ryann
[noob] recommendations for camaro with thunderform?
Hello! I have a 2000 Camaro with a thunderform 10" sub box (http://thunderforms...._2002/show.html).
I was about to get some crappy pioneers but then I came across SSA and am considering the DCON, Skar VVX, maybe a GCON, or something one of you might recommend.
My concern is that because the box is so limited (.6 ft3 sealed) if these subs will still sound any good, because I understand that they are engineered to be tuned and be in the right box.
I'd be getting a new amp to btw, i'm thinking the Audiopipe APSM-1500.
Let me know if you recommend a sub or if you think one of these wouldn't be a good choice for me. Any feedback would really help! smile.png
Edited by ryann
you will need to check the mounting depth but i would go with a Gcon or Icon. a Dcon would be great too but it sounds like you want to run more power. but you didn't really state your goals yet??
the skar would a bad choice in general. also, the audiopipe probably isn't the best option either. boston acoustic amps are on sale right now. i'd suggest this, http://www.sonicelec...s-GT-2200.html. 900 @ 2ohm bridge will be perfect for a Gcon or Icon.
cheaper but a little less power, http://www.sonicelec...cs-GT-2125.html
Edited by lithium
You could always try to build a box that fits in the ttop storage area. Or even try to use the pocket on the left side of the trunk to make a little more space..60 is kinda small for anything your trying run 1500w to.
The mounting depth on the thunderform box is 7 3/4" so it will fit all of the subs mentioned so far.
My goal is to get some clear, deep, hard hitting bass for listening to metal and electro.
I am most concerned with sound quality over just making my windows rattle, which is why i decided to consider these subs instead of mainstream big brands.
And it sounds ironic since im trying to do it with the tunderform box but thats just because I already have that box.
I picked the 1500 amp because with the gcon (750w) i can run D4 so the amp puts out 1000 or with the DCON (300w) i could run the S4 so the amp puts out 500, and ive read 4ohm sounds best.
I'm curious what makes the skar a bad choice in general?
Is it better to use a bridged 2ch amp instead of a mono? or is it just easier to find a better quality amp for cheaper that way? because i was also looking into the AQ1200D
I already have the tunderform box, and im trying to keep using it because i need the rest of the trunk space for the car's t-tops.
Edited by ryann
My only concern is that since these are "tuner" subs, by not putting them in an optimal box configuration that they suddenly may not perform as good as mainstream subs designed to work in varying situations like perhaps the alpine swr-10d4 or jl 10w3v3 or pioneer ts-w2502.
If you guys think that they will still perform on par or better, then I'll be getting a dcon or gcon.
Since my car is a hatchback, it will get plenty loud inside regardless, so i'm more interested in the bass sounding tight.
Go with the GCON, it performs better in sealed enclosures.
the skar isn't good sealed. Gcon would be better (simply look at the TS parameters). Also consider build quality.
mono vs 2 channel isn't an issue. the BA puts out plenty of power for what you need. the AQ would be a waste because the extra power wouldn't make an audible difference.
Mainstream brands or not, all subs are made to be played in in their right enclosure. The brands you find here give you more info about how to run their subs, but the mainstream subs are the same.
It would be nice if you could find more room for the enclosure.
But if you can go with an SSA Gcon : go for it. You'll love it. I had an Icon and it was monderful !!!
Ordered the GCON!! cant wait to get it, but the build wait time is good since now I have to look for an amp to power the sub. I'm considering the one's recommended by members above, and also doing some browsing of my own.
    1. Recent Topics
        • 397 comments
        • 32,980 views
        • 1 comment
        • 47 views
        • 4 comments
        • 112 views
        • 17 comments
        • 282 views
        • 2 comments
        • 717 views
        • 5 comments
        • 1,550 views
  • Similar Content
    • By spanky1975
      I am thinking about building a T-line for my 3 SSA DCON 12's. Has anybody here tried it or have any experience with T-lines?
      If anybody wants to give a shot at helping with the design it would be great.
      Before you comment that "The box will be huge!" , yes I know. Thanks.
    • By altoncustomtech
      Okay, we were finally able to get the vehicle that will be replacing the van as our daily driver.  I found a nice 2010 Traverse AWD with everything the wife wanted in it and a little more with decent miles on it and I even got a decent deal on it.  Now, the wife realized before we even got serious about shopping for one that we should probably tone down the size of the install in the new vehicle.  While she was/is still wanting some good sounding speakers and some bump going to the the size and extent of the build in the van was more than we need for this one.  One of the biggest reasons for that was simply because of the damage the Q's caused the van.  Before I installed them it was QUIET, not one interior panel rattled or made noise, not hardly a hint of sheet metal rattling could be heard.  At this point now not only is there a great deal of noise coming from the interior panels (particularly in the rear) but the Q's even managed to tear a spot welded seam in the floor of the van loose.  We simply don't want to repeat that in the new one.
