ksva
Question about my setup and the X-15
Hi all,
I have a JBL GTO 1201.1 ii amplifier, I used to own two RE Audio SEX 12" subwoofers but the cheap tinsel leads snapped; I had heard nothing but great things about sundown so I opted for the X-15!
I wanted to know if anyone has used the JBL GTO 1201.1 before, and if you think it would sufficiently power the X15. I know the X15 asks for 1200w rms, the JBL only pushes ~1100w rms if I recall correctly. Is this a problem?
Another question, I had the two RE's in an L-Port 4.0cu @ 32hz- given the power of my amplifier do you think the single X15 in the correct enclosure will be just as loud?
Thanks in advance!
Too many variables..
1100 vs 1250 watts, ask yourself if you think a 150 watts will make a difference?
No it won't at all, there is no such thing as under powering a subwoofer. Like stated above there is only one way to tell if your new setup is as loud as your old one, install it and go from there.
Edited by jay-cee
