gacker
Atomic 3000.1d and 2 FI BLs
Would it be smart to run the BLs down to 0.5ohms for daily use if I upgraded all my electrical? The amp is an Atomic 3000.1d
atomics are usually stable at .5
But you highly increase the risk of having your amp puff the magic dragon
i would ask you why?
why not just run the amp at 1 ohm?
Because I was such a genius and goofed up by ordering them @ 2ohms ea
When did you order? Can you change it?
They delivered yesterday, so unfortunately not. This wasn't the amp I had originally planned on getting. I could always just get another and strap them I suppose.
Are you going to use your setup for competions? Or just a daily driver.
Daily.
Just try running the one amp and see how you like it. Whats it rated at 2 ohms?
2000 @2
3200 @1
It sounds crisp and clear at 2ohms, nut near enough power for me though.
You won't be able to hear the difference between 1000 and 1500rms !
Do you have a upgraded alternator and a rear battery?
XS Power D1200 in the back, stock alternator though.
Then I wouldn't double your power without electrical upgrades. Like a high output alternator and two runs of o gauge wire to the amps.
Depending how far the amp is from the secondary battery in the rear will determine if two runs of wire to the amp are needed. But two positive runs of wire is needed for the front battery to the rear battery connection.
someone wanna explain why   my questions is negative ?
i would ask you why?why not just run the amp at 1 ohm?
Not anymore, fixed it for you. Someone must have it out for you
 thats no joke.......  thanks.
lol ok so i think i know who it is now.
Who? It's getting annoying even for me
where in texas gacker?
North Richland Hills, in the Dallas-Ft Worth area
That's what's up man, I'm in Arlington which is not to far from you. If you need any assistance give me a shout. The DFW area is limited on here.
