disturbeddrummer254
possible defective amp
i hooked up 2 PSI 18S and 2 Soundstream tx1.2000d amps. Gains and freq levels were set the same on each paired amp n sub. The first lil while i played it, everything worked fine. then all the sudden i notice one sub were playing lower than the other. wtf right...checked the impedance on the coils and they check out fine. So over the last few weeks ive done everything i can think of from checking connections, swapping subs around, new rca cables, even thought it might be the bass knobs, and still one of the amps is putting out less power. I can tell there is an issue because when i play a test tone, what ever sub is hooked to that amp suffers especially in the low range 20-30hz compared to the other sub n amp that is playing at the same time.  i called Soundstream and they said it either plays or it doesnt, theirs probably nothing wrong with it...wft i duno what to do.
has anyone ever ran into an amp like this? i know somethinng is wrong with it even if it is playing somewhat.
im def gonna try n return the soundstream amps again and get a Crescendo 3500 of SSA that ought to take car of the issue haa
Edited by disturbeddrummer254
just because both amp settings are  the same does not mean  they are matching outputs,
 two different amps two different outputs.  the only way to match the output would be  to strap them if strapable  or a maxxlink  or  you can play a test tone, and use a DMM to set match gain
i see what ur saying. but when i first hooked it up, they sounded and looked like they were hitting the same then all the sudden there was a huge difference the way the 2 subs were hitting. to match the excursion by eyeing it i had to turn the gain down on the good amp almost all the way to mach the bad one. i know there shouldnt be that much of a difference
 have you swapped out amp position to rule out sub or connection issues?
Yea I unmounted them n swapped em n I plays low on the other sub too. I even hooked up 2 12s n a box. one sub to each amp, one hit alot lower than the other. Called the ebay seller today and the are gonna let me return them Thank goodness. Im gonna run both on a Crescendo bc3500 at .5 ohm n be done with it. Shoupd sound better with that amp anyway.
How are you making sure each amp is matched?
Just by the gain adjustment itself. Should be around
2/3 of the way up..visualy it looks about even. but if it were just a hair off between amps, it wouldn't cause the difference that im seeing. Were talkin about a huge difference in volume between the subs when played...i did swap subs to be sure it wasnt a coil. when I first hooked it all up the excursion of both subs when played was even. I heard it fail that day. it was loud and then I heard I difference all the sudden. I looked at the 2 subs n one was moving way more than the other. I think If I order a dc or crescendo amp im gonna order a smd gain setter also
Yea dd1...forgot the name of it...heard good thing about em
where at SMD?
 save your money....
 it seems to me if you have swapped the amp out, and the same issue is present  then you may have a bad amp.. see what the seller does to help you
    1. Recent Topics
        • 3 comments
        • 68 views
        • 398 comments
        • 33,235 views
        • 18 comments
        • 308 views
        • 4 comments
        • 142 views
        • 2 comments
        • 728 views
        • 5 comments
        • 1,571 views
  • Similar Content
    • By Wolfram Audio
      Now available on the SSA store!
      I do NOT check PMs on here. For any questions, email colin@wolframaudio.com
      Wolfram Audio W-3000.1:
      RMS Power @ 1 Ohm : 3,000 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 2,000 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 1,150 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Linked) :  6,500 Watts x 1 Channel (14.4v) Frequency Response : 10hz~350hz (+/-1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% Low Level Input (Gain) : 8V - 200mV Low Pass Filter : 30Hz - 250Hz Bass Boost : 0 ~ 12 dB Subsonic Filter : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Linkable) : Yes Recommended Fuse Rating : 300 Amps 1/0 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-1500.1:
      RMS Power @ 1 Ohm : 1,600 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 900 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 530 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Strapped) :  3,200 Watts x 1 Channel (14.4v) Frequency Response : 10Hz - 350Hz (+/- 1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% RCA Line Output : Yes Low Pass Filter : 30Hz - 250Hz Bass Boost @ 45 Hz : 0 ~ 12 dB Subsonic Filter : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Linkable) : Yes Fuse Rating : 150 Amps (Linked: 300A) 1/0 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-600.1:
