Shogen
This is kinda against the rules, Sorry but need help....
Yes. It is. As I got this tweeter under the assumption of my research where users were able to cross down to 2.5k. It's there now and I'll keep playing with the EQ. I'm going to build some temporary pods so I can aim the tweeters and see if that changes much.
Where are they mounted now, and do they screech at moderate volume?
Right now up on the dash. The passenger side it's aimed at me directly. The driver side is aimed slightly off axis and more towards the passenger side. I'm using this mount right now. http://www.madisoundspeakerstore.com/speaker-mounts/lpg-wedge-mount-hinged/
They do screech, with certain singers.
Edited by Shogen
Someone broke into your car, and swapped the tweets. :peepwall:
Huh? No fucking way. That is not the strength of that tweet. 4k with a 2nd order is okay, but anything else is off. Don't see how you could have found anyone who said otherwise. Obviously didn't ask here either as I don't miss those sort of threads.
Right now up on the dash. The passenger side it's aimed at me directly. The driver side is aimed slightly off axis and more towards the passenger side. I'm using this mount right now. http://www.madisound...e-mount-hinged/
Also crazy to use that tweet on axis, not sure why you bought it.
I'm still gonna have to work on install. But I know now, after owning them that they don't do well under 4-5k. That's why I'm looking to replace them although they sound ok crossed that low at lower/moderate volume.
I don't think install will correct it much, but worth some experience. So, is there anything I should look at that may give me better sound or anything that plays lower than the lpg will suit my needs better? I don't what to look at as a start but the vifa tweeters looked great on paper.
There are plenty of drivers that allow you to run a tweeter at 4k+.
Why do you think the Vifa looks "great on paper"?
As far as running lower than I'm currently able to. The off axis response and powering requirements aren't very much. That looks good for my purpose or my goals. My only real attack is install. Unless I'm told otherwise,I could be wrong about how the vifa will sound. But it hasn't been said whether that can possibly be a good driver for me or eluded to other possibilities.
I already answered. If you are going to look at Fs and draw a driver out of a hat there are WAY more options than 2. If you actually select a driver i dont see how that'd be the choice
Maybe I should ask more straight forward.... In your opinion, for what I've stated as my goals, what should I look into? Is there anything you think fits my needs better? And could you tell what driver(s) I should look at?
What mids are you using?
No mids yet. Currently using my 6x9 cuz it's all I have. I was gonna throw in the mids from my edesign set just for the time being.
No mids and u don't like the lpg, lol. You haventbgiven anywhere near enough info to begin shopping. Atm what is best for you is a passive comp set
I am in the process of getting my front stage done. Lol Hence why I started this thread.
I don't want to go passive anymore. Want to "build" my front stage.
Your opinion has been noted though.
Edited by Shogen
In my humble opinion I think you should focus 100% of your attention on the mids right now. Tweeters are easy to pick out and implement, mids selection is another story.
If you are running a two-way mids will become more of a compromise. You can either have good midbass extension or good high end extension. Really really hard to get both. Midbass can be mostly handled with your subwoofer setup if needed. Then you could run a 4" mid that can easily play to 4k then you could buy a smaller tweeter. Or buy a bigger mid that can play the midbass range but then you will need a larger tweeter to effectively play down to 2-3Khz.
*Generally* Small format tweets mostly need crossed no lower than 4khz with a 3rd-4th order slope. Large format tweeters can be crossed much lower with a 1-2nd order slope. Mounting maybe become an issue with large format tweeters.
Thanks
As far as mids go, I'd be happy with something that could effectively down to 100Hz. I don't think that is too much to ask if a mid. But that means a tweeter that can play lower. The mids I've looked at were 6-7"and graphs showed them to play down to the 70s. Which i wouldn't be doing.
There are far less compromises in finding a tweeter to go with a mid than the other way around.
Choose a mid first, then look for tweeters.
Okay .then I shall return to this thread afterwards. Thanks for the words everybody. This will help greatly. :-)
The Vifa's I posted are very similar to the ones I have. I'm crossing mine at 2.5 with a 24 db slope running active off 2 channels of my ESX Q 120.4. They take a great deal of power, get incredibly loud and crystal clear and I barely touch my eq in the tweet range. Right now I'm down 1 notch at 8k. I suspect that it's just a sensative spot in my hearing. They hold very true to the published graphs. I guess if I could find a downfall it would be that they really fall off the further they are off axis. If you can keep them within 30 degrees or so it's not an issue. I would highly doubt you'll find a better sounding tweeter in the price range.
