Shogen
This is kinda against the rules, Sorry but need help....
So I know, I know.... "no VS threads" .... Not totally sure whether this completely falls under that but here we go....
So, I've realized I made the wrong decision for tweeters in my car... LPG aluminum tweets .... Cannot be crossed lower than 4k and that is with lower power/lower volume.... 5k is much better.... This will not work for me anymore... I've learned that now and need to move onto something better for me...
Currently using my Pioneer HU for active setup and going through a MB Quart 4.125 ....
I am looking at these guys:
Vifa NE25VTS-04
Specifications: • Power handling: 80 watts RMS/160 watts max • VCdia: 1" • Impedance: 4 ohms • Re: 3.1 ohms • Frequency response: 777-25,000 Hz • Fs: 777 Hz • SPL: 92.0 dB 2.83/1m • Dimensions: Overall diameter: 2.6", Cutout diameter: 1.9", Depth: 1.6"
Morel CAT 378
Specifications: • Power handling: 200 watts RMS/280 watts max • VCdia: 1-1/8" • Impedance: 8 ohms • DC resistance: 5.2 ohms • Frequency response: 1,800-20,000 Hz • Fs: 700 Hz • SPL: 93 dB 1W/1m • Dimensions: Overall diameter: 3.70", Cutout diameter: 2.83", Depth: 2.32"
I have been eyeballing the Vifa for quite some time now but not pulling the trigger just yet.... The Morel came up in another thread and I saw that the specs were similar but it's advertised as a sort of "hyrid" tweeter .. My biggest problem is not install or anything... But which would be louder on the power given... Not that I want to be heard from farther away but I want to have more headroom as far as EQ and balancing without much struggle... I'm looking to improve the clarity and range...I do not have a specific driver to match up with it yet but any suggestions would be great... And wondering if I can fit an 7-8" mid to pair with it... .Help I'm lost....
Music tastes: Pretty Lights Masta Ace K-OS John Legend
Robin Thicke Kalimba Eptic Aloe Blacc
Arrested Development Camp Lo The Pharcyde Slick Rick Putamayo Los Compadres Dir En Grey Gorillaz June
Highly suggest you guys check out the music I listen to so you know what I'm after.... It's really wide and I'd like to be able to play it all....
Any and all help much appreciated....!!!
Edited by Shogen
Go Vifa.......Less or a wallet rape than Morel usually........easier to un-fuck a possible mistake.
J
J
lol... was kind of thinking the same but not so simply put... hahahaha
Sorry bro. Today has been a shittastic day and I am in a 'heavy drinking on no food' mood. So needless to say the filter for my brain to mouth.hands has been disabled.
J
J
no worries man... I got a laugh at it... What you drinking anyways? lemonade?
No idea on either of those drivers, but your going to need to chose a woofer as well.
Check out the peerless sls, exodus ex-anarchy.
There's also a seas prestige with a reed cone 7" that comes in a kit with some seas prestige tweeters, so you already know those drivers can mate up well depending on the mounting axis and install.
6"-7" is probably about it to mate with a large format tweeter. 8" and upwards is going to be a bitch to mate.
Edited by stefanhinote
madisound??? Yea, I know I'll have to mate to woofer with it... I'm not specific on that... Since I mainly want to get a good tweeter that can go lower.... Thanks, I'm gonna look at those
http://www.madisoundspeakerstore.com/seas-woofers-6-7/seas-prestige-er18rnx-h1456-7-reed-paper-cone-woofer/
http://www.madisoundspeakerstore.com/seas-soft-dome-tweeters/seas-prestige-27tdfc-h1189-textile-dome-tweeter/
Yeah. I would definitely do some research though, as there may be other drivers better suited.
These: Seas Reed paper cone
Thread exemplifies why the rules are written like they are. Neither of those tweeters are logical choices for you. Has nothing to do with your "wide" selection of tracks there either.
I knew I probably shouldn't have narrowed it down to just those two tweets but it seems that my current setup I'm missing more than I should.
Now excluding those tweeters as my only options, what characteristics should I be looking for in as tweeter? Lower/lowest FS? 4 ohm or 8 ohm? Highest sensitivity? I'm fully aware of compromise so I need to know if I'm just looking at this the wrong way. I'm willing to give up "loudness" for the rabbits I need our want. I can adjust the rest(EQ) to even out the sound.
I wouldn't pay too much attention to the Re since tweeters can be loud on little power. Sensitivity somewhat similar thinking process. I wouldn't rely on EQ too much, it's nice for fixing small stuff, but don't want to be super reliant on it. Fs isn't a bad idea if your looking to cross in some frequency range, and the fs happens to be above it. Also nice if graphs are supplied with the T/S specs, or plug the specs into a modeling program.
Other then that I don't have much good advise on picking a tweeter for xxx usage. For me it's sorta pissing in the wind. :P
You should start the thread like it should have been. With your goals, desires, needs, mounting locations, power, processing, and even better to describe what you don't like about what you have and why. Then we can help narrow that down.
