yfz04450
couple box building questions
Im planing on building a box for 2 sp4 15s. Is it better to separate the chambers or just have one big one. And also the box im looking at building is around 8 cu ft or 4 if separate.
Are you going SQ or SPL?
Then I would do 9cu single common chamber with one large port, test, then add blocks or large 45's to reduce volume if the meter tells you too.
Also what is the purpose of the baffles inside the box? Just a different type of bracing
You are going to have to be more specific. Baffles can be in there for a multitude of reasons.