I don't like the 25. And yes, there are others that can be "better" in the price range but we've still been given NO information so shopping or recommending a tweet now is wrong and misleading. WAY too early. :(
I don't like the 25. And yes, there are others that can be "better" in the price range but we've still been given NO information so shopping or recommending a tweet now is wrong and misleading. WAY too early. sad.png
You're entitled to your opinion and I have the same priveledge. We are all here to speak our opinion.....And.....after 4 pages if i nor anyone else can give a solid reccomendation based upon experience perhaps I'm not aware of the proper forum etiquette here.
so independent of any goals or other equipment details your carte Blanche recommendation is the xt25...well that makes sense
After 4 pages we still don't even know something as basic as what mid the tweeter will be mated with. We could all "recommend" dozens of products, but those recommendations are useless as there is extremely limited information to go on so it's all just throwing darts and blindly tossing out model numbers......which isn't helpful or productive in the slightest.
  • Recently Browsing   0 members
    1. Recent Topics
        • 19 comments
        • 320 views
        • 3 comments
        • 75 views
        • 398 comments
        • 33,297 views
        • 4 comments
        • 155 views
        • 2 comments
        • 733 views
        • 5 comments
        • 1,582 views
  • Similar Content
    • By Wolfram Audio
      Now available on the SSA store!
      I do NOT check PMs on here. For any questions, email colin@wolframaudio.com
      Wolfram Audio W-3000.1:
      RMS Power @ 1 Ohm : 3,000 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 2,000 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 1,150 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Linked) :  6,500 Watts x 1 Channel (14.4v) Frequency Response : 10hz~350hz (+/-1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% Low Level Input (Gain) : 8V - 200mV Low Pass Filter : 30Hz - 250Hz Bass Boost : 0 ~ 12 dB Subsonic Filter : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Linkable) : Yes Recommended Fuse Rating : 300 Amps 1/0 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-1500.1:
      RMS Power @ 1 Ohm : 1,600 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 900 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 530 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Strapped) :  3,200 Watts x 1 Channel (14.4v) Frequency Response : 10Hz - 350Hz (+/- 1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% RCA Line Output : Yes Low Pass Filter : 30Hz - 250Hz Bass Boost @ 45 Hz : 0 ~ 12 dB Subsonic Filter : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Linkable) : Yes Fuse Rating : 150 Amps (Linked: 300A) 1/0 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-600.1:
      RMS Power @ 1 Ohm : 700 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 380 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 200 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Strapped) : 1,400 Watts x 1 Channel (14.4v) Frequency Response : 10Hz - 350Hz (+/- 1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% RCA Line Output : Yes Low Pass Filter : 30Hz - 250Hz Bass Boost : 0 ~ 12 dB Subsonic Filter @ 24 dB Slope : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Strappable) : Yes Fuse Rating : 30A x2 4 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-125.4:
      RMS Power @ 2 Ohms : 175 Watts x 4 Channels (14.4v) RMS Power @ 4 Ohms : 125 Watts x 4 Channels (14.4v) RMS Power @ 4 Ohms (Bridged) : 330 Watts x 2 (14.4v) Frequency Response: 15hz to 35khz Low Level Input Adjustment: 0.2v to 8v Signal to noise Ratio: >90 dB Minimum Impedance: 2 Ohm Low Pass Filter: 50hz to 500hz (500hz to 5khz [x10]) High Pass Filter: 50hz to 500hz (500hz to 5khz [x10]) T.H.D. Continuous @ 4ohm : 0.05% Operating Voltage : 10v ~ 16V Fuse Rating : 40A x2
    • By Aaron Clinton
      A few years late, but we are finally getting a very nice tweeter going that is worthy of being a part of the SSA line.  The pictures below show the prototypes, they are really attractive in person and will, in production form, bare the SSA logo.  See the attached files for the 4 and 8 ohm versions.  They are quite smooth to my ear (aka not super bright like some metal dome tweets can be) and blend well with the Evil6.5's (vital to the design).  These are not a PA style, 'screamy' tweet, these are meant for sound quality first and foremost.  Possible future home audio plans.  Pricing is not set just yet. These will be sold as a pair.