      For this build we're looking at something smaller, possibly along the lines of a pair of 10's if the space is right, single 12, etc.  Something like the DCON, GCON or ICON come to mind, SSD's, possibly even IA or something else I've not got a chance to try yet as well.  We'll be running 1,000 to 1,500 watts on the subs and no more than that at all.  What goes in will depend completely upon the space available and which sub choice will work best with that space.  I'm going to try to keep the rear of the vehicle as usable as possible so I'm probably going to be building an enclosure with the subs firing downward and the port to the side.  The enclosure will likely consume all the space available on the width and depth behind the 3rd row seat and my limiting factor will be that we're trying to keep the enclosure height to about half the total height of the 3rd row seat.
      The wife wants another Kenwood HU so we'll likely be ordering a DDX491HD and a Maestro RR integration unit this weekend for the source and to keep all the factory wheel functions and such.  I'm looking to use a PPI P900.4 for the highs and a similarly sized subwoofer amp to run the subs and those will be tucked away in the storage compartment under the floor in the rear with added ventilation if necessary.
      That brings me to my biggest frustration with this build, lol.  Before we got serious about shopping for a vehicle the wife was COMPLETELY on board for me doing whatever was necessary to install the Bravox 603's.  Fiberglassed custom door panels were in the plans for whatever that vehicle was going to be, uh, well, right up until we picked up the Travy.  Now it's, "You aren't really going to cut it up and put holes in the doors are you?"    and "There's already places for tweeters, you can just use those right?"  then finally "You can just use the factory places for now, I want it to have a good sounding stereo but not know it until you hear it, as in can't see nothin'."
      So, there goes anything remotely close to what I was wanting to do.  I thought if the Bravox's wouldn't work out I might do a dedicated full range/midbass setup, or maybe even the equivalent of the Arc Audio Black 6.2 speakers in the SB Acoustic's mid and tweeter that Arc is using, or something really and truly worth a damn to do.  Nope.  She gave me a pretty much open budget for speakers but I don't see the point in spending any kind of good money on a set of components that cannot be optimally installed.  So I'm not completely sure where I'm going to go with the highs.  I have found a hell of a deal (<$250)on a new set of Kicker QS65.2 components which I'm leaning toward but I have to verify if there's any possibility of getting that tweeter behind the A pillar.  I've also looked at the MB Quart QC216 set which has a nice looking large format tweeter but since Maxxsonics has their nasty hands in MBQ now I'm kind of shying away from them as well.  As soon as I can figure out what the hell to do (still need to verify some measurements) I'll pull the trigger on equipment and get it coming.
      Although the Travy is pretty quiet from the factory I'm still going to be ordering some SDS to treat the doors and all of the rear to start with.  I'll work on the floor and roof after we've had it a little while.  It has the sun roofs so I'm not in a real hurry to tear all that interior off the roof, nor am I in a hurry to figure out how to tear all the seats, center console, and carpeting out to treat those areas just yet.  I also have to pull the door panels off to see what kind of baffles I'll need to construct for it.  Luckily with the lower power I'm looking at running and the 170A factory alternator I shouldn't be looking at having to do anything too major on the electrical side of things.  Probably just the BIG 3 in 1/0 with Knu Kolossus.
      So, that's the, um, kind of the plan, for what little plan there is.  The more I can verify as far as fit in this thing the better the direction for what/where it will go is going to look.  I hope to have all that figured out and to be ordering equipment and supplies this weekend.
      Here's a quick shot of the Travy.  I just grabbed it to show to a co-worker.
      Any input is welcome, especially from anyone who's done some install work in one of these as the entire Lambda platform is completely new to me.
    • By spanky1975
      I was on the forums awhile ago and got some great help designing a box from a member (can't remember who). Just wanted to show what he helped me do.
      I have 3 SSA DCON 12's in a 1999 Chevy Tahoe. I just metered on a TermLab and the results were great. I have had this system in for over a year and this is the first time I have had it metered. Thanks again for the help
      from the build...
      http://i1241.photobucket.com/albums/gg506/eddielong1975/376572_532111330147364_1694144002_n_zpsfdfeacd5.jpg
      http://i1241.photobucket.com/albums/gg506/eddielong1975/218079_532113020147195_1480755921_n_zps062b6a97.jpg
      http://i1241.photobucket.com/albums/gg506/eddielong1975/DSCF1556_zpsc40ae279.jpg
      http://i1241.photobucket.com/albums/gg506/eddielong1975/DSCF1555_zps13de709b.jpg
      http://i1241.photobucket.com/albums/gg506/eddielong1975/DSCF1552_zpsae1bfbf1.jpg
      TermLab results
      http://i1241.photobucket.com/albums/gg506/eddielong1975/20140403_182653_zps901abed9.jpg
      From the port
      http://i1241.photobucket.com/albums/gg506/eddielong1975/20140403_191109_zpse462b10c.jpg
      Up for sale is a used when I bought it single 4 ohm 15" SSA DCON sub.  It's in great condition showing the usual signs of having been mounted before.  I bought this from Sean (W140) awhile back with no real intentions except that it was a good price at the time.  I'm getting nickeled and dimed to death at the moment so I need it sold.
      $120 shipped to anywhere in the CONUS.
  • Recent YouTube Posts
