QmarcesQ
AMp for BTL N2
I have a single BTL N2 18 that i am upgrading from a planet audio 5000.1D to an amp that can put out real power numbers and has 1/0 power and ground.
I was thinking of the Crescendo 3500 or sundown 3500 as i hear the BTL N2 can easilly take 3500 RMS.
Are those 2 amps one of my better, if not the best options and if not which would you suggest in a daily driver?
I should probably include this is a dual 2 ohm that i will be wiring to 1 ohm.
Basically if you had the choice what is the perfect amp to pair with this sub?
**Also i would like to know if i have been misinformed of the btl handling that much power before i just go and blow this sub.**
You can easily blow that (and any car audio sub made) sub with a 2 kw amplifier if you try hard enough.
Nobody can tell you what is safe.  Additionally, there are no gain settings you can accomplish that will keep you safe under all conditions.
You need to use your head, and your other senses, to tell when the driver is getting too much power...
Well lets lead him in the right direction shall we (you)....what are some signs that would begin to let you know, when you are giving too much pipe to your "woofa"
I think this was a mrspam.gif post.
Too much pipe to your woofa. Haha. Never touch your woofa with your pipe.
