:Male
lt was custom built in a shop 7 cubes. and my amp is 1 ohm stable can't run 3 subs down to 1 ohm. Reason for getting a different amp is i don't want to put 1500 rms on 1 sub hence why i want to drop down to the hifi1000. and lastly i will be able to fit all 3 w/o folding down the seats
#8
Budah93
Budah93
    Member
  • Members
  • 283 posts
  • Gender:Male
btw my subs are dual 4 ohm coils so they will be ran at 1 ohm on the hifi1500 and then i will buy a 3rd sa15 d2 and run it at 1 ohm on the hifi1000d
#9
swift
swift
    Young Grasshopper
  • SSA Regular
  • 1,247 posts
  • Real Name:Lee Swift
  • Gender:Male
You could do that if the 3rd is in its own enclosure but it would be completely stupid. No other way to say it.
07 F250 Harley Davidson crew cab, lifted on 20in Rockstars and 35's
Build motor and Suncoast Billet Trans, balding tires
*Pioneer deh-80prs
*Epicenter doors
158.7 Outlaw..............155.5 Sealed on dash
Best on old daily setup, quiet now. Soon to change
#10
Budah93
Budah93
    Member
  • Members
  • 283 posts
  • Gender:Male
i'm having a box built for 3 15s wiring 2 of them to one amp and the other to its own amp. how is that completely stupid?
#11
pro-rabbit
pro-rabbit
    Regular Member
  • Vendors
  • 538 posts
  • Gender:Male
There is very limited room in the back of those trucks. We use one as a demo truck. If you run 3 behind the back seat you will have to go pretty high to get the correct net volume which will cause loading issues.
As for your idea, it will not operate correctly at all. You should do some reading on what are some better options then what you are attempting. Personally I would get another D4 15 and run all three subs to a 2.66 load and snag a second amp and master/slave them. That would net a better overall result over what you are trying now.
While our insight is not being used here(you are doing to do it anyway), please tell me that the 3rd 15 is in its own enclosure in no way sharing space/port area with the other subs? If it is, you will find yourself with worse results then doing it the "correct" way if there is such a way as correct for this situation.
Edited by pro-rabbit, 29 June 2012 - 10:36 AM.
Posted Image
#12
Budah93
Budah93
    Member
  • Members
  • 283 posts
  • Gender:Male
The box is 10.5 cubes there for the right size and I talked to sundown and they said go for it
#13
An-i-no
An-i-no
    Nino-Wan-Kenobi
  • SSA Regular
  • 1,066 posts
  • Gender:Male
So two of the 15's will see ~750wrms and the other will see ~1000?
The one with more power will move more and cause funny shit to happen.
Come on now - this isn't the time to be critical. This weekend was their annual meet in Iowa. Instead of the usual heavy drinking and good times, ED supplied a bus and hauled everybody over to Cedar Rapids to help with flood relief. That's not the kind of thing you see every day and it speaks very well for ED and the car audio community as a whole - except that I made it up.
unfortuneately eD made the bus, so it sounded horrible, made no power and the "protect engine" light came on before it left the parking lot and wouldn't go away, and the eD tires wouldn't stick to the road for nothin'
#14
Budah93
Budah93
    Member
  • Members
  • 283 posts
  • Gender:Male
i can get an amp that does 750 rms i just throwing an amp out there for a refference
#15
ricksi30
ricksi30
    Doesn't know anything
  • SSA Regular
  • 5,800 posts
  • Real Name:Rick
  • Gender:Male
  • Vehicle:Infiniti I30
Plain and simple, it is a BAD idea. You wanted opinions and you don't like them so you argue?
Head unit: Kenwood Excelon KDC-X996
Front stage: Alpine Type X PRO mids Vifa Neo 1" silk tweeters
Component amp: PPI Bk800.4
Subs: SSA XCON 12's in 5 cubes tuned to 34hz
Sub amp: PPI Bk1300.1
Sound Deadening: Second Skin Damplifier Pro, Spectrum, and Sludge
Electrical: Stock alternator, Duralast Gold starter battery, Duralast Platinum secondary battery
Team SSA
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
#1 Car Audio Forum Since 2001!