As for what to look for, you need to pretty much look at ALL of the parameters. If they don't mean anything to you then it's best to ask for help in searching.
Well I've been talking with Randy and he made a few suggestions with my current setup to try as far as settings for the tweeter. So I crossed them at 2.5k and I EQ'd a bit at 3.15k since it was piercing. Now I have to aim these guys better and see where I go from there. If I'm not satisfied then I'm gonna look at getting something new and trying it out.
That's pretty much what I was looking for as far as help goes. I just posted those tweeters to show what I have been looking at so someone could tell me if they are what I'm looking for. Thanks.
I know what the specs are and I was looking at the graphs as well to give me an idea of usable frequency slightly off axis since I know I can't or might not have them dead on axis. I listed what I didn't like about my current setup. But it's mainly stage height I guess. It's almost as if the music is coming from below me at all times. I mean it's clear but didn't sound right. The adjustments I did have helped but I'm gonna see if aiming it makes it better. But who knows.
J
LOL Rum and Dr. Pepper.
J
Other then that I don't have much good advise on picking a tweeter for xxx usage. For me it's sorta pissing in the wind. tongue.png
That doesn't help or describe anything.
-aiming, location, driver, processing, what you are blending it with, and continue.
Actually you said you didn't like the LPG's since you had to cross them high...and that you want something better.
I find that amusing. That is a stellar tweet. If you don't like it, you should blame the install not the tweeter. Or at least describe what you don't like about it. Just playing lower you can grab anything with a lowish FS, but don't go nuts picking only based on that.
Thank you. So I've not attacked install yet but I'm going to now. They did sound great to me at first but I'm not sure what changed. But at higher than moderate listening levels they seem to break up easily unless crossed at 5k which I believe is making the sound almost lost. I'm assuming that I possibly had them crossed too low and it messed up the sound. I also don't have a mid yet which I'll get into another time.
I just dropped the crossover point to 2.5k which made it louder and brought the music up higher. But it sounded way to screechy. So I adjusted 3-5k down some and it seemed to tame it quite a bit. I'm thinking that I might have to do the same at 10k and 12k.
I'm using my p880 and an acoustic 4x60.
Double post FTL
Edited by Shogen
5k, weird. What slope? Although even with something pretty shallow I'm still surprised.
24db as I didn't want it to play lower than 5k at all. :-
That's bizarre.
Yes. It is. As I got this tweeter under the assumption of my research where users were able to cross down to 2.5k. It's there now and I'll keep playing with the EQ. I'm going to build some temporary pods so I can aim the tweeters and see if that changes much.
    1. Recent Topics
        • 1 comment
        • 0 views
        • 3 comments
        • 62 views
        • 398 comments
        • 33,158 views
        • 18 comments
        • 299 views
        • 4 comments
        • 134 views
        • 2 comments
        • 721 views
  • Similar Content
    • By Wolfram Audio
      Now available on the SSA store!
      I do NOT check PMs on here. For any questions, email colin@wolframaudio.com
      Wolfram Audio W-3000.1:
      RMS Power @ 1 Ohm : 3,000 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 2,000 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 1,150 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Linked) :  6,500 Watts x 1 Channel (14.4v) Frequency Response : 10hz~350hz (+/-1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% Low Level Input (Gain) : 8V - 200mV Low Pass Filter : 30Hz - 250Hz Bass Boost : 0 ~ 12 dB Subsonic Filter : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Linkable) : Yes Recommended Fuse Rating : 300 Amps 1/0 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-1500.1:
      RMS Power @ 1 Ohm : 1,600 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 900 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 530 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Strapped) :  3,200 Watts x 1 Channel (14.4v) Frequency Response : 10Hz - 350Hz (+/- 1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% RCA Line Output : Yes Low Pass Filter : 30Hz - 250Hz Bass Boost @ 45 Hz : 0 ~ 12 dB Subsonic Filter : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Linkable) : Yes Fuse Rating : 150 Amps (Linked: 300A) 1/0 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-600.1:
      RMS Power @ 1 Ohm : 700 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 380 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 200 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Strapped) : 1,400 Watts x 1 Channel (14.4v) Frequency Response : 10Hz - 350Hz (+/- 1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% RCA Line Output : Yes Low Pass Filter : 30Hz - 250Hz Bass Boost : 0 ~ 12 dB Subsonic Filter @ 24 dB Slope : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Strappable) : Yes Fuse Rating : 30A x2 4 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-125.4:
      RMS Power @ 2 Ohms : 175 Watts x 4 Channels (14.4v) RMS Power @ 4 Ohms : 125 Watts x 4 Channels (14.4v) RMS Power @ 4 Ohms (Bridged) : 330 Watts x 2 (14.4v) Frequency Response: 15hz to 35khz Low Level Input Adjustment: 0.2v to 8v Signal to noise Ratio: >90 dB Minimum Impedance: 2 Ohm Low Pass Filter: 50hz to 500hz (500hz to 5khz [x10]) High Pass Filter: 50hz to 500hz (500hz to 5khz [x10]) T.H.D. Continuous @ 4ohm : 0.05% Operating Voltage : 10v ~ 16V Fuse Rating : 40A x2
    • By Aaron Clinton
      A few years late, but we are finally getting a very nice tweeter going that is worthy of being a part of the SSA line.  The pictures below show the prototypes, they are really attractive in person and will, in production form, bare the SSA logo.  See the attached files for the 4 and 8 ohm versions.  They are quite smooth to my ear (aka not super bright like some metal dome tweets can be) and blend well with the Evil6.5's (vital to the design).  These are not a PA style, 'screamy' tweet, these are meant for sound quality first and foremost.  Possible future home audio plans.  Pricing is not set just yet. These will be sold as a pair.
