April 11, 201313 yr Use a dmm and check the coil to see if you have around 4 ohms. A zero reading would mean a broken wire or burned up coil. If it reads around four you have a amp issue. Alton beat me. Edited April 11, 201313 yr by pmureika
April 11, 201313 yr You can disconnect the speeaker wire from he amp and use a double a battery. touch the leads to the each side of the battery at the same time the sub should move up or down.If it doesnt you need to remove the sub and check your wiring.
April 11, 201313 yr A zero reading would indicate a short. An high or infinite reading would indicate a torn lead or cooked coil... (assuming the coil didn't cook into one blob of copper shorted on the former)
April 15, 201313 yr My vote is on RCA's they will get you every time! specially if the amp isnt secured 100% but it looks clean from the photos. I doubt its a "internal" problem on the amp since he has two other channels working correctly, Edited April 15, 201313 yr by Dictator
May 13, 201313 yr Author So for whatever reason, the sub works when I push in the logo... it works for a while then stops working... then if I push it in again it works... all the wiring is secure and fine but it seems to have something to do with the sub itself.
May 13, 201313 yr The tinsel leads are broke loose from the voice coil leads. Often times an issue with running the sub well beyond it's mechanical limits.
May 13, 201313 yr Author The tinsel leads are broke loose from the voice coil leads. Often times an issue with running the sub well beyond it's mechanical limits.is this a difficult fix? and the s4 dcon at 500w at 4 ohms destroyed the dcon? why is this ? would a higher rated rms sub such as a GCON work better ? or was I wired at 250 at 8 ohms ? Edited May 13, 201313 yr by [email protected]
May 13, 201313 yr It's as much box dependent as it is power dependent. I don't recall a post on what enclosure the sub is/was in, but as I did post before the amp has no SSF (sub sonic filter) so if you have it in a ported enclosure tuned to say the upper 30hz region for example and were playing tones or music below that frequency it wouldn't take much power to drive the sub beyond it's mechanical limits and cause this kind of damage. Even if it were in a sealed box, if the sealed enclosure was way too large or if it had some leaks the same issue can occur. It all depends on the suspension on a given speaker, but I've had some 6" speakers that you could easily destroy mechanically (ramming the voice coil into the back plate, running the coil completely out of the gap and hanging it on the top plate, tearing the surround or spiders, things of that nature) on only a few watts of power at those kinds of low frequencies in free air. When you play music, tones, etc. on a sub in a ported enclosure below the frequency it's tuned to the enclosure is no longer helping to control the cones movement. Far enough below tuning and it's pretty much the same as free air and it sure doesn't take too much for some drivers to destroy themselves mechanically. Now, given it's lasted a year in these conditions, the suspension has held up and it obviously has enough room in the motor to keep from smacking the voice coil into the back plate. The problem is running it like that, making it pull on the tinsels where they attach over and over again, like taking a piece of solid wire and bending it back and forth for awhile, eventually it will break. What are the specifications of the enclosure it was in? Give us every measurement and we can run those measurements and verify what the volume and tuning of the enclosure is. My money is on the enclosure being tuned high and with no SSF the sub was unloading in the enclosure and finally gave in to the stress. As far as the fix, it should be reconed to repair it properly. I've gotten lucky over the years and repaired a few drivers by resoldering the lead back onto the voice coil wire but that's few and far between.
May 15, 201313 yr Author The box is as follows: mdf enclosure w/ charcoal carpet, spring loaded terminal cupaero port double/flushed baffle 45 deg angles internal bracing29hz Made by Vitveet I believe these are the dimensions 24" wide16" high14" deep (15.5" after double and flushed mounted baffles)Afterall displacements, it's 2.18 cubes of airspace tuned to 29 hz! Subwill face back and port will fire to either side (drivers orpassenger's). Edited May 15, 201313 yr by [email protected]
May 22, 201313 yr Remove the sub and post some pics of the sub. Might help point out what happened.With you talking about pushing on the cone and it THEN working, m thought is a separated coil. Push on it and it smashes back together, then works its way back apart.J
June 5, 201313 yr Author why not recone it? I don't know how, and isnt it more than a recone, it seems the tinsel lead snapped ? I'm not sure Edited June 5, 201313 yr by [email protected]
June 5, 201313 yr why not recone it? I don't know how, and isnt it more than a recone, it seems the tinsel lead snapped ? I'm not sureIt is just a recone, and it is fairly easy to do.
June 5, 201313 yr Author no basket needed. juat the recone kitIts only 50 dollars more to just buy a brand new DCON... and I don't have any idea how to recone, nor do I have a soldering iron.. Any suggestions ?
June 5, 201313 yr reconing is pretty simple on a 12 and a soildering iron is only a few bucks online and most times they come with solder
June 5, 201313 yr Author you can youtube reconing TONS of videos on how to'sI saw one video that looked kind of intricate it had a sander type tool grinding all excess material off the inner sub? I don't have that
June 5, 201313 yr yes you do... if you dont have the tools to do so then just buy a new one and list this motor and basket for sale on the FS part of SSa... but you will be selling it as just that... a motor and a basket... it wont go for much because just as you stated its only 50 bucks more for a new one.
