Followers
0
Recently Browsing 0 members
Recent Topics
- 2 comments
- 52 views
- 398 comments
- 33,056 views
- 18 comments
- 291 views
- 4 comments
- 119 views
- 2 comments
- 719 views
- 5 comments
- 1,555 views
Similar Content
By Ryann627
Thanks in advance guys.
By Aaron Clinton
We have finally released our new amp. It is a tiny tiny production run to see how people like them. Meant for the high end, SQ market, without the European price tag. If this model moves as well as I hope, it will help spawn another model in the line up soon.
https://store.soundsolutionsaudio.com/ssa-dm150-2-2-channel-amplifier-150w-x-2-ch-or-500w-x-1-ch/
Introducing the all new SSA DM150.2 amplifier. An old school approach, with updated components, for the most discerning of ears. If your front stage is lacking warmth and clarity, its time to upgrade. Our first amplifier in our high-end, sound quality, Class- A/B - Demon amplifier line. The SSA DM150.2 is the elite choice for that high end active front stage, premium passive components, and especially a sound quality sub (SSA Demon). We've incorporated direct inputs for those competition installs that use an external DSP and want their amp to be a pure gain block. Stellar looks to match the design and components. Don't let your speakers or your ears down, #levelup to the all new SSA DM150.2 amplifier.
150 Watts RMS X 2 @ 4 Ohm 500 Watts RMS X 1 @ 4 Ohm Angled Terminals for show quality installations Full Complimentary low distortion Class AB design Tiffany Style RCA connectorsFull Complimentary low distortion Class AB design Butterworth Crossover Filters for premium level performance An extra pair of input connectors for a direct input that will bypass the crossover so the amp can act as a gain block The op amps featured are TI chips w/BB technology high performance audio grade IC's Docking Pads® to reduce vibration & extend the life the amplifier DC, Short Circuit, Thermal & Overload Protection, on board fusing Diagnostic LEDs Specifications
OUTPUT POWER @ 14.4V input RMS per channel at 4 Ohms 150 W x 2 CH RMS per channel at 2 Ohms 250 W x 2 CH RMS Bridged Mono at 4 Ohms 500 W x 1 CH RMS Mono at 1 Ohm N/A INPUT SENSITIVITY 200mV - 6.0V FREQUENCY RESPONSE 10Hz - 30KHz +/- 0.5dB THD LESS THAN 0.01% S/N RATIO > 103 dB CHANNEL SEPARATION > 91 dB DAMPING FACTOR @100Hz 4 ohm > 200 CROSSOVER RANGE High Pass, 12dB/Octave 80-1.2K Hz Low Pass, 24dB/Octave 10Hz - 250Hz Subsonic N/A Variable Bass Boost (0 to +12 dB bass boost at 45 Hz) Yes Phase Shift (0 - 180 degrees) No Fusing 3 x 40A Size (L x W x H) in 16.4 x 8.9 x 2.2 -
By Aaron Clinton
I am working to expand our amplifier offerings, while staying high quality, somewhat unique, and affordable.
First up looks like a class-A/B 6 channel. No crossover network, individual gains, 150watts x 6, will keep footprint as small as possible for the design, similar appearance to the current models. Feeling out interest as it will effect the total amps I put into production.
As a side note, I am considering a 2-channel of the same line, but the demand for 2 channels right now are so low. Would not really want to build them if they are going to sit for a while.
Just curious on any input before I get production going.
By Wolfram Audio
Now available on the SSA store!
I do NOT check PMs on here. For any questions, email colin@wolframaudio.com
Wolfram Audio W-3000.1:
RMS Power @ 1 Ohm : 3,000 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 2,000 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 1,150 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Linked) : 6,500 Watts x 1 Channel (14.4v) Frequency Response : 10hz~350hz (+/-1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% Low Level Input (Gain) : 8V - 200mV Low Pass Filter : 30Hz - 250Hz Bass Boost : 0 ~ 12 dB Subsonic Filter : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Linkable) : Yes Recommended Fuse Rating : 300 Amps 1/0 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
Wolfram Audio W-1500.1:
RMS Power @ 1 Ohm : 1,600 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 900 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 530 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Strapped) : 3,200 Watts x 1 Channel (14.4v) Frequency Response : 10Hz - 350Hz (+/- 1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% RCA Line Output : Yes Low Pass Filter : 30Hz - 250Hz Bass Boost @ 45 Hz : 0 ~ 12 dB Subsonic Filter : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Linkable) : Yes Fuse Rating : 150 Amps (Linked: 300A) 1/0 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
Wolfram Audio W-600.1:
RMS Power @ 1 Ohm : 700 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 380 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 200 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Strapped) : 1,400 Watts x 1 Channel (14.4v) Frequency Response : 10Hz - 350Hz (+/- 1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% RCA Line Output : Yes Low Pass Filter : 30Hz - 250Hz Bass Boost : 0 ~ 12 dB Subsonic Filter @ 24 dB Slope : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Strappable) : Yes Fuse Rating : 30A x2 4 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
Wolfram Audio W-125.4:
RMS Power @ 2 Ohms : 175 Watts x 4 Channels (14.4v) RMS Power @ 4 Ohms : 125 Watts x 4 Channels (14.4v) RMS Power @ 4 Ohms (Bridged) : 330 Watts x 2 (14.4v) Frequency Response: 15hz to 35khz Low Level Input Adjustment: 0.2v to 8v Signal to noise Ratio: >90 dB Minimum Impedance: 2 Ohm Low Pass Filter: 50hz to 500hz (500hz to 5khz [x10]) High Pass Filter: 50hz to 500hz (500hz to 5khz [x10]) T.H.D. Continuous @ 4ohm : 0.05% Operating Voltage : 10v ~ 16V Fuse Rating : 40A x2
Recent YouTube Posts
