wcefai
Fi's new website
I noticed the tech section is gone. Where it tells what options does what. Besides that I think its nice.
I know they had to hurry up and release this site earlier then expected, there are still a few kinks to work out but scott, shawn and crew are working on it still
i like it alot old one wasnt bad though both cool layouts.
Yes the new site is a great improvement.
still have some stuff written backwards lol, was bummed to see they upped the recone i need by $30 tho D=. no matter, i love the new website, also is there any update about the new version of the X series?
Cost of parts goes up and they've ate it for a LONG time..never updated the pricing accordingly.
All of the stuff on the recones is written backwards for copyright reasons.
whoa i havent been on Fi's website in a while so this is definitly news to me
their new layout is nice
also..... somehow the box sizes aren't there anymore either.... looking at SSDs....... 12" x 2 .....
Sorry guys, all of that information will be in the second phase of the site that was supposed to be launched along side of the store, but we had to rush the store out the door due to technical issues with the old store.
Shouldn't be long for a whole new Fi experience online.
No worries... Would be nice if someone from Fi could post of box recommendations on the forum so we could get the info at least... Or if they've given that you Mark for creating that portion of the site then maybe you could just paste it on the forum??? Just a suggestion ... Thanks for the work though!
All box size recommendations are there.
SSD Series: 10”, 12”, 15”, and 18”
Dual 1 and Dual 2 Ohm
Cast basket
Wrap around gasket
Kraft pulp fiber reinforced cone
Single layer wide foam surround
Push terminals
Extra heavy lead wire
FEA optimized motor
3” diameter 4 layer coil
Single high grade magnet
Triple progressive spiders
Optional Heli-cool system
SSD12 DUAL 1 | DUAL 2 Fs: 30.1 Hz | 30.1 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 7.65 | 7.65 Qes: .37 | .37 Qts: .36 | .36 Mms: 248g | 248g Cms: 0.11mm/N | 0.11mm/N Sd: 480cm^2 | 480cm^2 Vas: 36.5 l | 36.5 l Spl: 86.1dB 1W/1m | 86.1dB 1W/1m Bl: 13.1 N/A | 18.7 N/A Xmax: 20mm Rms: 1000W Sealed box: .7-1.2 cuft Ported box: 1.8-2.5 cuft @ 33Hz Sub OD: 12.500” Cut ID: 11.125” Mounting depth: 6.500” Displacement: 0.14cuft
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
Shyt.. That run-on sentence mad it hard to see... Thanks for that Swift... I noticed the T/S there but didn't see that mixed in.... Lifesaver!
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
Sorry it doesnt read that way on the site, but if you click on the actual sub listing the recommendations are at the bottom in a god layout. Confused me at first too with the quick look and took time for me to find it as well. Maybe if by clicking the picture or the subject matter about the sub it would pull up the same detail it would be easier for the shopper. But the site is a HUGE improvement as before.
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
lol... I thought it was like that on the site... I found it right after... lmao.... Yes the site overall is way nicer....