      Some quick points of info:
      28mm Silk Dome, Large Roll Surround Aluminum Faceplace and Housing Sound Transparent Grill Low Fs. for flexibility in both Home & Car Neo Motor with Shallow non-Resonant Chamber 61.9mm (2.44") dia. flange, 21.5mm (.85") depth 65 watts rms
    • By Tirefryr
      Selling off everything but a few things.  All items are BNIB unless otherwise noted.  I am NOT interested in trades, sorry.
      SOLD!
    • By Godsmack
      - 27 Raptor 1/0 AWG Ring Terminals $20
      - Install Edge 5 pack remote wires [IEC P 3x5-6] 6 feet $15
       - 2 packs Install Edge 6.6 ft RCA cables [IRC GAC2] $7 each or $10 for both
       - 8 4 way Knu Konceptz 1/0AWG in 4 8AWG out $8 each or all for $55
       - 50ft 16AWG speaker cable spool $5
      - Install Edge Remote wire [IEC P18 X5-6] 18AWG $5
      - Knu Konceptz kolossus Flex 1/0 AWG Red power cable 44 ft $125; 8ft $25; 10.5ft $35 (all for 175)
       - 13 ft Q power 1/0 AWG Super Flex on spool $25; 15ft on spool $30
      - Approx 400 ft 16AWG Q power speaker wire on spool $40
       - Stinger 150 amp circuit breaker $25
      - 6 Install Edge Speaker Savers [IEC CAP 133] $6 per pack or all 6 pairs for $30
       - 2 2packs Rockford Fosgate 8AWG Ring Terminals $5 each or both for $7.50 -
       2 Rockford Fosgate Side mount battery terminals $9 each or both for $15 -
       Rockford Fosgate 2 output top mount battery terminal $10
      - Rockford Fosgate RCA coupler $5
      - Rockford Fosgate 10 AWG Amp kit (no RCA wires) 17 ft $30
       - Rockford Fosgate pack of 2 100amp MAXI fuses $10
       - Knu Konceptz Negative top mount terminal $10 -
      Metra Honda Harness [BB-WHHDI] $10 -
       Metra Inpala/Monte Carlo [XSVI-2105] $35 - Metra GM 88-05 22 pin harness [70-1858] $5
      - Pair of Dynex square box terminal cups $2
       - Dynex OEM Ford Radio removal tools $8
      - Stinger Blue HPM voltage meter [SVMB] $15
      - Tsunami Marine ANL fused distro, 1/0 AWG IN, 2 1/0AWG out $20
       - Generic ANL fuse holder, no cover $5 -
       Mini RCA stereo Y cable $2 - 14ft Raptor RCA cable $10
      - 16 ft Monster RCA cable $20 -
       Stinger 1/0 AWG ring terminal $4 -
       2 2male 1female RCA adapter $5 each or both for $7.50
      - 1 RCA to RCA dual male wire 9" $2 -
       2 Street wires RCA cables in bags 19.69 ft [ZN1260] $7.50 each or both for $10 -
       ANL fuses, 2 200amp, 4 250 amp, 2 300 amp, 4 100 amp, 2 500 amp. 500 amp are $5 per pair others are $3 per pair, or all for $30
      Total price when purchased individually: $761 Buy the whole lot: $650
      Open to trades, Nikon FX lenses and other photography equipment are of special interest. Feel free to contact with questions. Thanks for looking!!
      - Viper 500.4, missing xo cover, and right mounting feet. $300
      - MTX Road Thunder XO's for componants. $20 for the pair
      - Eclipse SC-8355/8365 XO's for componants $50 for the paid
      - Phoenix Gold Octane 4.0 2 amp. $150
      - JL Audio 500/1. Missing some side screws. Not 100% on what the guts condition is, and last I remember looking it was fine. $125
      - Digital Designs DD C1. $140
      ORIGINAL RE XXX 12" to come, as well as more amps. I'd love to sell everything as a lot, and am willing to make deals. Only thing trade wise I would be after is Nikon FX lenses, but feel free to offer up. Pics are all on the link below.
  • Recent YouTube Posts
