FadingCarton38
What would be louder in a 2000 explorer..2 15" mojos or 2 SA-12s
I have the MOJOs right now ran by a Hifonics Brutus 2100.d. Now i know thats not enough for them but in general with a custom box and either same amp or a saz-1500, could i get a little louder with the sundown SA-12s since ill actually be putting enough power to them? Also this would be in a 2000 ford explorer, so if anyone has witnessed a similar setup with 2 sa-12s in a explorer it would be great if you give feedback. thanks
You should probably post the same question a third time, that way you know it gets noticed. wackit2.gif
no one can really answer that. you could model the subs and enclosures with winisd. however that won't determine real world performance in your vehicle.
    1. Recent Topics
        • 19 comments
        • 320 views
        • 3 comments
        • 75 views
        • 398 comments
        • 33,297 views
        • 4 comments
        • 155 views
        • 2 comments
        • 733 views
        • 5 comments
        • 1,582 views
  • Similar Content
    • By jcarter1885
    • By Ryann627
      Thanks in advance guys.
    • By MJS_IraggiAlts
      PRV AUDIO Vocal Speakers....
      This may not make sense initially, but a high-quality speaker will have less bandwidth than a lower quality speaker... (for the most part)
      Just like a 3- or 4-way system is always better than a 1- or 2-way system.  The narrower the bandwidth the speaker must play the cleaner it will sound.  This will also keep you from asking the speaker to play up to its upper and lower frequency limits which are where it starts to sound "forced" to play those frequencies
      Pro Audio speakers are nothing new to car audio, but I see consumers not really knowing how to properly use them and having some issues which is understandable.  These are totally different than your standard coaxial speaker
      If you look at the graph on the 6mr500ndy, which sounds amazing, you'll see that it can play from 90hz to 12,000hz... but if you narrow it down to what is plays "best" and more "naturally" it’s closer to 200hz to 10,000hz.   Yes, it can play down to 50hz but not efficiently and not as well as 200 and up. Very low volume that would be fine but in what we do with the speaker you will want to cross it over closer to 200-300hz
      I get a lot of PMs asking if this speaker will pick up where my subs leave off?   … around 60-80hz.  I say no but the specs say "yes”. 99-13k so that may be a little confusing if you don’t look at the graph and understand what information it has in it
      So, for someone interested in using this speaker as a voice speaker, which I HIGHLY recommend, you will also need a "midbass" speaker to go with it such as a 10mb800 or 10mb500 or 8mb450.
      This leads me to another piece of information.  PRV model numbers have an "MR”, “MB", "SW" or "W" in between the size of the driver and wattage of the individual speaker. MR=midrange
      MB=midbass
      W=woofer
      SW=subwoofer
      This is a general guideline for what the speaker is geared towards. That doesn’t mean an 8mb450 can’t be used for midrange or and 8mr400 can’t be used for midbass.  That is where the graph and interpretation of the graph comes into play
      There is a lot more that goes into designing your front stage or your "voice" speakers that one of these days I’ll try and have a more in depth write up.   The possibilities are endless...
    • By Second Skin
      Starting on May 1st, Second Skin is giving away 31 pairs of Speaker Tweakers – that’s one winner EVERY SINGLE DAY in May. 62 lucky car speakers are about to sound a heck of a lot better with less back waves! To enter, just go to this page and sign up!
      Enter the Giveaway
      Why are you still reading down here? Get over there and sign up to win!!
  • Recent YouTube Posts