      RMS Power @ 1 Ohm : 700 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 380 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 200 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Strapped) : 1,400 Watts x 1 Channel (14.4v) Frequency Response : 10Hz - 350Hz (+/- 1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% RCA Line Output : Yes Low Pass Filter : 30Hz - 250Hz Bass Boost : 0 ~ 12 dB Subsonic Filter @ 24 dB Slope : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Strappable) : Yes Fuse Rating : 30A x2 4 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-125.4:
      RMS Power @ 2 Ohms : 175 Watts x 4 Channels (14.4v) RMS Power @ 4 Ohms : 125 Watts x 4 Channels (14.4v) RMS Power @ 4 Ohms (Bridged) : 330 Watts x 2 (14.4v) Frequency Response: 15hz to 35khz Low Level Input Adjustment: 0.2v to 8v Signal to noise Ratio: >90 dB Minimum Impedance: 2 Ohm Low Pass Filter: 50hz to 500hz (500hz to 5khz [x10]) High Pass Filter: 50hz to 500hz (500hz to 5khz [x10]) T.H.D. Continuous @ 4ohm : 0.05% Operating Voltage : 10v ~ 16V Fuse Rating : 40A x2
    • By Godsmack
      - 27 Raptor 1/0 AWG Ring Terminals $20
      - Install Edge 5 pack remote wires [IEC P 3x5-6] 6 feet $15
       - 2 packs Install Edge 6.6 ft RCA cables [IRC GAC2] $7 each or $10 for both
       - 8 4 way Knu Konceptz 1/0AWG in 4 8AWG out $8 each or all for $55
       - 50ft 16AWG speaker cable spool $5
      - Install Edge Remote wire [IEC P18 X5-6] 18AWG $5
      - Knu Konceptz kolossus Flex 1/0 AWG Red power cable 44 ft $125; 8ft $25; 10.5ft $35 (all for 175)
       - 13 ft Q power 1/0 AWG Super Flex on spool $25; 15ft on spool $30
      - Approx 400 ft 16AWG Q power speaker wire on spool $40
       - Stinger 150 amp circuit breaker $25
      - 6 Install Edge Speaker Savers [IEC CAP 133] $6 per pack or all 6 pairs for $30
       - 2 2packs Rockford Fosgate 8AWG Ring Terminals $5 each or both for $7.50 -
       2 Rockford Fosgate Side mount battery terminals $9 each or both for $15 -
       Rockford Fosgate 2 output top mount battery terminal $10
      - Rockford Fosgate RCA coupler $5
      - Rockford Fosgate 10 AWG Amp kit (no RCA wires) 17 ft $30
       - Rockford Fosgate pack of 2 100amp MAXI fuses $10
       - Knu Konceptz Negative top mount terminal $10 -
      Metra Honda Harness [BB-WHHDI] $10 -
       Metra Inpala/Monte Carlo [XSVI-2105] $35 - Metra GM 88-05 22 pin harness [70-1858] $5
      - Pair of Dynex square box terminal cups $2
       - Dynex OEM Ford Radio removal tools $8
      - Stinger Blue HPM voltage meter [SVMB] $15
      - Tsunami Marine ANL fused distro, 1/0 AWG IN, 2 1/0AWG out $20
       - Generic ANL fuse holder, no cover $5 -
       Mini RCA stereo Y cable $2 - 14ft Raptor RCA cable $10
      - 16 ft Monster RCA cable $20 -
       Stinger 1/0 AWG ring terminal $4 -
       2 2male 1female RCA adapter $5 each or both for $7.50
      - 1 RCA to RCA dual male wire 9" $2 -
       2 Street wires RCA cables in bags 19.69 ft [ZN1260] $7.50 each or both for $10 -
       ANL fuses, 2 200amp, 4 250 amp, 2 300 amp, 4 100 amp, 2 500 amp. 500 amp are $5 per pair others are $3 per pair, or all for $30
      Total price when purchased individually: $761 Buy the whole lot: $650
      Open to trades, Nikon FX lenses and other photography equipment are of special interest. Feel free to contact with questions. Thanks for looking!!
      - Viper 500.4, missing xo cover, and right mounting feet. $300
      - MTX Road Thunder XO's for componants. $20 for the pair
      - Eclipse SC-8355/8365 XO's for componants $50 for the paid
      - Phoenix Gold Octane 4.0 2 amp. $150
      - JL Audio 500/1. Missing some side screws. Not 100% on what the guts condition is, and last I remember looking it was fine. $125
      - Digital Designs DD C1. $140
      ORIGINAL RE XXX 12" to come, as well as more amps. I'd love to sell everything as a lot, and am willing to make deals. Only thing trade wise I would be after is Nikon FX lenses, but feel free to offer up. Pics are all on the link below.
    • By matj1990
      So looking for some info about amplifier and efficiency.
      I have a xcon dual 1ohm 10"  so i can run at either .5ohm or 2ohm What i would like to know is  1500w @ .5ohm or 1500w @ 2ohm the 2ohm amplifier would be drawing more power to make its wattage because of the higher resistance correct ?
    • By GarrettHarvey
      Getting two hds212s and wanna know what amp to get(sq brand) , and if i should get dual 2 ohm or dual 4 ohm. And if youve done this build, what are the box measures
  • Recent YouTube Posts