      Some quick points of info:
      28mm Silk Dome, Large Roll Surround Aluminum Faceplace and Housing Sound Transparent Grill Low Fs. for flexibility in both Home & Car Neo Motor with Shallow non-Resonant Chamber 61.9mm (2.44") dia. flange, 21.5mm (.85") depth 65 watts rms
    • By Tirefryr
      Selling off everything but a few things.  All items are BNIB unless otherwise noted.  I am NOT interested in trades, sorry.
      SOLD!
    • By Godsmack
      - 27 Raptor 1/0 AWG Ring Terminals $20
      - Install Edge 5 pack remote wires [IEC P 3x5-6] 6 feet $15
       - 2 packs Install Edge 6.6 ft RCA cables [IRC GAC2] $7 each or $10 for both
       - 8 4 way Knu Konceptz 1/0AWG in 4 8AWG out $8 each or all for $55
       - 50ft 16AWG speaker cable spool $5
      - Install Edge Remote wire [IEC P18 X5-6] 18AWG $5
      - Knu Konceptz kolossus Flex 1/0 AWG Red power cable 44 ft $125; 8ft $25; 10.5ft $35 (all for 175)
       - 13 ft Q power 1/0 AWG Super Flex on spool $25; 15ft on spool $30
      - Approx 400 ft 16AWG Q power speaker wire on spool $40
       - Stinger 150 amp circuit breaker $25
      - 6 Install Edge Speaker Savers [IEC CAP 133] $6 per pack or all 6 pairs for $30
       - 2 2packs Rockford Fosgate 8AWG Ring Terminals $5 each or both for $7.50 -
       2 Rockford Fosgate Side mount battery terminals $9 each or both for $15 -
       Rockford Fosgate 2 output top mount battery terminal $10
      - Rockford Fosgate RCA coupler $5
      - Rockford Fosgate 10 AWG Amp kit (no RCA wires) 17 ft $30
       - Rockford Fosgate pack of 2 100amp MAXI fuses $10
       - Knu Konceptz Negative top mount terminal $10 -
      Metra Honda Harness [BB-WHHDI] $10 -
       Metra Inpala/Monte Carlo [XSVI-2105] $35 - Metra GM 88-05 22 pin harness [70-1858] $5
      - Pair of Dynex square box terminal cups $2
       - Dynex OEM Ford Radio removal tools $8
      - Stinger Blue HPM voltage meter [SVMB] $15
      - Tsunami Marine ANL fused distro, 1/0 AWG IN, 2 1/0AWG out $20
       - Generic ANL fuse holder, no cover $5 -
       Mini RCA stereo Y cable $2 - 14ft Raptor RCA cable $10
      - 16 ft Monster RCA cable $20 -
       Stinger 1/0 AWG ring terminal $4 -
       2 2male 1female RCA adapter $5 each or both for $7.50
      - 1 RCA to RCA dual male wire 9" $2 -
       2 Street wires RCA cables in bags 19.69 ft [ZN1260] $7.50 each or both for $10 -
       ANL fuses, 2 200amp, 4 250 amp, 2 300 amp, 4 100 amp, 2 500 amp. 500 amp are $5 per pair others are $3 per pair, or all for $30
      Total price when purchased individually: $761 Buy the whole lot: $650
      Open to trades, Nikon FX lenses and other photography equipment are of special interest. Feel free to contact with questions. Thanks for looking!!
      - Viper 500.4, missing xo cover, and right mounting feet. $300
      - MTX Road Thunder XO's for componants. $20 for the pair
      - Eclipse SC-8355/8365 XO's for componants $50 for the paid
      - Phoenix Gold Octane 4.0 2 amp. $150
      - JL Audio 500/1. Missing some side screws. Not 100% on what the guts condition is, and last I remember looking it was fine. $125
      - Digital Designs DD C1. $140
      ORIGINAL RE XXX 12" to come, as well as more amps. I'd love to sell everything as a lot, and am willing to make deals. Only thing trade wise I would be after is Nikon FX lenses, but feel free to offer up. Pics are all on the link below.
  • Recent YouTube Posts
